xaviml
(Xavi Moreno)
December 29, 2019, 7:30pm
41
Hi @MrGinos ,
As I already mentioned in the issue, the LED1624G9 does not have support for “color_temp” attribute and that is the attribute that is meant to use for the arrows on the E1524/E1810. My solution was to provide a xy_color attribute for the lights that do not have the color_temp attribute, but I don’t currently own a lightbulb with xy_color to test it out. I saw that lorek123 offered to try some code, so once I get back to it I will give you both some code to try out.
I can assure you that the app works with the lightbulb LED1732G11 from IKEA, since it does support color_temp. You can also get any lightbulb with brightness and color_temp support, you can check it out in here .
xaviml
(Xavi Moreno)
January 8, 2020, 7:13pm
42
xaviml
(Xavi Moreno)
January 11, 2020, 2:38pm
43
xaviml
(Xavi Moreno)
January 11, 2020, 2:40pm
44
I just released v1.4.0 with support to the Symfonisk controller for light and media player. Check it out and let me know.
xaviml
(Xavi Moreno)
January 17, 2020, 6:04pm
45
xaviml
(Xavi Moreno)
January 18, 2020, 7:03am
46
Hi @swiftlyfalling ,
Thanks for the information you gave me long time ago. In came in handy to get rid off the time.sleep and instead use the self.sleep with async features with AD 4.x
fribse
(Kenneths Teknik)
January 18, 2020, 8:59pm
47
Thankyou, this works really well with my deconz and my ikea remote and WLED light.
Not sure about the color transition yet, can’t find info about the wled integration supports it properly.
xaviml
(Xavi Moreno)
January 18, 2020, 9:15pm
48
Do you get an error on the color transition? Does the WLED light supports xy_color attribute?
fribse
(Kenneths Teknik)
January 18, 2020, 9:42pm
49
Yes I do, and I don’t know, I’m trying to find some info on that
Can you enlighten us @frenck ?
MrGinos
(Gino)
January 25, 2020, 8:44am
50
@fribse maybee a good idea to share your error code here?
xaviml
(Xavi Moreno)
January 26, 2020, 8:11pm
51
v2.1.0 is now released
This minor change does not contain any breaking changes
New devices
Added support for deCONZ in E1743Controller @kalkih
ladaowner
(Ladaowner)
January 29, 2020, 9:15pm
52
how do I get started.
I have HCAS and AppDeamon installed I loaded controllerX.
Do I need “appdaemon: true” in the standard HA configuration.yaml file
Do I need a apps.yaml if so where does this go under appdeaon/apps/controllerx/ and should it contain
bedroom_speaker:
module: controllerx
class: E1744MediaPlayerController
sensor: sensor.symfonisk_controller_action
media_player: media_player.bedroom_speaker
Does it support skip and previous track?
xaviml
(Xavi Moreno)
January 29, 2020, 9:44pm
53
Yes, you need to activate appdaemon to HACS configuration. Either through yaml configuration or through GUI.
Yes, when installing AppDaemon and running it for the first time, you will see an apps.yaml in /config/appdaemon/apps/apps.yaml
Yes, it does. 1 click resumes/pauses. 2 clicks skips forward. 3 clicks skips backward. The same as the original implementation with IKEA hub.
