asonkel
February 19, 2024, 11:47am
21
I also want to control my pool heatpump locally through a MQTT server, and found this nice solution. But I have some problems with the *.yaml file(errors during compiling).
Can someone explain which content is required in the *.yaml file, especially te the Wifi and MQTT parameters ?
I tried to copy the parameters from @deepstahl77 but with his parameters I receive errors during compiling.
And in the original Github project there are no Wifi/MQTT parameters remarked
I tried following configuration in a YAML Validator, and it seems to be that there are no errors.(Wifi/MQTT parameters need to be adjusted).
esphome:
friendly_name: IPS 170 ESP
esp8266: null
board: d1_mini_pro
wifi:
ssid: MyHomeNetwork
password: VerySafePassword
captive_portal: null
# Example configuration entry
mqtt:
broker: 10.0.0.2
username: livingroom
password: !secret mqtt_password
web_server:
port: 80
uart:
rx_pin: RX
tx_pin: TX
baud_rate: 9600
modbus:
modbus_controller:
- id: fairland
address: 1
modbus_id: modbus1
update_interval: 2s
switch:
- platform: modbus_controller
modbus_controller_id: fairland
name: PWP Power Switch
register_type: coil
address: 0
select:
name: PWP Operating Mode
address: 0
value_type: U_WORD
optionsmap:
Auto: 0
Heating: 1
Cooling: 2
name: PWP Power Mode
address: 1
value_type: U_WORD
optionsmap:
Super Silence: 2
Silence: 1
Normal: 0
Turbo: 3
number:
name: PWP Target Temperature Heating
address: 3
value_type: U_WORD
unit_of_measurement: °C
min_value: 18
max_value: 32
lambda: return (x-96) / 2 + 18;
write_lambda: |-
ESP_LOGD("main", "Modbus Number incoming value = %f", x);
return ((x-18) * 2 + 96) * 1.0;
name: PWP Target Temperature Auto
register_type: holding
address: 2
value_type: U_WORD
min_value: 18
max_value: 32
write_lambda: |-
name: PWP Target Temperature Cooling
address: 4
value_type: U_WORD
min_value: 18
max_value: 32
write_lambda: |-
name: PWP Speed Percentage
register_type: read
address: 0
value_type: U_WORD
unit_of_measurement: "%"
name: “Voltage of PFC”
register_type: read
address: 2
value_type: U_WORD
unit_of_measurement: “V”
name: PWP Inlet water Temperature
register_type: read
address: 3
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: PWP Outlet water Temperature
register_type: read
address: 4
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: PWP Ambient Air Temperature
register_type: read
address: 4
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: PWP Compressor Current
register_type: read
address: 11
value_type: U_WORD
unit_of_measurement: A
filters:
- multiply: 0.1
name: PWP Compressor Running Frequency
register_type: read
address: 10
value_type: U_WORD
unit_of_measurement: Hz
name: PWP Compressor Power
unit_of_measurement: W
lambda: |-
if (id(pwp_compressor_current).state) {
return id(pwp_compressor_current).state * id(voltage_of_pfc).state;
} else {
return 0.0;
update_interval: 1s
binary_sensor:
name: PWP Error E0
register_type: discrete_input
address: 48
device_class: PROBLEM
name: PWP Error E1 - High Pressure Protection
address: 49
name: PWP Error E2 Low Pressure Protection
address: 50
name: PWP Warning E3 No Water Protection
address: 51
name: PWP Error E4 3 phase sequence protection
address: 52
name: PWP Warning E5 Power Supply Excesses Operation Range
address: 53
name: PWP Warning E6 Insufficient Water Flow
address: 54
name: PWP Error E7 Water Outlet Temp too high or too low
address: 55
name: PWP Error E8 High Exhaust Temp Protection
address: 56
name: PWP Error E9
address: 57
name: PWP Error EA Evaporator overheat protection
address: 58
name: PWP Warning EB Ambient Temperature too high or too low
address: 59
name: PWP Error EC
address: 60
name: PWP Warning ED Anti-Freezing Reminder
address: 61
name: PWP Error EF
address: 62
name: PWP Error P0 Controller Communication Failure
address: 64
name: PWP Error P1 Water Inlet Temp Sensor Failure
address: 65
name: PWP Error P2 Water Outlet Temp Sensor Failure
address: 66
name: PWP Error P3 Gas Exhaust Temp Sensor Failure
address: 67
name: PWP Error P4 Evaporator Coil Pipe Temp Sensor Failure
address: 68
name: PWP Error P5 Gas Return Temp Sensor Failure
address: 69
name: PWP Error P6 Cooling Coil Pipe Temp Sensor Failure
address: 70
name: PWP Error P7 Ambient Temp Sensor Failure
address: 71
name: PWP Error P8 Cooling Plate Sensor Failiure
address: 72
name: PWP Error P9 Current Sensor Failure
address: 73
name: PWP Error PA Restart Memory Failure
address: 74
name: PWP Error PB
address: 75
name: PWP Error PC
address: 76
name: PWP Error PD
address: 77
name: PWP Error PE
address: 78
name: PWP Error PF
address: 79
name: PWP Error F0
address: 80
name: PWP Error F1 Compressor Drive Module Failure
address: 81
name: PWP Error F2 PFC Module Failure
address: 82
name: PWP Error F3 Compressor Start Failure
address: 83
name: PWP Error F4 Compressor Running Failure
address: 84
name: PWP Error F5 Inverter Board Over Current Protection
address: 85
name: PWP Error F6 Inverter Board Over Temperature Protection
address: 86
name: PWP Error F7 Current Protection
address: 87
name: PWP Error F8 Cooling Plate Overheat Protection
address: 88
name: PWP Error F9 Fan Motor Failure
address: 89
name: PWP Error FA PFC Module Over Current Protection
address: 90
name: PWP Error FB Power Filter Plate No-Power Protection
address: 91
name: PWP Error FC
address: 92
name: PWP Error FD
address: 93
name: PWP Error FE
address: 94
name: PWP Error FF
address: 95
Syon
February 22, 2024, 1:44pm
22
Do you found a solution? I’ve a Protoss (RS485 to LAN) which I wants to use.
