Ok. The SBC connection on the expansion board will open/close the gate with RatGDO. I did a bit of experimenting and I couldn’t find a connection that would trigger open/close states via the dry contact connections. I ran out of time and didn’t try very hard though. I need to read up a bit more on how to get that working, if it’s at all possible. It may need to wait until the weekend before try #2.
Regardless, the way I use the RSL12UL is very simple. It’s just something I need to open, and then let a timer and sensors manage the rest. So, even if I can’t pull a status on the gate, I really only need it to function like a single-button opener. Would be nice to get it working completely, however.
Great info in this thread by the way. The HA community is something special.
I have a Liftmaster CSL24UL gate operator, with the add-on board. Like fyton2v, the board layout of this board is different than the LA400. I formatted the ratgdo with the MQTT firmware, enabled dry contact functionality, and hooked up the device as follows:
Red Ctrl - “SBC+” pin on add-on board
Wht GND - “COM-”, under the SBC pin on the add-on board
Open - Add-on board AUX Relay 1 NC (relay 1 DIP switch set to OFF-OFF-ON)
Close - Add-on board AUX Relay 2 NO (relay 2 DIP switch set to OFF-ON-OFF)
GND - Wired into add-on board Aux Relay 1 AND 2 commons (commons wired together - I have no idea if this is proper)
Door open/close sensing works fine, but I can’t close it via ratgdo. I’m thinking possibly a bad connection to the SBC pin or common, or I need to pin into something else on the board for “Wht GND”… unlike the LA400, this board doesn’t have a board ground connection that I can see.
Why use the AUX Relay instead of these on your expansion board?
I tried to look up your model’s board too and it might have an option in the top right of the main board:
Unlike the LA400, the main board of the CSL24UL doesn’t have a SBC terminal.
Regarding using OPN, CLS, STP on the expansion board instead of the AUX Relays, I could be wrong, but I think that those are for control, not limit sensing…that’s at least what the wiring diagram makes it seem like.
That’s much more detailed than what I found. Thanks.
I think you are right that those are for control and not limit sensing.
Can you not use just the SBC terminal on the Expansion board? If that’s not there,
I think you could try to use just the “open” and “common” in the upper right corner on the main board OR on the bottom left corner.
The only way I can see this not working is if your opener needs a different command for open vs close. Maybe try to put two jumpers to both Open and Close from “Red Ctrl to GDO” if just one doesn’t work.
Good find on the aux relays for sensing status. I think that is a game changer for those with expansion boards!
During the little bit of testing I’ve done on the 12UL, the Open and Close terminals on both the main board and expansion board trigger open and close actions when the circuit is closed. I believe they’re designed to support a 3 button control panel Open/Stop/Close. They’re sending voltage all the time … I think. I was really just quickly testing with a multimeter and monkeying with wires for 30 mins, so there may be some crossed wires in my head.
I don’t have a close button in HA working either. However, the Open Cover function does 3 things. It’ll open the gate, pause a moving gate, and close the gate. It’s one button. It may only be appearing as one active button for me because the device isn’t aware of the gate’s state.
Thanks for the tip on the Aux ports. Perhaps they’re the path to a fully functioning cover.
OK. Using the auxiliary relays are definitely an improvement for folks with expansion boards. Below is a table covering the functions of the dip switches on that board’s relays. So, here’s what I did … and it’s important to note that the relays on my expansion board were unused.
I used a single relay on the control board, Relay 1 for me (but it doesn’t matter which) and set the DIP switches to OFF OFF ON. This will send voltage to the right place when the gate hits its open stop limit and close stop limit.
Connected the RatGDO dry contacts like this: Open to NO on the relay 1, Close to NC, and GND to COM.
Connected the RatGDO ‘Red Ctrl to GDO’ to the SBC terminal on the expansion board and connected ‘Wht Gnd’ to the adjacent COM terminal.
This will allow the RatGDO thing to trigger an open action to the gate controller and get open and closed status from the controller, and then refer that info back to HA. You don’t get opening and closing states, but I’ll take this situation over MyQ any day. Also, the “close” function that shows up in the MQTT integrated entity doesn’t work, because it’s Single Button Control. I’m not sure you really need it anyway. You can just use a button card to display the gate entity and the icons will change based on open or closed state. Pretty happy with how this is working.
Edit: It turns out the close function does in fact work. So, even better.
Note that I could have NO and NC switched on what I wrote as I was going from memory. I’m going to verify the NO and NC terminals, rewire SBC and Wht GND and test tomorrow. Was aiming on doing it today but came down sick.
The whole thing seems pretty sensitive to wiring. I was having major issues (i.e. nothing worked) with my first wiring job (using some random braided core 22awg wire off amazon) and finally got at least the open/close sensing working by cutting off the heads of some cat6a cable and using that instead. Wago lever nuts work well for splicing connections.
Ah, you are using the ESPHome firmware instead of MQTT? It seems that officially they say it doesn’t support dry contacts yet, but it can be used for it. I might try it again once I get MQTT fully working.
Alright, I had a bad wire for SBC and once I fixed that, everything works. I had NC and NO for the AUX relays switched around on what I wrote, but edited my initial message to correct that.
This is what works for my CS24UL:
GND - Wired into add-on board Aux Relay 1 AND 2 commons (commons wired together)
@Chmynard - Great to see you were able to get the ratgdo wired up to the LA400.
Thanks for sharing the connection points. Will try wiring up the ratgdo after Christmas.
I tried the wiring suggested. It doesn’t work with 412. What I plan to do is get a 5v relay that can be low triggered. Wire dc+ and - to 5v usb. Wire COM to dc+. Wire signal to yellow wire which goes to 0 when open and put relay on low setting (vs high). Then wire NO to open on RDO and NC to closes on RDO. When open, signal will be low which will switch relay and NO will be energized. Downside is closeness closed it is just not fully open. I may wire 2 relays together so the relays for open and close operate independently
I think this will work and is a $6 part vs buying the expansion board.
Because of the way the relay fires, the RatGDO only updates when the gate is fully open or fully closed. Nothing in the middle. I’m hopeful we can figure that out … someday.
It seems to me that opening and closing are a function of what state it thought it was in and whether either the open or closed port on the ratgo is triggered. So when it opens from close, both inputs shoudl not be triggered and when it gets to open, then open is triggered. I have got it working with the addition of a relay and 1 magnetic switch. I ordered the expansion board as then I don’t need the magnetic switch but the issue is there is no reliable way to get the closed state, it is essentially (NOT OPEN - yellow at > 0 volts) as soon as it starts to close. For a while the voltage is like 5v then 3v but then drops down to 1.xx volt and it doesn’t register with my 5v relay. Maybe I could find a relay that clamps at a lower voltage and remove the magetic switch. In the configuration I have below I get Open, Opening, Closing and Closed.
