Connectivity Issues - duckdns
Hi Guys
Suddenly started having issues today, my duckdns (inc letsencrypt) setup has been working fine since last September.
All of a sudden today I’m unable to connect to my HA on the duckdns when on the internal network. Was advised it could be a nat loopback issue but nothing has changed on my modem or router, no firmware updates etc.
For some reason now I can access it via internal IP address on my wired desktop PC, but if I try and connect on my iPhone, the only way I can get it to work is to disable WiFi and connect via the duckdns address but over 4G.
I’ve looked in the log files and can see the below:
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:777)
2018-06-29 16:42:56 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x731d9cd0>: SSL handshake failed
File “uvloop/sslproto.pyx”, line 592, in uvloop.loop.SSLProtocol._on_handshake_complete
File “uvloop/sslproto.pyx”, line 171, in uvloop.loop._SSLPipe.feed_ssldata
File “/usr/lib/python3.6/ssl.py”, line 689, in do_handshake
self._sslobj.do_handshake()
2018-06-29 16:42:56 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x731d9cd0>: SSL error errno:1 reason: HTTP_REQUEST
File “uvloop/sslproto.pyx”, line 496, in uvloop.loop.SSLProtocol.data_received
File “uvloop/sslproto.pyx”, line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-06-29 16:43:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
I’m on 0.72.1 and there’s no errors I can see in the DuckDNS add-on log.
Any help would be massively appreciated, thanks!
I started to get these errors too when I updated to 0.72.0
These errors do not seem functionality. They occur with “Task was destroyed but it is pending!”
I can still access hassio from WiFi or 4G using the same DuckDNS URL.
To get this working I had to install DNSmasq add-on since I don’t have NAT loopback on my router.
And without me doing anything…it’s started working again as it should do this morning…confused haha!
I’m also getting these errors, it doesn’t seem to effect access to home assistant but it’s constantly spamming my log.
2018-07-03 10:00:28 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x734fcbf0>: SSL handshake failed
  File "uvloop/sslproto.pyx", line 592, in uvloop.loop.SSLProtocol._on_handshake_complete
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
2018-07-03 10:00:28 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x734fcbf0>: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 496, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-07-03 10:00:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Does anyone have a solution?
Hi everyone!
I actually have the same problem - no access to HomeAssist through “duckdns”. Though from local net there is the access. Here is the text i receive in module DuckDNS:
" end of string encountered while processing type of subject name element #1
problems making Certificate Request".
The access through DuckDNS has worked successfully for a year. The problem appeared a few days ago.
Did anyone find the solution? Any piece of advise?
Thanks.
I’ve got the same errors as you.
I don’t have access through duckdns and the only way i can connect is through my local network.
I hope there is a solution for this problem!
After working fine for another few days, it has stopped working again today.
Getting these errors in the log files whenever I try and access via duckdns:
2018-07-04 00:24:57 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x7396a6f0>: SSL error errno:1 reason: HTTP_REQUEST
Tried uninstalling and re-installing the duckdns add-on, but from what I can tell in the log it’s all setup and working perfectly. But still no access via duckdns address internally, but it does work if I switch wifi off on my phone and use 4G. Does everybody elses duckdns work when accessing outside of your network??
Duckdns add-on logs (edited)
> # INFO: Using main config file /data/workdir/config
> + Generating account key...
> + Registering account key with ACME server...
> + Done!
> Wed Jul  4 09:00:38 BST 2018: OK
> 1.2.3.4
> NOCHANGE
>  + Creating chain cache directory /data/workdir/chains
> Processing mydomain.duckdns.org
>  + Creating new directory /data/letsencrypt/mydomain.duckdns.org ...
>  + Signing domains...
>  + Generating private key...
>  + Generating signing request...
>  + Requesting new certificate order from CA...
>  + Received 1 authorizations URLs from the CA
>  + Handling authorization for mydomain.duckdns.org
>  + 1 pending challenge(s)
>  + Deploying challenge tokens...
> OK + Responding to challenge for mydomain.duckdns.org authorization...
>  + Challenge is valid!
>  + Cleaning challenge tokens...
> OK + Requesting certificate...
>  + Checking certificate...
>  + Done!
>  + Creating fullchain.pem...
>  + Done!
> Wed Jul  4 09:06:33 BST 2018: OK
> 1.2.3.4
> NOCHANGE
I’m using cludflare as ssl. But I’m also getting
2018-07-04 09:06:02 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x70308a90>: SSL handshake failed
    2018-07-04 09:06:02 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x70308a90>: SSL error errno:1 reason: HTTP_REQUEST
My problem was that my certificate expired. The problem was that i used both the Let’s Encrypt and the DuckDNS add-on. I deinstalled both and only reinstalled the DuckDNS add-on. After i changed “accept_terms”: from false to true, my certificated got renewed.
But that did not fixed my errors in the logs. After enabling the logger component i saw in the logs that the Sabnzb debug info was the error. So i added Sabnzb at the Discovery Ignore list, after a restart the errors didn’t appear any more in the logs.
2018-07-04 22:15:46 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=28 from 2018-07-04 20:01:14.196630)
2018-07-04 22:16:07 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-04 22:17:02 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x728ad930>: SSL handshake failed
2018-07-04 22:17:02 ERROR (MainThread) [homeassistant.core] Error doing job: <uvloop.loop.SSLProtocol object at 0x728ad930>: SSL error errno:1 reason: HTTP_REQUEST
Got the same issue. Not able to access HA at all. This is a brand new installation of the duckdns add-on.
Having the same error, started a week or two ago:
Error doing job: SSL error errno:1 reason: UNKNOWN_PROTOCOL
I don’t use HASS.io, but I faced same issue with normal docker installation at version 0.73.1.
Home Assistant stop responding after while. If I restart Home Assistant everything will work and can be accessible via DuckDNS uri.
Log give me these:
Error doing job: SSL error errno:1 reason: HTTP_REQUEST
File “uvloop/sslproto.pyx”, line 504, in uvloop.loop.SSLProtocol.data_received
File “/usr/local/lib/python3.6/ssl.py”, line 689, in do_handshake
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
Error doing job: SSL handshake failed
File “uvloop/handles/stream.pyx”, line 609, in uvloop.loop.UVStream._on_eof
Mine has been working fine for about a week (it just started working without me doing anything), an again this morning it has stopped again, perfectly on 7am as well according to the logs:
2018-07-12 07:00:00 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/sslproto.pyx", line 593, in uvloop.loop.SSLProtocol._on_handshake_complete
I see the same issue. Did you solved it?
Been seeing this as well, all of a sudden it’ll just stop loading. I get the password prompt but then it fails to connect. If I load on the local ip address then I can load the interface if I add exceptions for the SSL cert. The only thing I’ve found that gets me back up and running is to do a completely fresh install and then restore from a backup from before the problem started happening.
However I’ve done three reinstalls tonight and so far each one has resulted in the same problem when restoring from the backup.
Also I sometimes get an error from the browser of the following form:
Corrupted Content Error
The site at https://hostname:port/ has experienced a network protocol violation that cannot be repaired.
I’ve got no idea on this one. Mine has had the issues about 3 or 4 times, but it will seemingly fix itself and work for days at a time with no problem whatsoever.
Mine’s been 100% reliable for many months and has literally just stopped working, no errors in the log. Might have been with the 73.1 update but can’t be sure.
same here, did a full restore of HA without DuckDNS, errors gone.
After installing DuckDNS and get the new cetificate the errors are back.
It’s working fine from outside but I don’t like the errors.
The log is full with those errors