rstcologne
(Richard Stevens)
February 23, 2024, 8:44am
23
Can you share the error message, please?
rstcologne
(Richard Stevens)
February 23, 2024, 8:52am
24
With the LAN adapter, I think it’s better to use the MQTT module in home assistant. There should not be the need for an ESP and ESP-Home.
Below is an example of how I set up home assistant to communicate with my solar inverter via Modbus over LAN. First block is the communication setup. Here you’d configure your Modbus to LAN adapter. After that you add the modbus registers. I believe the syntax is identical to the one used in ESP-Home but haven’t tried it.
modbus:
- name: Sungrow
type: tcp
host: !secret sungrow_modbus_host_ip_wr5
port: !secret sungrow_modbus_port
delay: 1
timeout: 1
sensors:
- name: WR5 Daily PV Generation
unique_id: wr5_daily_pv_generation
slave: !secret sungrow_modbus_slave
address: 5002 # reg 5003
input_type: input
data_type: uint16
#swap: byte
precision: 1
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
scale: 0.1
scan_interval: 600
hatolkai
(Hatolkai)
March 2, 2024, 5:22pm
25
Hi All,
I’m trying to bring this solution to life, but rather with less success than more.
I have an ESP32 and a MAX485 TTL to RS485
I keep getting these CRC Check Failed errors.
Any idea what am doing wrong?
PS: noob here
INFO ESPHome 2024.2.1
INFO Reading configuration /config/esphome/med-hsz-esp.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing med-hsz-esp (board: esp32dev; framework: arduino; platform: platformio/[email protected] )
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/med-hsz-esp/src/main.cpp.o
Linking .pioenvs/med-hsz-esp/firmware.elf
RAM: [= ] 12.5% (used 41012 bytes from 327680 bytes)
Flash: [===== ] 53.9% (used 989649 bytes from 1835008 bytes)
Building .pioenvs/med-hsz-esp/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/med-hsz-esp/firmware.bin"], [".pioenvs/med-hsz-esp/firmware.elf"])
Wrote 0x103060 bytes to file /data/build/med-hsz-esp/.pioenvs/med-hsz-esp/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 17.27 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.0.165
INFO Uploading /data/build/med-hsz-esp/.pioenvs/med-hsz-esp/firmware.bin (995424 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 12.44 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.0.165 using esphome API
INFO Successfully connected to med-hsz-esp @ 192.168.0.165 in 7.313s
INFO Successful handshake with med-hsz-esp @ 192.168.0.165 in 0.264s
[18:13:47][I][app:102]: ESPHome version 2024.2.1 compiled on Mar 2 2024, 18:13:11
[18:13:47][C][wifi:577]: WiFi:
[18:13:47][C][wifi:409]: Local MAC: 08:D1:F9:E7:54:A8
[18:13:47][C][wifi:414]: SSID: 'TP-Link_1F87'[redacted]
[18:13:47][C][wifi:415]: IP Address: 192.168.0.165
[18:13:47][C][wifi:417]: BSSID: 34:60:F9:6B:1F:87[redacted]
[18:13:47][C][wifi:418]: Hostname: 'med-hsz-esp'
[18:13:47][C][wifi:420]: Signal strength: -80 dB ▂▄▆█
[18:13:47][C][wifi:424]: Channel: 4
[18:13:47][C][wifi:425]: Subnet: 255.255.255.0
[18:13:47][C][wifi:426]: Gateway: 192.168.0.1
[18:13:47][C][wifi:427]: DNS1: 0.0.0.0
[18:13:47][C][wifi:428]: DNS2: 0.0.0.0
[18:13:47][C][logger:447]: Logger:
[18:13:47][C][logger:448]: Level: DEBUG
[18:13:47][C][logger:449]: Log Baud Rate: 115200
[18:13:47][C][logger:451]: Hardware UART: UART1
[18:13:47][C][uart.arduino_esp32:137]: UART Bus 0:
[18:13:47][C][uart.arduino_esp32:138]: TX Pin: GPIO1
[18:13:47][C][uart.arduino_esp32:139]: RX Pin: GPIO3
[18:13:47][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[18:13:47][C][uart.arduino_esp32:143]: Baud Rate: 9600 baud
[18:13:47][C][uart.arduino_esp32:144]: Data Bits: 8
[18:13:47][C][uart.arduino_esp32:145]: Parity: NONE
[18:13:47][C][uart.arduino_esp32:146]: Stop bits: 1
[18:13:47][D][modbus_controller:043]: Modbus command to device=1 register=0x03 countdown=0 no response received - removed from send queue
[18:13:47][C][modbus:143]: Modbus:
[18:13:47][C][modbus:144]: Flow Control Pin: GPIO4
[18:13:47][C][modbus:145]: Send Wait Time: 250 ms
[18:13:47][C][modbus:146]: CRC Disabled: NO
[18:13:47][C][modbus.number:083]: modbus.numberModbus Number 'PWP Target Temperature Heating'
[18:13:47][C][modbus.number:083]: modbus.number Unit of Measurement: '°C'
[18:13:47][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:47][C][modbus.number:083]: modbus.numberModbus Number 'PWP Target Temperature Auto'
[18:13:47][C][modbus.number:083]: modbus.numberModbus Number 'PWP Target Temperature Cooling'
[18:13:47][C][template.sensor:022]: Template Sensor 'PWP Compressor Power'
[18:13:47][C][template.sensor:022]: State Class: ''
[18:13:47][C][template.sensor:022]: Unit of Measurement: 'W'
[18:13:47][C][template.sensor:022]: Accuracy Decimals: 1
[18:13:47][C][template.sensor:023]: Update Interval: 1.0s
[18:13:47][C][modbus_controller:298]: ModbusController:
[18:13:47][C][modbus_controller:299]: Address: 0x01
[18:13:47][C][modbus_controller.switch:068]: modbus_controller.switchModbus Controller Switch 'PWP Power Switch'
