This is my take on controlling the heat and warm water.
My conditions:
NIBE 1126 Heatpump without internet connection, not compatible to nibepi or other modbusbased controllers.
Electricity billed by the our.
My nibe heat pump is prepared to take advantage of the SG-ready standard(not implemented in the Swedish grid) its controlled by connecting two potential free relays to the aux input according to the installer manual.(google it)
I use two shelly 1.
based on the level I control the two shelly according to the manual I also included a condition that the house temperature must exceed 18,5 degrees to turn off the heat pump during the expensive ours.
Hi.
Thank you for sharing.
I tired your code creating the 5-step sensor.
Thing is, i get Level 0 sometimes. Looking in my history the sensor never say Level 3.
Looking at the code but canât really say what is wrong here.
I have 2 sensors right now because I tried change the code i little bit but I canât get it working.
ElprisnivÄ_median_today_2 is the sensor in the code above
I would like to calculate the median of prices, not by today or tomorrow but the median from 13.00 today to 13.00 tomorrow.
Is there a way to combine the attributes of today from 13.00 to tomorrow 13.00 and sort them, then calculate the average of attribute (12+ 13+13)/2?
Any ideas how to fix this?
//Erik
That should be possible, unfortunately i donât have much time to look in to it at the moment due to Christmas coming up.
If you find a solution before i do please feel free to share it.
I do like your code, but I feel like I would like to be able to predict the outcome for the day, so including the value 1-5 into price chart (prefer Apex) would be optimal.
Any ideas from vilhelm or anyone else how could it be implemented.
With the 7days average line (stroke width 0) the chart will autoscale it to that max value so I found it more informative, additionally blue line is the 7 day average line.
What iâm looking for is the price level median for each hour. Now I can see only the ongoing one.
I am looking to do something similar with my ordered but not yet delivered Vaillant Heat Pump. Sadly Vaillant doesnât offer much in terms of âsmart featuresâ so I am thinking about using the SG Ready approach with either Shelly or a Homematic IP multi-io box.
So I have done some more âthinkingâ on this topic and since I donât have my heat pump yet I would like to put my current ideas out there and see what you think.
From what I understand, the PV Ready contact on Vaillant Heat Pumps does the following:
It does a quick heat up of the hot water tank
if the contact is still active after that, it heats the âbufferâ for the heater to +X Kelvin above what is normally set.
My idea is to use Solar excess energy in Summer by enabling the relay through a Home Assistant binary sensor. This should put the excess into the hot water tank and hopefully use the remaining energy to run the âcoolingâ mode of the heat pump.
In Winter I would like to use the âcheapest hoursâ from entso/tibber/nordpool (whatever works best) to activate the same program, but what I am wondering is how many hours are best. Since I never owned a heat pump so far I have no experience with thisâŠmy gut feeling tells me 4 hours should work, but that is a very unprofessional way of planning.
At the same time I would set all my room Thermostats to âboost modeâ so that the warm water actually gets circulated around the house.
Does anyone have and thoughts or insight to share concerning this?
Iâm doing the same with my Nibe F1145-10 PC heat pump. The two potential free SG ready contacts are activated based upon availability of my solar energy. However the impact on my Nibe heatpump is pretty low. I see it rises the âS1 supply target temperatureâ, however the âhot water high target temperatureâ is not rised.
How is this working for you? Do you see an immediate reaction of the heatpump when activating the relais? And did you use any specific settings in Nibe?
Interesting, at the moment I donât have any way to monitor the heatpump, iâm thinking about adding a couple of thermometers and monitoring the energy to better understand how to optimize it accordingly to electricity price.
Accordingly to my manual (nibe1126) it should rice the warm-water.
â HĂ€r vĂ€ljer du om temperaturen pĂ„ varmvattnet fĂ„r pĂ„verkas vid aktivering av âSG Readyâ.
Vid lĂ„gprislĂ€ge pĂ„ âSG Readyâ sĂ€tts stopptemperaturen pĂ„ varmvattnet sĂ„ högt som möjligt vid enbart kompressordrift (elpatron tillĂ„ts ej).
Vid överkapacitetslĂ€ge pĂ„ âSG Readyâ sĂ€tts varmvattnet i âlyxâ (elpatron tillĂ„ts).â
Maybe it needs to reach the low threshold temp before it starts producing water and only then allows it to get extra hot?
In that case a bit poor design by nibe in my opinion.
Nice post, I was actually thinking of doing this myself and wanted to check if anyone in home assistant community done this before, surprise surprise there is always someone, so thanks for posting your findings and approach!
For my SMO20 I cant seem to get a straight answer if it can support local control via RS485, but I do have AUX inputs which can be used to trigger SG actions, so going to start thinking about how I can use this along with my variable Octopus tariff to control the heat pump operation more efficiently to my wallet!
Hope to help with the water situation, @tvds - my understanding is that S1 is responsible for climate only not water, so this wonât change the Target and the lows of hot water.
The water high target is effectively set by the Lux/Normal/Economy modes which can be changed in the Water settings which are only accessible via the Advanced config menu (holding back for a few seconds on my unit, yours might be different).
So if you want your Target water temperature to change you would have to setup something like this example:
Standard operating hot water behaviour = Economy Target 40C - Low 38
When you fire an SG event also fire a Lux (boost) event so that temporarily affects your Hot water target temps, then when SG event is off also turn off the Lux (boost) event
In my example and use case, I will need to wire in 3 x Potential Free Shelly Plus 1âs into my AUX inputs:
1 x to trigger Temporary Lux
2 x to trigger the SG events i.e. âSG Ready Aâ and âSG Ready Bâ as listed in the manual.
Again just thoughts, Ive yet to do this at my place but this is my current thinking to the problem.
I just finished code for an ESP32 smart switch that integrates with Home Assistant to switch my Nibe F-1155 into and out of SG Ready mode 1. It obeys the 10 minute state transition rule and it also falls back to normal operating mode if the MQTT broker is unresponsive. Itâs not clear what an effect this will have but I will watch it over a few days. I did notice that mode 2 (Over capacity) turned the pump on immediately and it used a huge amount of power, but I am not sure itâs a good idea to force the pump to turn on. My idea is to push the pump to use excess solar, reducing the nighttime consumption. My carrier fees are substantial, so even if the price of electricity itself is low I still incur cost from the carrier.