ladaowner
(Ladaowner)
January 30, 2020, 9:07pm
54
2020-01-30 20:52:09.570310 INFO AppDaemon: Initializing app tv_sonos_speaker using class E1744MediaPlayerController from module
controllerx
2020-01-30 20:52:09.572473 WARNING AppDaemon: ------------------------------------------------------------
2020-01-30 20:52:09.572718 WARNING AppDaemon: Unexpected error initializing app: tv_sonos_speaker:
2020-01-30 20:52:09.572877 WARNING AppDaemon: ------------------------------------------------------------
2020-01-30 20:52:09.573328 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/local/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 2051, in check_app_updates
self.init_object(app)
File "/usr/local/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 1567, in init_object
modname = __import__(app_args["module"])
File "/conf/apps/controllerx/controllerx.py", line 14, in <module>
import hassapi as hass
ModuleNotFoundError: No module named 'hassapi'
2020-01-30 20:52:09.573629 WARNING AppDaemon: ------------------------------------------------------------
Any ideas? No HASC just plain old drop files and folders into Appdaemon/conf/
appdeamon.yaml =
log:
logfile: STDOUT
errorfile: STDERR
appdaemon:
threads: 10
plugins:
HASS:
type: hass
ha_url: https://ha.bertybassett.synology.me
token: XXXXXXXXXXXXXXXXXXXXremovedForSecutityReasonsXXXXXXXXXXXXXXXXXXXX
You need at least AppDaemon 4.0.0 for this app, from your config it looks like you are still using version 3.x.x.
ladaowner
(Ladaowner)
January 30, 2020, 9:39pm
56
https://registry.hub.docker.com/r/acockburn/appdaemon/builds?page=1
Is what I loaded, thought it would be version 4?? How do I double check?
Which one exactly? There are quite a few there.
In version 4.0.0 and higher latitude, longitude, time_zone and elevation are mandatory config options in the appdaemon.yaml file.
ladaowner
(Ladaowner)
January 31, 2020, 12:37am
58
I loaded the latest ones as of 2 days ago
ladaowner
(Ladaowner)
January 31, 2020, 1:52am
59
appdaemon:
threads: 10
plugins:
ha_url: REDACTED
ha_key: REDACTED
time_zone: America/Los_Angeles
latitude: REDACTED
longitude: REDACTED
elevation: 116
hadashboard:
dash_url: http://192.168.0.21:5050
dashboard_dir: /conf/dashboards
ladaowner
(Ladaowner)
January 31, 2020, 2:07am
60
2020-01-30 18:06:14.403976 INFO AppDaemon: Removing module /conf/apps/hello.py
2020-01-30 18:06:14.405260 INFO AppDaemon: Removing module /conf/apps/controllerx/controllerx.py
2020-01-30 18:06:14.405907 INFO AppDaemon: Terminating tv_sonos_speaker
2020-01-30 18:06:42.521834 INFO AppDaemon: Loading App Module: /conf/apps/controllerx/controllerx.py
2020-01-30 18:06:42.537387 INFO AppDaemon: Initializing app tv_sonos_speaker using class E1744MediaPlayerController from module
controllerx
2020-01-30 18:06:42.539179 WARNING tv_sonos_speaker: ------------------------------------------------------------
2020-01-30 18:06:42.539960 WARNING tv_sonos_speaker: Unexpected error initializing app: tv_sonos_speaker:
2020-01-30 18:06:42.540770 WARNING tv_sonos_speaker: ------------------------------------------------------------
2020-01-30 18:06:42.541613 WARNING tv_sonos_speaker: Traceback (most recent call last):
File "/usr/local/lib/python3.8/site-packages/appdaemon/app_management.py", line 820, in check_app_updates
await self.init_object(app)
File "/usr/local/lib/python3.8/site-packages/appdaemon/app_management.py", line 279, in init_object
"object": app_class(
File "/usr/local/lib/python3.8/site-packages/appdaemon/plugins/hass/hassapi.py", line 46, in __init__
adbase.ADBase.__init__(self, ad, name, logging, args, config, app_config, global_vars)
File "/usr/local/lib/python3.8/site-packages/appdaemon/adbase.py", line 75, in __init__
self.dashboard_dir = self.AD.http.dashboard_dir
AttributeError: 'NoneType' object has no attribute 'dashboard_dir'
2020-01-30 18:06:42.542050 WARNING tv_sonos_speaker: ------------------------------------------------------------
2020-01-30 18:06:42.542900 WARNING AppDaemon: Unable to find module tv_sonos_speaker - initialize() skipped