[18:13:47][C][modbus_controller.switch:091]: modbus_controller.switch Restore Mode: disabled
[18:13:47][C][modbus_controller.select:009]: modbus_controller.selectModbus Controller Select 'PWP Operating Mode'
[18:13:47][C][modbus_controller.select:009]: modbus_controller.selectModbus Controller Select 'PWP Power Mode'
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Speed Percentage'
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensor State Class: ''
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: '%'
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 0
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Inlet water Temperature'
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: '°C'
[18:13:47][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Outlet water Temperature'
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 0
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Ambient Air Temperature'
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensor State Class: ''
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: '°C'
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Compressor Current'
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: 'A'
[18:13:48][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'PWP Compressor Running Frequency'
[18:13:48][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: 'Hz'
[18:13:48][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFD
[18:13:48][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E0'
[18:13:48][C][modbus_controller.binary_sensor:009]: Device Class: 'problem'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E1 - High Pressure Protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E2 Low Pressure Protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Warning E3 No Water Protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E4 3 phase sequence protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Warning E5 Power Supply Excesses Operation Range'
[18:13:48][W][modbus:108]: Modbus CRC Check failed! 4040!=DFFF
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Warning E6 Insufficient Water Flow'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E7 Water Outlet Temp too high or too low'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E8 High Exhaust Temp Protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error E9'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error EA Evaporator overheat protection'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Warning EB Ambient Temperature too high or too low'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error EC'
[18:13:48][W][modbus:108]: Modbus CRC Check failed! 8047!=FFFF
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Warning ED Anti-Freezing Reminder'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error EF'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P0 Controller Communication Failure'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P1 Water Inlet Temp Sensor Failure'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P2 Water Outlet Temp Sensor Failure'
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P3 Gas Exhaust Temp Sensor Failure'
[18:13:48][D][modbus_controller:043]: Modbus command to device=1 register=0x0A countdown=0 no response received - removed from send queue
[18:13:48][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P4 Evaporator Coil Pipe Temp Sensor Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P5 Gas Return Temp Sensor Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Device Class: 'problem'
[18:13:49][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P6 Cooling Coil Pipe Temp Sensor Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P7 Ambient Temp Sensor Failure'
[18:13:49][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P8 Cooling Plate Sensor Failiure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error P9 Current Sensor Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PA Restart Memory Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PB'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PC'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PD'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PE'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error PF'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F0'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F1 Compressor Drive Module Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F2 PFC Module Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F3 Compressor Start Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F4 Compressor Running Failure'
[18:13:49][W][modbus:108]: Modbus CRC Check failed! D041!=FFFF
[18:13:49][W][modbus:108]: Modbus CRC Check failed! 8101!=FFFF
