Controlling a Fairland Pool Heatpump eliminating Tuya
Hey community,
I spent quite some time to get my pool heatpump integrated with tuya local and local tuya but wasn’t really happy with the outcome.
Inspired by user enboer sharing a direct interface with domoticz, I set about doing something similar with esphome.
This is the outcome in the dashboard:
Errors can also be shown:
It all starts on the main control board which is easily accessible:
B and A are the RS 485 headers and the connector even provides 12V power for the ESP.
After a bit of prototyping…
I came up with this:
At the top is the connector, stays within the enclosure. Middle left is a small stepdown converter to get from 12V to 5V for the ESP. On the right is a MAX485 based RS485 interface. At the bottom you see a custom board I use for ESPHome projects someone shared on PCBWay. I flash the 12E/12F module and then solder it to the board, OTA from there.
Next was an enclosure:
The electronics are placed in there, the boards separated by two of the H-shaped spacers. Once the box is screwed closed, two holders are attached wich allow clipping it to the heated water out pipe at the back of the machine. The cable comes out at the bottom, so humidity should not be too much of an issue. I’ll add a TPU based seal later.
I plan to add the files on github later. So far I’m really happy with the results and best of all, I can elminiate the tuya cloud. Also directly communicating with modbus unlocked a “super silent” mode which is not available via the hardware user interface or the tuya based app.
One note on compatibility. I have an IPS pro by Poolsystems which seems to be identical or very similar to the Inver X from Fairland directly. These heatpumps seem to be sold under many different brands. At least for my model, you can add the feature to control it via app. It looks like all they do is ship the unit with a different controller which is in box separate from the main controller. At least this is where the WIFI module is located as inside the metal enclosure of the heatpump, there would be very little reception. It looks like the main control board is the same with or without wifi support. My guess is, one could buy the cheaper option without app and make it smart with the solution described above.
I already have ideas to improve my solution. The M5 stack tough seems to fit in the space of the current UI box. Moving the original box to the inside or disconnecting it entirely I could use the M5stack to control the pump manually adding things like presets or other advanced things.
Hi Richard, just got a Fairland Heatpump and am super interested to try this out.
Hey,
cool. Good luck. Sorry for the delay. Life got in the way :slight_smile:
I have uploaded everything to github:
https://github.com/rstcologne/ESP-Home-Fairland-Heatpump
If you do go ahead and implement it, I’d appreciate some feedback if the description is good enough to follow along.
UPDATE: Just noticed, the esphome conifg was an empty file. Fixed now.
@rstcologne: When I browse to your Github using the above link, I get a 404 error. It also does not show up on your Github project page. Did you remove it?
My bad. I’m not very experienced with GitHub and accidentally left the repo private. It should work now.
Thanks for the work!
I have a HF2211 RS485 to Wifi/Ethernet device that I am using to control my Vistapool swimming controller (see Vistapool Integration). Can I use the same device to connect to the Fairland Inver-X? I would think this is possible as RS485 is a bus system. The wiring would look like this (Device 1: Vistapool, Device 2: Fairland):
Does anyone have experience with this?
Have you tried the Aqua Temp application together with the HA integration?
Retrieves a lot of sensor information, including controls and switches and works with all wi-fi modules based on tuya. I personally tried it on Hayward, AstralPool heat pumps with the same type of wi-fi module.
No, never used AquaTemp. If I understand correctly, it would also require external accounts to work which then need to be integrated into HA with a custom integration. While this might be an option which works perfectly fine, personally I’m really happy with the very direct integration without dependencies to something outside of my network. The aquatemp approach sounds like there are more components involved which have the potential to cause problems when HA evolves.
But thanks for mentioning it here as it might be a more stable solution than tuya local and local tuyya and more suitable for people who don’t want to open their heatpump and fiddle around with the controlboard.
By the way, my ESPHome Device also retrieves more sensor information than actually used in the dashboard.
I will definitely try your version, especially since I already have all the components from previous projects and I don’t mind sticking my nose in the heat pump.
Sooooo, I’ve tried your solution and …sorry…failed. Don’t know why. I’m using HA since April this year for all of my smart devices (meross, tuya, sonoff ect.). For my energy management (photovoltaic) i’m using a tasmota smart meter reader (DIY interface by bitShake) and one ESP Home interface for some relais. So, I’m actually stuck in the topic.
