I have my main HA instance on a virtual machine of my ESXi host. When I made this change I lost the ability to use the GPIO pins of my Raspberry Pi to send 433mhz signals to my RF switches. I would like to get these working again using a Pi Zero W I recently picked up and my old hardware. I can also put a temp sensor / pir sensor ect. on it and use those also.
I was able to get the temp sensor reporting to my main HA instance using the restful sensor component. It works well and suits my needs for that item. However, I want to be able to control the switches from my main instance, write my automations there etc.
The implementation of the master/slave setup for multiple HA instances appears to be broken at best. Ive seen a few people report success, however, more seem to report issues.
How is anyone else handling a setup like this? MQTT, rest seem like good avenues. I am thinking of using a restful switch on my main instance that (if I understand the docs correctly) should be able to get the status and post a command to turn on the switch via the Pi.
It seems like MQTT would need more setup and doesn’t seem as easy to me. However, I know MQTT can be very useful and I wouldn’t mind diving into it if someone had an example to get me started.
Looks like @PtP used the command line switch with some success. I may make this my first attempt tonight, although I am still interested in how others have implemented this. My main concern is keeping both HA instances up to date. The main instance is what I use to control everything, however, the Pi instance will ultimately have the state of and control of the actual switches.
I have been using this for some time now and it works great. I currently have 8 devices connected to 2 different machines that I pull into my main HA instance.
My only complaint is that lights cannot be dimmed (easily).
I typically don’t update the remote instances very often as long as the devices on there are working good.
I am updating mine today because I had some time to kill at work. I can ssh into both instances so it pretty easy to do.
My only complaint is that lights cannot be dimmed (easily). [/quote]
Thanks for the update. My switches are just on/off so this should work well. I’m hoping I can write the code once and then copy/paste the rest with a few updates as I have 5 switches to make. Should be able to.
I tend to do the same for my main instance to, if it’s not broke don’t mess with it. I was on version 43 until a day or so ago when I needed a new component.