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F5 Inverter Board Over Current Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F6 Inverter Board Over Temperature Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F7 Current Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F8 Cooling Plate Overheat Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error F9 Fan Motor Failure'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FA PFC Module Over Current Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FB Power Filter Plate No-Power Protection'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FC'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FD'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FE'
[18:13:49][C][modbus_controller.binary_sensor:009]: Modbus Controller Binary Sensor 'PWP Error FF'
[18:13:50][C][modbus_controller.binary_sensor:009]: Device Class: 'problem'
[18:13:50][C][captive_portal:088]: Captive Portal:
[18:13:50][C][web_server:168]: Web Server:
[18:13:50][C][web_server:169]: Address: 192.168.0.165:80
[18:13:50][C][mdns:115]: mDNS:
[18:13:50][C][mdns:116]: Hostname: med-hsz-esp
[18:13:50][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:50][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:50][C][ota:096]: Over-The-Air Updates:
[18:13:50][C][ota:097]: Address: 192.168.0.165:3232
[18:13:50][C][ota:100]: Using Password.
[18:13:50][C][ota:103]: OTA version: 2.
[18:13:50][C][api:139]: API Server:
[18:13:50][C][api:140]: Address: 192.168.0.165:6053
[18:13:50][C][api:142]: Using noise encryption: YES
[18:13:50][D][modbus_controller:043]: Modbus command to device=1 register=0x00 countdown=0 no response received - removed from send queue
[18:13:51][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:51][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:51][D][modbus_controller:043]: Modbus command to device=1 register=0x30 countdown=0 no response received - removed from send queue
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFB
[18:13:52][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 4040!=FFDF
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFC
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 8641!=FFFF
[18:13:52][W][modbus:108]: Modbus CRC Check failed! 4040!=FBFF
[18:13:53][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:53][D][modbus_controller:043]: Modbus command to device=1 register=0x40 countdown=0 no response received - removed from send queue
[18:13:53][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:53][W][modbus:108]: Modbus CRC Check failed! 8081!=FDFF
[18:13:53][W][modbus:108]: Modbus CRC Check failed! 4040!=FF7F
[18:13:53][W][modbus:108]: Modbus CRC Check failed! D041!=FFFF
[18:13:54][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:54][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:54][D][modbus_controller:043]: Modbus command to device=1 register=0x00 countdown=0 no response received - removed from send queue
[18:13:55][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFE
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 4040!=DFFF
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 8011!=FFFF
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 80E1!=FFFF
[18:13:55][W][modbus:108]: Modbus CRC Check failed! 9841!=FFFF
[18:13:55][D][modbus_controller:043]: Modbus command to device=1 register=0x00 countdown=0 no response received - removed from send queue
[18:13:56][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:57][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:57][W][modbus:108]: Modbus CRC Check failed! 41C0!=FFFF
[18:13:57][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:57][W][modbus:108]: Modbus CRC Check failed! 8101!=FFFF
[18:13:57][W][modbus:108]: Modbus CRC Check failed! 47C0!=FFFF
[18:13:57][W][modbus:108]: Modbus CRC Check failed! 4040!=BFFF
[18:13:57][W][component:214]: Component modbus took a long time for an operation (0.11 s).
[18:13:57][W][component:215]: Components should block for at most 20-30ms.
[18:13:58][W][modbus:108]: Modbus CRC Check failed! 4040!=FFFF
[18:13:58][W][modbus:108]: Modbus CRC Check failed! 4040!=FFF7
[18:13:58][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
[18:13:58][W][modbus:108]: Modbus CRC Check failed! E041!=FFFF
[18:13:58][D][modbus_controller:043]: Modbus command to device=1 register=0x00 countdown=0 no response received - removed from send queue
[18:13:58][W][modbus:108]: Modbus CRC Check failed! 804D!=FFFF
[18:13:59][D][sensor:094]: 'PWP Compressor Power': Sending state nan W with 1 decimals of accuracy
rstcologne
(Richard Stevens)
March 2, 2024, 6:35pm
26
The error seems to be with compressor power. Are you getting the other values? Maybe the your board is different? Just guessing here though.
Does it work if you remove the entry for compressor power from the config?
@rstcologne did you use/copy register/coils from the domoticz-post?
I recently bought a pool inverter that came also across with a second RS485 socket and i’ve tried to use those registers/coils via usb RTU (for testing). Unfortunatly only holding registers work, but the results do not match anything from this domoticz-article.
