Connecting 1-Wire to HA
I’m trying to connect my 1-Wire network to HA running under HAOS on RPi. I have a D1 Mini Pro connected via USB to my RPi. I have ESP Home installed in HA. It is showing 2 devices, a LocalBytes plug which seems to be working correctly, and 1-Wire D1 Mini Pro, which is showing 1 device and 1 entity. The entity shows name=update.1_wire_d1_mini_pro_firmware and Entity id=update.1_wire_d1_mini_pro_firmware. It shows status unavailable.
How do I make progress with this, so that I can read the devices on the 1-Wire network (mostly DS18B20 temperature sensors)?
Thank you - Rowan
