Connect to xiaoyi webcam!
Can you add xiaoyi webcam support?
Regards.
Have you tried:
or
I try both, but I cannot connect.
Main stream: rtsp://ipaddress:554/ch0_0.h264
Minor stream: rtsp://ipaddress:554/ch0_1.h264
Audio stream: rtsp://ipaddress:554/ch0_3.h264
http://xiaoyi.querex.be/instructions/
Neither method would work as there is currently no RTSP support for HA; however there have been feature requests posted for it so you may want to add your votes there.
In the interim, you may want to look into these posts:
I successfully use the following configuration with xiaoyi camera:
camera:
  - platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://192.168.x.x:554/ch0.h264
Note that you will have to install ffmpeg on your Pi in order for this to work.
@rpitera How I install ffmpeg in RPI?
Update: installed libav-tools and created a symbolic link. It’s working! Thanks.
Regards,
I’ve seen a lot of people having problems setting this up; would you mind explaining your steps?
Yes.
1/ install libav-tools: sudo apt install libav-tools
2/ create symbolic link: sudo ln -s /usr/bin/avconv /usr/bin/ffmpeg
Regards,
Thanks - I don’t use this but I’m sure this will help a lot of people and I appreciate your taking the time!
You can also install ffmpeg from backports:
https://backports.debian.org/Instructions/
apt-get -t jessie-backports ffmpeg
How would one know the correct suffix after “:554/”? This site uses “:554/tcp/av0_0” while here you use “:554/ch0.h264”. Both cases doesn’t work on my setup.
Please help. Thanks.
This is my entry in configuration.yaml, if it helps you. Works fine for me.
camera:
  • platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://x.x.x.x:554/ch0_0.h264
It depends on how it has been defined in your firmware for the cam.
I have to do reverse engineering.
  1. Using telnet I’ve found the prompt to be RT-IPC
  2. I’ve searched "RT-IPC” using Google and found that the the rtsp urls are as follows:
    rtsp://:554/11 -> 720P resolution or “MainFlow”
    rtsp://:554/12 -> VGA or “MinorFlow”
  3. Verified using VLC
You could also can get more details using this generic query http://<ip address>/cgi-bin/hi3510/param.cgi?cmd=getserverinfo gives me
var serialNum="VVVIPC1507283580HSDS-jPD4tU5cTcv"; var model="RT_IPC"; var hardVersion="3500-ov9712a"; var softVersion="V3.5.4.2301-S50-SMC-B20150723B"; var ipcname="IPCAM"; var startdate="1970-1-1 8:0:17"; var runtimes="0 day, 0:20"; var sdstatus="out"; var sdfreespace="0 "; var sdtotalspace="0 "; var builddate="Jul 28 2015 "; var productmodel="null"; var vendor="RTJ"; var swver=""; var hwver=""; var mppver="mpp2";
The model is RT_IPC and the vendor is RTJ, you can search using this and will find the correct rtsp url.
Any one know about how to add xiaomi fang with RTSP?
Check out this project.
i know about it, i ask about how to add it to HA :slight_smile: but i find how so Thanks any way
How did you?
  - platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://192.168.31.41/unicast