Is there a way to find out correct registers, maybe with sniffing what that tuya-device is doing over RS485 - or do i have to contact the vendor - what might be nearly impossible - to find a modbus-register-table.
rstcologne
(Richard Stevens)
March 5, 2024, 6:20pm
28
For me, copying the registers worked. I also contacted the vendor just in case and received a reply really quickly. The document received didn’t uncover anything new though.
Honestly I’m not too experienced with Modbus. I suppose you could program something that queries everything or try sniffing but I’m of no help with that. Sorry.
sorry for my late response
I use a windows machine, I followed the instructions for installation step by step as described at: Installing ESPHome Manually — ESPHome
and this guide at youtube: https://www.youtube.com/watch?v=BX6tDsux_X4
The installation was sucessfull but when I try to run my esp.yaml file I receive error message(see below)
C:\esp>esphome run esp.yaml
INFO ESPHome 2023.12.9
INFO Reading configuration esp.yaml...
Failed config
esphome: None
expected a dictionary.
I only want to create from *.yaml a binary file which I can flash to my wemos board.
rstcologne
(Richard Stevens)
March 7, 2024, 11:47am
30
Your latest message prompted me to look into your yaml again. Even though it’s valid yaml, I believe you have a syntax error (with respect to the syntax ESPHome expects).
You have this at the start:
esp8266: null
board: d1_mini_pro
Can you try this instead:
esp8266:
board: d1_mini_pro
Make sure the line with board is indented the same way as other indentations.
I also don’t really understand why you try to compile manually. I suppose you have a home assistant instance somewhere. I find it much easier to use the ESP-Home environment in the HA UI to do the configurations, compile in the browser and then flash with Esphome flasher:
Just build in the UI with manual download selected and then use the flasher tool to flash.
No offense please, there might be valid reasons for you to do it the way you try to do it.
yes, the *yaml file I use is without “null” comands … but errors still available.
The whole backround of my intention is that I have a pool heatpump which I want to integrate in my smarthome via MQTT (Iobroker) or locally via WebIF(ESP board) and not through the integrated WLAN controller of the Pool heatpump into the internet.
I don´t have any ESPHome or Homeassistant system running.
I just installed it locally for compiling/flashing my ESP board, I thought this would be the best solution with minimum of expense instead of installing and configuring bigger toolings.
But it seems that I was wrong
Hello everyone,
This is my first post
I tried to connect my unbranded heat pump which has a MWH298-V2 2017.04.21 card
It’s almost the same card used by deepstahl77 but the XH - connector is not present and the red DIP switch configuration is also different.
I’m using an ESP8266 AZDelivery, a DC-DC Buck Converter 4.5-28V and a Hailege TTL to RS485 485 to Serial UART.
ESP is online but there are no sensor data available
I tried almost everything : hardware_uart: UART0_SWAP, hardware_uart: UART0, increase modbus update_interval…
Everything failed
After some email exchange with Fairland, I have to change the PC board…
Elwell
(Andrew Elwell)
April 29, 2024, 2:09am
34
We’ve just had one of these (Madimack InverEco branded) units installed - Still waiting for sparky to commission it tomorrow but had a dig inside. Ours has a MWH298 V2.1 pcb, with the modbus connector broken out to the external wifi module. it looks like the connector they use on wifi is AHUA 4 pin M12 series - still to be measured fully and see if I can grab some from ebay, This manufacturer product seems to be similar.
The Wifi module itself is a tuya WBR1 with an antenna on the front face of the package. Looks like it has a clone of an STM32F030C8 ARM M0 cpu onboard - that’s the model with 2 uarts, so I’m guessing one is modbus, the other talks to tuya. Strangely the PCB has the ‘wifi’ LED and a push button in the moddle, but there’s also 3 LEDs on the side that aren’t visible through the case. Googling for ‘MCH302’ (pcb screenprint) or ‘AWY40D’ (part number on back) didn’t bring anything interesting
I don’t have a 3D printer, so may try and make my interface version fit in their case - might be a challenge.
Photos if it’s of help to others at https://photos.app.goo.gl/UTgzzrPRBTL56rtm8 - see also the “Mr Silence full pool heater” thread
rsonke
(Rob)
May 5, 2024, 10:21am
35
Hi all, I’ve been working on dropping my local Tuya config for an Esphome based control too. Your code @rstcologne has been of great help.
I’ve used devices from M5Stack, which saves you the soldering and just use out of the box solutions.
I’ve used a M5Stickc with an RS485 hat (which has a 12v-5v converter inside):
M5StickC is a mini M5Stack, powered by ESP32. It is a portable, easy-to-use, IoT development board. The open source code & engineering communities that will help you maximize your benefits in every step of the developing process Internet of...
