my question is how I can connect a Raspi-based HAOS system to a Vaillant heat pump via EBus. I already use the MyVaillant integration (myVAILLANT integration). My SMA-based solar system is also already connected to the Vaillant heat pump via EBus (directly via their apps). The question refers explicitly to a connection that is made directly between the HomeAssistant and the heat pump. No detour via wired systems such as Reserve-my-adapter – ebusd and GitHub - john30/ebusd: daemon for communication with eBUS heating systems.
Is there anything?
Frank
