I’m in the same shoes. I missing keypad colour switching. sending text to display and the one you mentioned above. I used all this function on Homeseer, there is paid plugging which I have in VB.
It would be great if someone help to complete this
Long time lurker here. You lot all seem to know your stuff. I wish i could get this working. I have been struggling with adapting this guide to suit Home Assistant Yellow. Put it to me straight, can it even be done?
In the docker container setup all of the file paths are for directories that don’t seem to exist on HASS Yellow.
I have the Russound integration working well with Home Assistant and CAA66.
I would like to add an automation which will switch on a zone from the mini-media player, based on a trigger. I have a working trigger and 30 second delay, but cannot figure out the action.
Could anyone advise an appropriate’Action’ for the automation to turn on a zone name/number?
Thank you
I edited the top post for information on how to create a local add-on and bypass portainer.
I disabled portainer for now on my machine and it works with this new add-on.
Thank you very much biochemguy for your work.
I am trying to use the new non-Portainer method, but HA is not importing the Russound entity info.
The Russound add-on is starting and the log shows that services have successfully started.
In config.yaml, i have tried both
media_player:
- platform: russound_rnet[^2^][2]
host: 127.0.0.1
port: 3333
and also
media_player:
host: 127.0.0.1
port: 3333
but the entities do not show up.
I have also tried replacing 127.0.0.1 with the IP address for the HA, but no success.
I have tried using
dmesg | grep tty
and it shows
usb 1-1.1: pl2303 converter now attached to ttyUSB0
When I go to Settings >>Devices, I see a device called Russound, but it only shows sensors for CPU, memory etc.
I would be very grateful if anyone could help.
Thank you
This is almost great. Except I have 8 zones, via 2 CA4’s (old school). I can only get 6 zones to be found. I’m guessing this is a limitation of the platform (given it was probably written for CA66’s specifically. Anyone know if a hack is available to expand it to cover 8 zones (or more!)?
I think you are on the right track. I noticed that a typo was introduced when I copied the config settings for the add-on how-to. There should not be any weird brackets in the config. It is now fixed.
As for the usb, it is normal to be connected as a ttyusb as this is what makes the serial connection to the russound system.
Your ip address should be 127.0.0.1 as the usb is plugged on your local machine. The russound add-on opens the port 3333 to communicate with home assistant.
I have the same things show up like you when I look at my settings>devices
Check in your settings>devices & services>entities. Your entities should compile as media_player.kitchen or whatever you named them.
Likely… You would have to look at the Rnet protocol or the home assistant interaction with this protocol found here
Thanks @biochemguy , I think you’re right, and I don’t mind having a go at hacking the media_player.py, but I can’t actually find this file on my HA. Should I have this file local that I can edit/play with? (I’m very new to HA, and I’ve just been building dashboards and installing HACS… adding the config.yaml for my Russound was the first ‘backend’ stuff I’ve really had to)
I suspect I’ve exposed my absolute newbie status here… I think the rnet code is embedded in the core HA system, so I probs need to raise a bug report?
I found a fix for this (well, a work-around actually). If you’re using a CA4 controller, you must create blanks for slots 5 and 6, and start the speaker for the linked second controller from slots 7-10.
My config looks like this:
# Russound Speakers
media_player:
host: 192.168.1.104
port: 2401
zones:
1:
2:
3:
4:
name: Bedroom 1 Speaker
# controller 2 - zone 1 (connected via RNET link ports)
5:
6:
7:
name: Patio Right Speaker
8:
name: Patio Left Speaker
9:
10:
sources:
- name: iPod
- name: Radio
- name: CD
- name: XM1
Dear community and the absolute MVP who has created this add-on!
I am a total newbie and have been trying to make this work for at least a month, and need som help.
My setup: RPI 4 running HASS OS + RS232 USB device (checked with PC - reads and writes correctrly) + Russound CAV6.6 connected directrly to RS232 port
What I have tried: portainer method, add-on method, bare Raspbian with this code
The best I’ve got: clean HASS OS install + add-on results in Russound as device identified, shows CPU and RAM usage and OS version (which is correct)
but no zones control or anything else.
My HA Core log shows following:
Error trying to connect to Russound controller.
21:57:29 – (ERROR) components/russound_rnet/media_player.py
Error handling request
21:57:27 – (ERROR) /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py
Any suggestions where to look at?
(also checked:
HASS OS shows RS232 serial adapter on correct USB0
terminal and DMESG | TTY tried already - just gives a full list of devices, no results
multiple reboots and restarts both of Russound and RPI and HA)
would really appreciate any help! this intergration was one of the main goals of RPI purchase
ok, I modified my repository on Github to hopefully fix this issue. simply replace the Dockerfile and config.yaml with the new ones in your folder. Then update the add-on in Home Assistant to the new version. let me know if this works.
omg, it works! huge huge thanks!
