@Burningstone
here is the complete log
2019-11-18 09:02:41 ERROR (MainThread) [homeassistant.components.hue] Error connecting to the Hue bridge at 192.168.2.29
2019-11-18 09:02:42 WARNING (MainThread) [homeassistant.config_entries] Config entry for hue not ready yet. Retrying in 5 seconds.
2019-11-18 09:02:48 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-11-18 09:02:54 WARNING (MainThread) [homeassistant.components.weather] Setup of platform met is taking over 10 seconds.
2019-11-18 09:02:58 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform yamaha is taking over 10 seconds.
2019-11-18 09:03:11 ERROR (MainThread) [homeassistant.components.plex] Plex server could not be reached: http://192.168.2.200:32400
2019-11-18 09:03:11 ERROR (MainThread) [homeassistant.components.plex] Plex server (http://192.168.2.200:32400) could not be reached: [HTTPConnectionPool(host='192.168.2.200', port=32400): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f88bbeadad0>, 'Connection to 192.168.2.200 timed out. (connect timeout=30)'))]
2019-11-18 09:03:48 ERROR (MainThread) [homeassistant.components.media_player] Setup of platform yamaha is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2019-11-18 09:03:51 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:04:22 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:04:52 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:04:55 ERROR (SyncWorker_18) [rxv] Failed to fetch http://192.168.2.168:80/YamahaRemoteControl/desc.xml
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Operation timed out
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1244, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.7/http/client.py", line 966, in send
self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f88bb597f90>: Failed to establish a new connection: [Errno 110] Operation timed out
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.2.168', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f88bb597f90>: Failed to establish a new connection: [Errno 110] Operation timed out'))
File "/usr/local/lib/python3.7/site-packages/rxv/rxv.py", line 108, in _discover_features
desc_xml = self._session.get(self.unit_desc_url).content
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.2.168', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f88bb597f90>: Failed to establish a new connection: [Errno 110] Operation timed out'))
2019-11-18 09:04:55 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
raise err
sock.connect(sa)
chunked=chunked,
self.send(msg)
self.connect()
timeout=timeout
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 118, in setup_platform
receivers = rxv.RXV(ctrl_url, name).zone_controllers()
File "/usr/local/lib/python3.7/site-packages/rxv/rxv.py", line 103, in __init__
self._discover_features()
2019-11-18 09:05:23 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:08:28 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:23:54 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 09:54:50 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 10:25:44 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 10:56:41 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 11:27:32 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 11:58:28 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 12:29:22 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 13:00:13 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 13:31:06 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
2019-11-18 14:02:03 ERROR (MainThread) [pysma] Could not start session, Could not connect to SMA at http://192.168.2.44 (timeout), got {'err': 'Could not connect to SMA at http://192.168.2.44 (timeout)'}
Concerning the sma and the yamaha receiver. This is normal, there are not online for the moment.
as i mentioned, i already tried to remplace the old container with a new one.
The last thing i did before it cease working was the introduction of these line in my configuration.yalm.
`logger:
default: warning
logs:
homeassistant.components.homekit: debug
pyhap: debug
homekit:
filter:
include_entities:
- demo.demo`
I already remove these lines from my config file but still autistic. :slight_smile:
