Control garage door using home assistant without live wiring
Hi
I wanted to avoid the live wiring + keep the garage door motor clean.
I have done a hack to add my garage door control into home assistant using RF Remote.
Wanted to share here if anyone is looking to avoid the electrical wiring while adding wifi to garage door
YouTube: https://youtu.be/rN_rt7zWKl4
Blog post: http://accordingtoalinahid.blogspot.com/2019/12/the-story-of-hack-job.html?m=1
Nice one! I’m still locking for a solution as well. As I don’t have a spare remote, I wanted to use something like a Broadlink to emulate the original remote.
My system is a closed source system (yepp, thanks to my landlord - not), with extremely expensive parts (I’m quite sure, they sell these cheap to the buiders, and afterwards the users have to make it profitable): a spare remote is around 120.-€ each…
For your open/close/pause problem, I’d use two of the cheap Xiaomi/Aqara door/window sensors. One at the upper end of the garage door, one at the lower end. This way you will get three states: open, close and neither of both. Open or close is usable, if neither of them, send the command and wait a few seconds - than you should get either open or close… :slight_smile:
Thanks. If you are thinking about emulating RF signal using broadlink please double check if you can map rolling code in it. I failed with Sonoff RF bridge because of the rolling code issue. Not sure if broadlink solves it or not?
Also check out this https://bondhome.io/
These guys claim that their device can map rolling code. I almost bought one until I figured to hack the RF remote.
Thanks for the tips on the open/close state. I was thinking similar, but your one is better.
@alinahid looks like a cool product but would be great to get rolling code working on the Sonoff RF bridge
@alinahid LOVE this, I have the EXACT same remote and controller (based on the video, is it a steel-line SD800??). I couldn’t see how to access the exposed wiring when I looked at it (was originally going to buy something like you mentioned).
I’m a fellow aussie, will give this ago myself based on the video and instructions.
Question, where can you get a remote for $15? Would love to set this all up from scratch.
I plan to use xiaomi window/door sensors to check state of completely closed / not completely closed (not a perfect solution but good enough for me when I can’t see the door).
I ended up going with a z-wave garge controller, cost more but it connects direclty into the device using the two remote access ports on top.
Great idea. I was looking to this and while googling I found this https://www.itead.cc/sonoff-re5v1c.html
It looks like great ideas quickly find an implementation.