Price: USD 9.95
RS485 HAT SKU:U067 Description RS485-HAT is a TTL to RS485 converter for M5StickC. Among M5stack products we have 5 items that include TTL to RS485, they are RS485 unit, RS485 HAT, PLC, LAN, BASE26 they have different input voltage, vary from 5V -...
Price: USD 4.50
Most of the yaml is identical, I’ve just included it for future reference for others. Main difference is in the m5stickc config and the gpio ports:
esphome:
friendly_name: pool-fairland-heatpump
substitutions:
ip: !secret pool_heatpump_ip
<<: !include .common.yaml
esp32:
board: m5stick-c
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
level: INFO
#level: VERBOSE #makes uart stream available in esphome logstream
uart:
tx_pin: GPIO0
rx_pin: GPIO26
baud_rate: 9600
data_bits: 8
stop_bits: 1
parity: NONE
# debug:
# direction: BOTH
# dummy_receiver: false
# after:
# delimiter: "\n"
# sequence:
# - lambda: UARTDebug::log_string(direction, bytes);
modbus:
modbus_controller:
- id: fairland
## the Modbus device addr
address: 0x0001
modbus_id: modbus1
update_interval: 5s
light:
# Built-in Red Status LED Light. See https://esphome.io/components/light/status_led.html
- platform: status_led
restore_mode: ALWAYS_OFF
pin:
number: GPIO10
inverted: true
# Built-in buttons. See https://esphome.io/components/button/
# binary_sensor:
# - platform: gpio
# pin:
# number: GPIO37
# inverted: true
# id: button_a
# name: Button A
# - platform: gpio
# pin:
# number: GPIO39
# inverted: true
# id: button_b
# name: Button B
# Built-in infrared transmitter. See https://esphome.io/components/remote_transmitter.html
# and https://m5stack.hackster.io/alessandro-polselli/turn-m5stickc-into-universal-ir-remote-home-automation-d3ec0d
remote_transmitter:
pin: GPIO9
carrier_duty_percent: 50%
# sensor:
# - platform: axp192
# address: 0x34
# i2c_id: bus_a
# model: M5STICKC
# update_interval: 30s
# battery_level:
# name: "Battery Level"
# id: "battery_level"
spi:
clk_pin: GPIO13
mosi_pin: GPIO15
i2c:
- id: bus_a
sda: GPIO21
scl: GPIO22
scan: True
# Fonts
font:
- file: "gfonts://Roboto"
# builtin 80x160 TFT
display:
- platform: st7735
model: "INITR_MINI160X80"
cs_pin: GPIO5
dc_pin: GPIO23
reset_pin: GPIO18
device_height: 80
device_width: 160
row_start: 1
col_start: 1
rotation: 270
update_interval: 2s
lambda: |-
it.print(80, 0, id(roboto), TextAlign::TOP_CENTER, "M5Stickc Fairland Pool - Modbus");
# Elements with Modbus Operation read 01 / write 05
# coil
# 0 Power
# 1 compulsory defrosting
# 2~47 reserve
switch:
icon: "mdi:power"
register_type: coil
address: 0x0
# Elements with Modbus Operation read 03 / write 06
# holding
# address content Range Unit Step length Defaut Illustration
# 0 mode selection 1 0~2 0:Auto,1:Heating,2:Cooling
# 1 mode selection 2 0~3 1 1 0:Normal,1:silence,2:Super silence, 3: Turbo
# 2 Temp setting under Auto mode 18~35 ℃ 1 25
# 3 Temp setting under heating mode
# 4 Temp setting under cooling mode 30~95 % 1 50
# 5 Running mode of water pump 0~2 1 0 "0:Continuation
# 1:Water temp control
# 2:time/water temp control
# 6 Time setting of water pump (When under running mode 2) 10 ~ 120 min 5 60
# 7 The compressor runs continuously before defrosting enters 20~90 min 1 20
# 8 Defrosting start temp -10~10 ℃ 1 -1
# 9 Defrosting running time 1~12 min 1 8
# 10 Defrosting quit temp 0~30 ℃ 1 8
# 11 Fixed speed mode selection
# 12 reserve
# 13 reserve
# 14 Low temperature shutdown protection correction amount
# 12 reserve
# 13 reserve
# 17 Electronic expansion valve overheat level(heating) -10~20 ℃ 1 3
# 18 Electronic expansion valve overheat level(cooling) -10~20 ℃ 1 3
# 19 Electronic expansion valve manual/auto 0~1 1 0 0:auto,1:Manual
# 20 Electronic expansion valve openning setting(heating) 50~240 2 100
# 21 Electronic expansion valve openning setting(cooling) 50~240 2 100
# 22 The medium frequency ratio selection
# 23 reserve
# 24 reserve
# 25 Power off memory function 0~1 1 1 0: None; 1: Yes
# 26 reserve
# 27 reserve
# 28 reserve
# 29 reserve
# 30 reserve
# 31 reserve
# 32 reserve
select:
