I've developed an integration for the API behind the myVAILLANT app, which lets you control Vaillant HVAC equipment (aroTHERM heatpumps, boilers, hydraulic stations, etc) from Home Assistant:
Supports climate & hot water controls, as well as sensor information
Control operating modes, target temperature, and presets such as holiday more or quick veto
Track sensor information of devices, such as temperature, humidity, operating mode, energy usage, or energy efficiency
See diagnostic information, such as the current heating curve, flow temperature, or water pressure
Also compatible with MiGo Link app from Saunier Duval
Installation with HACS - reboot - add integration with user/pw/country… successfully!
But no devices/entities…
Can you help?
Logger: homeassistant.components.binary_sensor
Source: custom_components/mypyllant/binary_sensor.py:32
Integration: Binärsensor (documentation, issues)
First occurred: 16:14:50 (1 occurrences)
Last logged: 16:14:50
Error while setting up mypyllant platform for binary_sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 293, in _async_setup_platform
await asyncio.shield(task)
File "/config/custom_components/mypyllant/binary_sensor.py", line 32, in async_setup_entry
for index, system in enumerate(coordinator.data):
TypeError: 'NoneType' object is not iterable
Great, as soon as my Sensonet VR921 completes the forced upgrade to the Myvaillant app (since 24h, the device is updating), I will test the integration.
really I have to thank you, for this I was searching
So I can take away the EBUS controller.
The consumption is not really to the values from the Vaillant!
Sidenote:
I’m using that but get lots of connection errors/timeouts. I’m trying to alternate my heating and boiler/buffer with the use of solar input. The system now is unrelyable because of these errors. Was looking at a EEBUS sollution when I found this.
Hi, I was waiting for this integration, unfortunately there is no option to select the country Czech Republic to fill in the integration. Would it be possible to add please?
I just had a Vaillant combi installed today along with VRC720.
Would I be right in thinking that I also need the sensoNET Internet Gateway to allow me to link HA to the app generated data?
On a side note, did your thermostat come with an outside sensor? I’m thinking my installer forgot it
I found the reason for that, the library I was using to list countries returned Czech Republic as Czechia and that wasn’t available from Vaillant. Should be fixed in the latest version.
@callumw yeah, you will need sensoNET to use the myVAILLANT App (and my integration). I installed an outdoor temperature sensor that hooks up to the hydraulic station. I had to order that separately.
Perfect, thank you for adding the Czech Republic. The integration works great. Is it possible to calculate the daily consumption in kWh for heating and hot water?
Hello @pdd and thank you for this integration.
I have a Saunier Duval Duomax boiler with a Miset thermostat coupled with a Migolink gateway and I cannot find an integration compatible with my equipment. Do you think it is possible to make your integration compatible with Saunier Duval knowing that they are the same products?
I am using the android app Migolink V2.4.1 (14381)which is a copy of Myvaillant v 2.4.1(14383)
Thanks in advance,
Hey @telenaze, the authentication and API endpoints would probably need to be updated. In the myVAILLANT app a browser window opens when logging in. If you can grab that link and post it in here (without your email), I might be able to help you.
@jaroslav.caha you can add the energy usage to the energy dashboard to see daily / weekly / monthly totals. Or create a graph that sums up per day, I use mini-graph-card:
type: custom:mini-graph-card
entities:
- entity: sensor.arotherm_plus_consumed_electrical_energy_heating_2
name: Energy Consumption Heating
hours_to_show: 168
group_by: date
animate: true
hour24: true
show:
graph: bar
Thanks, I added preliminary and completely untested support for this new endpoint in version 0.2.0. Let me know, if it works! Just select Saunier Duval as a brand when setting up the integration.
