I have a yale smart lock that I want to control remotely. After doing a bit of research I found that I could use Home Assistant to do this using Z-Wave. So I got a Zwave module that slots into the lock. Then followed the instructions for installing HA on the Pi. Amazingly I got it installed eventually. Now I’m looking at the HA page on my laptop. When I go to try and configure Z-Wave it asks for a path to a USB stick and a Network Key. I also read in the docs that " On the Raspberry Pi you will need to enable the serial interface in the raspi-config tool before you can add Z-Wave to Home Assistant." OK now I’m lost. 2 questions to start.
1- What is the raspi-config tool and how do I enable the serial interface with it? Where do I find the Network key?
2- And do I need to buy a USB stick with Z-wave on it? (Actually I just counted and that might be 3 questions.)
I thought this would be a cheaper option than say Smartthings, but so far I have bought a raspberry Pi, a blank USB stick, and a micro SD-card. If I now have to buy a Z-wave stick for £40 then it’s not looking like a cheaper alternative at all! Any help would be greatly appreciated. Thanks