icon: "mdi:fan"
address: 0x0
value_type: U_WORD
optionsmap:
"Auto": 0
"Heating": 1
"Cooling": 2
icon: "mdi:fan"
address: 0x1
value_type: U_WORD
optionsmap:
"Super Silence": 2
"Silence": 1
"Normal": 0
"Turbo": 3
# Temperature Formula
# ((value - 96) / 2) + 18
number:
name: "Target Temperature Heating"
icon: "mdi:sun-thermometer-outline"
address: 0x3
value_type: U_WORD
unit_of_measurement: "°C"
min_value: 18
max_value: 32
lambda: "return (x-96) / 2 + 18;"
write_lambda: |-
name: "Target Temperature Auto"
icon: "mdi:thermometer-auto"
address: 0x2
value_type: U_WORD
min_value: 18
max_value: 32
write_lambda: |-
name: "Target Temperature Cooling"
icon: "mdi:snowflake-thermometer"
address: 0x4
value_type: U_WORD
min_value: 18
max_value: 32
write_lambda: |-
# Elements with Modbus Operation read 04 / write NA
# read
# 0 Percentage of speed
# 1 Target frequency of compressor
# 2 Voltage of PFC
# 3 Inlet water temp
# 4 Outlet water temp
# 5 Ambient air temp
# 6 Dircharge temp
# 7 Outer coil pipe temp
# 8 Suction temp
# 9 Inner coil pipe tem
# 10 Running frequency of compressor
# 11 Current of compressor
# 12 Cooling plate temp
# 13 Electronic expansion valve opening
# 14 DC fan speed
# 15 Lower limit of setting temp of auto mode
# 16 Upper limit of setting temp of auto mode
# 17 Lower limit of setting temp of heating mode
# 18 Upper limit of setting temp of heating mode
# 19 Lower limit of setting temp of cooling mode
# 20 Upper limit of setting temp of cooling mode
# 21 Motherboard version code1 ASCII code
# 22 Motherboard version code2 ASCII code
# 23 Motherboard version code3 ASCII code
# 24 Motherboard version code4 ASCII code
# 25 Motherboard version code5 ASCII code
# 26 Model code1 ASCII code
# 27 Model code2 ('C'is heating and cooling version,‘H’is heating version) ASCII code
# 28 Model code3 ASCII code
# 29 Model code4 ASCII code
# 30 Voltage of power supply V 1
# 31 The remaining time of Compressor shutdown protection S 1
# 32 reserve
name: "Speed Percentage"
icon: "mdi:fan-speed-1"
register_type: read
address: 0x0
value_type: U_WORD
name: "Voltage of PFC"
icon: "mdi:flash-triangle"
register_type: read
address: 0x2
value_type: U_WORD
unit_of_measurement: "V"
name: "Inlet water Temperature"
icon: "mdi:thermometer-chevron-up"
register_type: read
address: 0x3
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: "Outlet water Temperature"
icon: "mdi:thermometer-chevron-down"
register_type: read
address: 0x4
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: "Ambient Air Temperature"
icon: "mdi:home-thermometer-outline"
register_type: read
address: 0x5
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
icon: "mdi:sine-wave"
register_type: read
address: 11
value_type: U_WORD
unit_of_measurement: "A"
filters:
- multiply: 0.1
name: "Compressor Running Frequency"
icon: "mdi:repeat-variant"
register_type: read
address: 10
value_type: U_WORD
unit_of_measurement: "Hz"
icon: "mdi:lightning-bolt"
unit_of_measurement: "W"
lambda: |-
if (id(compressor_current).state) {
return id(compressor_current).state * id(voltage_of_pfc).state;
} else {
return 0.0;
update_interval: 1s
# Elements with Modbus Operation read 02 / write NA
# discrete_input
# 0 Switch on/off
# 1 Defrosting
# 2 Temperature adjustment
# 3 Silence
# 4 Anti-freeze
# 5 Cooling mode selection
# 6 Remote controll
# 7 Water flow swtich
# 8 High pressure swtich
# 9 Low pressure swtich
# 10 Compressor
# 11 Outdorr fan motor
# 12 4-Way valve
# 13 Bypass valve
# 14 reserve
# 15 Heating element in the basis
# 16 reserve
# 17 Circulation pump
# 17~47 reserve
# 48 E0
# 49 E1
# 50 E2
# 51 E3
# 52 E4
# 53 E5
# 54 E6
# 55 E7
# 56 E8
# 57 E9
# 58 EA
# 59 EB
# 60 EC
# 61 ED
# 62 EE
# 63 EF
# 64 P0
# 65 P1
# 66 P2
# 67 P3
# 68 P4
# 69 P5
# 70 P6
# 71 P7
# 72 P8
# 73 P9
# 74 PA
# 75 PB
# 76 PC
# 77 PD
# 78 PE
# 79 PF
# 80 F0
# 81 F1
# 82 F2
# 83 F3
# 84 F4
# 85 F5
# 86 F6
# 87 F7
# 88 F8
# 89 F9
# 90 FA
# 91 FB
# 92 FC
# 93 FD
# 94 FE
# 95 FF
binary_sensor:
