Control Sonos Equalizer via Python script
I have a python script that changes the equalizer settings for one of my Sonos boxes, like Bass volume, Loudness and Treble - it uses the SoCo library, that so far as I know, also Home Assistant itself uses to control Sonos - but it’s somehow not working, I get this error in the Log:
ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `python3 /config/python_scripts/kitchen_silent_mode_on.py`, return code: 1
NoneType: None
This is the Python Script, that works fine on my Mac (after pip install soco):
from soco import SoCo
sonos = SoCo("192.168.178.46")
sonos.bass = -5
sonos.treble = 10
sonos.loudness = False
and that is in my configuration.yaml:
shell_command:
kitchen_silent_mode_on: 'python3 /config/python_scripts/kitchen_silent_mode_on.py'
Does anybody know why it is not working?
I’m interested in this as well. Ideally I would like to be able to control the equalizer setting in lovelace.
I tried this solution and it help get the equalizer settings. Hope this helps
