Connecting to a remote Zigbee coordinator with ZHA using ser2net
This is a quick guide on how to connect ZHA to a Zigbee coordinator on different hardware than the hardware HomeAssistant is running on.
Reasons for wanting to do this could include:
  • HomeAssistant running on hardware in a bad location in your house
  • Needing to use ZHA over Z2M
  • Long USB cords causing instability in Zigbee network
You will need another computer running Linux. A Raspberry Pi would work fine. I am using some really old Optiplex SFF running Debian.
  1. On the linux computer, run apt install ser2net.
  2. Get the USB path by-id. This prevents issues when plugging in other devices to USB ports or moving the device to a different port. ls /dev/serial/by-id
    My output: usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2420347-if00
  3. Edit the yaml config for ser2net with sudo nano /etc/ser2net.yaml
    3.a The file will have a bunch of default config in it - comment all of that out and add the new config to the bottom:
connection: &con01
    accepter: tcp,20108
    enable: on
    options:
      kickolduser: true
      chardelay-min: 0
      chardelay-max: 0
    connector: serialdev,
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2420347-if00,
              115200n81,nobreak,local
Check: [Connect to a remote adapter | Zigbee2MQTT](Connect to a Remote Adapter) for examples of other adapter configs. Note I changed the Conbee II config slightly from the example in that article to match the default configs I noticed in the yaml file and added some options I think provide more stability. I am not sure if this was necessary.
  1. Save with ctrl+x and execute:
    sudo systemctl restart ser2net
  2. In HomeAssistant navigate to Settings > Devices & Services > Integrations > ZHA (Configure button).
  3. Click Migrate Radio
  4. Select reconfigure the current radio
  5. On serial device path click “enter manually”
  6. Type in:
    tcp://192.168.X.X:20108
    9.a Substitute 192.168.X.X with the IP or hostname of the workstation that the coordinator is plugged into.
I have HomeAssistant running on a rack server in the basement. Previously I was using a very long USB cable and a lot of commands would fail, especially scenes involving a lot of Zigbee devices. Since making this change the stability has been rock solid.
Edit:
  • Changed the USB path to device by-id - Thanks SwerveShot
  • Added chardeley-min and chardelay-max options in ser2net.yaml - not sure if this actually does anything, but larger commans, like turn off all the lights at once, seem to be more consistent.
  • Added “or hostname” in option 9, as that is what I am using now
What an excellent idea. I was just wondering if this would be possible only to find a complete guide available to me. Thanks a lot for posting your setup.
At the moment I have a POPP ZB Stick connected directly to my home assistant server, but having it located elsewhere will be much better in terms of signal strength. So I will definitely give this a try.
I’m already using an old Raspberry Pi with ser2net to connect to my smart utility meter which is nowhere near my home assistant server. Adding a couple of new lines to my ser2net config is something I think I can probably handle. :grinning_face_with_smiling_eyes:
Aside from the fact that I’m running a bit older version of ser2net which does not support a YAML style config the migration went fine. I don’t have a kickolduser setting and reloading the zha integration did not close the TCP connection right away. So I had to allow more than 1 connection.
Finally, as suggested on the ZHA integration page I switched to using the device path /dev/serial/by-id instead of using /dev/ttyUSB1. This will cause the configuration to still work when sticking USB devices in other ports than they were inserted originally. And maybe got another ttyUSB reference assigned. Devices in the /dev/serial/by-id path are simply symbolic links so it does not affect the way the devices work.
3001:raw:600:/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0:115200 8DATABITS NONE 1STOPBIT max-connections=3
Cannot access /dev/serial/by-id: No such file or directory
So far, no good!:unamused:
That’s strange. What distro are you using. This is after you plugged your coordinator into the remote computer?
Unplug and replug your coordinator into the USB port then run dmesg. What is your output?
Perhaps this is why:
serial:
  port: tcp://192.168.1.115:8888
  adapter: ezsp
is it possible to do a backup of the zigbee stick if it is attached via ser2net?
I don’t get errors when performing backups. I did recently switch to a Sonoff 3.0 and backing up from Conbee to Sonoff failed, but I think that’s to be expected.
Hello, first, thanks for this guide! I am also looking for such a solution so that I want to move my device running home assistant to basement, and I still need to put the Z-Wave and ZHA stick in the middle of living room.
I just have question, because in the home assistant ZHA documentation, it says Ser2Net remote adapter is not recommended, “Serial protocols used by the Zigbee Coordinator do not have enough robustness, resilience, or fault tolerance to handle packet loss and latency delays that can occur over unstable connections.”
I know this is somehow has to be comprised. I only want to ask, what is the real experience you have with this setup. Is there realizable behavior? Or it doesn’t have big impact?
Thanks! I currently only connected on IKEA remote button in the ZHA, and want to add a Aqara relay module later.
I haven’t had any issues.
I think the key part in the caution in the ZHA documentaion is:
Be aware that using a Zigbee Coordinator via a Serial-Proxy-Server (also known as Serial-to-IP bridge or Ser2Net remote adapter) over a Wi-Fi, WAN, or VPN connection is not recommended.
I would recommend connecting over ethernet. I haven’t, nor would I, try to connect over WIFI, WAN, or VPN.
what is your ser2net version?
ser2net -v
I recently bought a Home Assistant Connect ZBT-2, and initially connected it directly to the computer I run Home Assistant on. Today I reconnected the device to a Raspberry Pi running Trixie and ser2net 4.6.4-1, following the excellent steps from OCT0PUSCRIME above, but had to fiddle with the configuration in /etc/ser2net.yaml. Sharing the working config here in case it helps someone else:
connection: &con01
    accepter: tcp,20108
    enable: on
    options:
      kickolduser: true
      chardelay-min: 0
      chardelay-max: 0
              /dev/serial/by-id/usb-Nabu_Casa_ZBT-2_1CDBD45E1B94-if00,
              460800n81,nobreak,local
In Home Assistant, the Zigbee Home Automation configuration is:
Radio type: ezsp
Serial port: tcp://x.x.x.x:20108
Baudrate: 460800
Serial port flow control: none
Ser2Net is a good work around for now. I think the HA / NC team will update the ZBT-2 in time to add PoE like they did with the ZWA-2.
I am kind of holding out for now, but long USB Cables and USB Hubs are not the best solution. The sometimes do cause errors.
This tutorial is one of the best I have seen as far as how easy it is to follow and mostly getting it up and running.
I am using the ZWA-2 with the experimental firmware on the external ESP ethernet device (I didn’t want to change firmware on the actual ZWA-2). It seems to work quite well.
Thank you! I am glad people are still finding this helpful 2 years later. I was also bummed to see the lack of PoE on the ZWA or I would have pulled the trigger!
I had some issues with my TI USB co-ordinator where Z2M would not connect on start, would complain about a 6sec timeout occuring. Found the stick was entering flash mode on boot when connected through ser2net. Would only connect to Z2M after the device left flash mode and resumed a normal start - could take 15 minutes. My config is slightly modified from above,
connection: &con01
  accepter: tcp,20108
  enable: on
  connector: serialdev,/dev/ttyUSB0,115200n81,nobreak,local,dtr=off,rts=off
  options:
    kickolduser: true
    chardelay-min: 0
    chardelay-max: 0
Someone might find it useful down the track, took me days to work out what the issue was.