icon: "mdi:check-circle"
address: 48
name: "Error E1 - High Pressure Protection"
address: 49
name: "Error E2 Low Pressure Protection"
address: 50
name: "Warning E3 No Water Protection"
address: 51
name: "Error E4 3 Phase Sequence Protection"
address: 52
name: "Warning E5 Power Supply Excesses Operation Range"
address: 53
name: "Warning E6 Insufficient Water Flow"
address: 54
name: "Error E7 Water Outlet Temp too high or too low"
address: 55
name: "Error E8 High Exhaust Temp Protection"
address: 56
address: 57
name: "Error EA Evaporator overheat protection"
address: 58
name: "Warning EB Ambient Temperature too high or too low"
address: 59
address: 60
name: "Warning ED Anti-Freezing Reminder"
address: 61
address: 62
name: "Error P0 Controller Communication Failure"
address: 64
name: "Error P1 Water Inlet Temp Sensor Failure"
address: 65
name: "Error P2 Water Outlet Temp Sensor Failure"
address: 66
name: "Error P3 Gas Exhaust Temp Sensor Failure"
address: 67
name: "Error P4 Evaporator Coil Pipe Temp Sensor Failure"
address: 68
name: "Error P5 Gas Return Temp Sensor Failure"
address: 69
name: "Error P6 Cooling Coil Pipe Temp Sensor Failure"
address: 70
name: "Error P7 Ambient Temp Sensor Failure"
address: 71
name: "Error P8 Cooling Plate Sensor Failiure"
address: 72
name: "Error P9 Current Sensor Failure"
address: 73
name: "Error PA Restart Memory Failure"
address: 74
address: 75
address: 76
address: 77
address: 78
address: 79
address: 80
name: "Error F1 Compressor Drive Module Failure"
address: 81
name: "Error F2 PFC Module Failure"
address: 82
name: "Error F3 Compressor Start Failure"
address: 83
name: "Error F4 Compressor Running Failure"
address: 84
name: "Error F5 Inverter Board Over Current Protection"
address: 85
name: "Error F6 Inverter Board Over Temperature Protection"
address: 86
name: "Error F7 Current Protection"
address: 87
name: "Error F8 Cooling Plate Overheat Protection"
address: 88
name: "Error F9 Fan Motor Failure"
address: 89
name: "Error FA PFC Module Over Current Protection"
address: 90
name: "Error FB Power Filter Plate No-Power Protection"
address: 91
address: 92
address: 93
address: 94
address: 95
Hi, I have the same PCB as you. Did you manage to get the PCB with the blue connector?
Thank you
Thank you @rstcologne and @deepstahl77 for detailed explanation.
I have successfully upgraded a Pool-Systems IPS-90 (which do not had a Wi-Fi module before) using a ESP 8266 D1 mini. The only pitfall was, that the UART0 is occupied with the USB connector and I was not able to ‘share’ the TX,RX with the logger somehow. I decided to use the I2C connectors instead (using the UART software emulation):
uart:
rx_pin: GPIO4
tx_pin: GPIO5
#rx_pin: RX
#tx_pin: TX
baud_rate: 9600
Thomas - @deepstahl77 - could you please share you latest snipped of your lovelace implementation?
Regards
Sascha
Elwell
(Andrew Elwell)
May 28, 2024, 4:17am
38
We have a ‘madimack’ branded version of these - I’ve successfully got the sensor readings polling with a lilygo t-can485 (WIP, Will post to github once I have the holding registers pulled in (most likely as diagnostics). What I have discovered with this is that you need to make sure you add force_new_range: true at the specified read intervals (ie address 3,6,9,12 on the read registers) or you’ll get CRC errors
EDIT: My config’s available at GitHub - Elwell/pool-heatpump: ESPhome based control for a madimack branded pool heatpump
Hi all
I have a new Fairland X20-40CT, pne heck of a machine.
Wouldnt it be the easiest option to just buy a Waveshare RS485 to LAN Adapter and attach it to the heatpump?
Then setup MQTT…
Or is it not possible? Anyone tried?
Dominik
Does anyone know if this works with the Evolution Proline from Poolmegastore ? It also uses the Tuya app and is cheaper than the ips line. According to the docs it also has RS485 interfaces.