Actually, i’m using the “Tuya local” integration for my heating pump. (NOT “Local Tuya”!!!) but NOW wanted to decouple it from the Tuya cloud AND the WIFI-Adapter given by Pool-Systems/Fairland
What I’ve done: bought similar devices like Richard:
  1. AZDelivery NodeMCU Amica Modul V2 ESP8266 ESP-12F WiFi - Node MCU ESP 8266 WiFi Development Board with CP2102
  2. DC-DC Buck Converter 4.5-28V bis 0.8-20V MP1584EN Mini Step Down adjustable converter
  3. JST-XH Premium 3S 4Pin 20cm Balancer-cable
  4. Hailege TTL to RS485 485 to Serial UART Level Reciprocal Hardware Automatic Flow Control UART to RS485 Converter RS485 to TTL
Annotation: The DC-DC buck converter was first used for down regulation from 12V to 5V (measured by a multimeter)…but then i decied better to use first a normal 5V power adapter for the ESP 8266 power connection to eliminate an errorsource. Soldered them all in the same way as Richard (see images)
My heating pump is an IPS 170 full inverter heating pump by pool-systems (similar to all of the fairland devices and to Richard’s :-)). And yes…there exist this “B A G +12V” interface for the original wifi-adapter…to be used as DIY connection.
Approach:
  1. installation of a new ESP Home device called “ISP 170”; (ESPHome version 2023.8.2)
  2. I´ve copied Richard’s code below the " captive_portal" (yes, only once in the hole script)
  3. install/flash via USB
    → good WIFi connection according to the log-file; ESP-Home integration status “online”
  4. → settings/devices&services/add integration with the correct IP Adress and the API code given by the ESP Home integration (three dots) → fine
  5. after some time (at first …for a long time “N/A”, then restarted HA etc.) i was able to push e.g. the power switch. Nothing happend at the heating pump. silent/boost buttons & Temperature slider available (auto/cooling/heating) but without any effect when pushed in HA.
conclusion: “B” and “A” from the RS485 to the heating pump circuit board seem to be connected correctly (black and white cable of the JST-XH adapter). The power adapter 5V is connected to the ESP8266. Rx, Tx, GND and 3V3 from ESP 8266 connected to RxD, TxD, VCC and GND at the RS485. By the way…the RS485 onboard-LED glows red.
esphome:
friendly_name: IPS 170 ESP
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxx"
ota:
platform: esphome         # <-- since update ESPhome 2024.06.04
password: "xxxxxxxxxxxxxxxxxx"
wifi:
ssid: "xxxxxxxxxx"
password: "xxxxxxxxxxxxx"
# Optional manual IP
manual_ip:
static_ip: 192.168.178.68
gateway: 192.168.178.1
subnet: 255.255.255.0
captive_portal:
web_server:
port: 80
uart:
rx_pin: RX
tx_pin: TX
baud_rate: 9600
modbus:
# flow_control_pin: GPIO4
modbus_controller:
- id: fairland
## the Modbus device addr
address: 0x0001
modbus_id: modbus1
update_interval: 2s
# Elements with Modbus Operation read 01 / write 05
# coil
# 0 Power
# 1 compulsory defrosting
# 2~47 reserve
switch:
- platform: modbus_controller
modbus_controller_id: fairland
name: "PWP Power Switch"
register_type: coil
address: 0x0
# unit_of_measurement: "State"
# Elements with Modbus Operation read 03 / write 06
# holding
# address content Range Unit Step length Defaut Illustration
# 0 mode selectioin 1 0~2 0:Auto,1:Heating,2:Cooling
# 1 mode selectioin 2 0~3 1 1 0:Normal,1:silence,2:Super silence, 3: Turbo
# 2 Temp setting under Auto mode 18~35 ℃ 1 25
# 3 Temp setting under heating mode
# 4 Temp setting under cooling mode 30~95 % 1 50
# 5 Running mode of water pump 0~2 1 0 "0:Continuation
# 1:Water temp control
# 2:time/water temp control
# 6 Time setting of water pump (When under running mode 2) 10 ~ 120 min 5 60
# 7 The compressor runs continuously before defrosting enters 20~90 min 1 20
# 8 Defrosting start temp -10~10 ℃ 1 -1
# 9 Defrosting running time 1~12 min 1 8
# 10 Defrosting quit temp 0~30 ℃ 1 8
# 11 Fixed speed mode selection
# 12 reserve
# 13 reserve
# 14 Low temperature shutdown protection correction amount
# 12 reserve
# 13 reserve
# 17 Electronic expansion valve overheat level(heating) -10~20 ℃ 1 3
# 18 Electronic expansion valve overheat level(cooling) -10~20 ℃ 1 3
# 19 Electronic expansion valve manual/auto 0~1 1 0 0:auto,1:Manual
# 20 Electronic expansion valve openning setting(heating) 50~240 2 100
# 21 Electronic expansion valve openning setting(cooling) 50~240 2 100
# 22 The medium frequency ratio selection
# 23 reserve
# 24 reserve
# 25 Power off memory function 0~1 1 1 0: None; 1: Yes
# 26 reserve
# 27 reserve
# 28 reserve
# 29 reserve
# 30 reserve
# 31 reserve
# 32 reserve
select:
name: "PWP Operating Mode"
address: 0x0
value_type: U_WORD
optionsmap:
"Auto": 0
"Heating": 1
"Cooling": 2
name: "PWP Power Mode"
address: 0x1
value_type: U_WORD
optionsmap:
"Super Silence": 2
"Silence": 1
"Normal": 0
"Turbo": 3         # <---- this is not working for me :-( depends on the fairland model
# Temperature Formula
# ((value - 96) / 2) + 18
number:
name: "PWP Target Temperature Heating"
address: 0x3
value_type: U_WORD
unit_of_measurement: "°C"
min_value: 18
max_value: 40
lambda: "return (x-96) / 2 + 18;"
write_lambda: |-
ESP_LOGD("main", "Modbus Number incoming value = %f", x);
return ((x-18) * 2 + 96) * 1.0;
name: "PWP Target Temperature Auto"
register_type: holding
address: 0x2
value_type: U_WORD
min_value: 18
max_value: 40
write_lambda: |-
name: "PWP Target Temperature Cooling"
address: 0x4
value_type: U_WORD
min_value: 18
max_value: 40
write_lambda: |-
# Elements with Modbus Operation read 04 / write NA
# read
# 0 Percentage of speed
# 1 Target frequency of compressor
# 2 Voltage of PFC
# 3 Inlet water temp
# 4 Outlet water temp
# 5 Ambient air temp
# 6 Dircharge temp
# 7 Outer coil pipe temp
# 8 Suction temp
# 9 Inner coil pipe tem
# 10 Running frequency of compressor
# 11 Current of compressor
# 12 Cooling plate temp
# 13 Electronic expansion valve opening
# 14 DC fan speed
# 15 Lower limit of setting temp of auto mode
# 16 Upper limit of setting temp of auto mode
# 17 Lower limit of setting temp of heating mode
# 18 Upper limit of setting temp of heating mode
# 19 Lower limit of setting temp of cooling mode
# 20 Upper limit of setting temp of cooling mode
# 21 Motherboard version code1 ASCII code
# 22 Motherboard version code2 ASCII code
# 23 Motherboard version code3 ASCII code
# 24 Motherboard version code4 ASCII code
# 25 Motherboard version code5 ASCII code
# 26 Model code1 ASCII code
# 27 Model code2 ('C'is heating and cooling version,‘H’is heating version) ASCII code
# 28 Model code3 ASCII code
# 29 Model code4 ASCII code
# 30 Voltage of power supply V 1
# 31 The remaining time of Compressor shutdown protection S 1
# 32 reserve
name: "PWP Speed Percentage"
register_type: read
address: 0x0
value_type: U_WORD
unit_of_measurement: "%"
name: "PWP Inlet water Temperature"
register_type: read
address: 0x3
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: "PWP Outlet water Temperature"
register_type: read
address: 0x4
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: "PWP Ambient Air Temperature"
register_type: read
address: 0x4
value_type: U_WORD
filters:
- offset: -96
- multiply: 0.5
- offset: 18
name: "PWP Compressor Current"
register_type: read
address: 11
value_type: U_WORD
unit_of_measurement: "A"
filters:
- multiply: 0.1
name: "PWP Compressor Running Frequency"
register_type: read
address: 10
value_type: U_WORD
unit_of_measurement: "Hz"
name: "PWP Compressor Power"
unit_of_measurement: "W"
lambda: |-
if (id(pwp_compressor_current).state) {
return id(pwp_compressor_current).state * 230;
} else {
return 0.0;
update_interval: 1s
# Elements with Modbus Operation read 02 / write NA
# discrete_input
# 0 Switch on/off
# 1 Defrosting
# 2 Temperature adjustment
# 3 Silence
# 4 Anti-freeze
# 5 Cooling mode selection
# 6 Remote controll
# 7 Water flow swtich
# 8 High pressure swtich
# 9 Low pressure swtich
# 10 Compressor
# 11 Outdorr fan motor
# 12 4-Way valve
# 13 Bypass valve
# 14 reserve
# 15 Heating element in the basis
# 16 reserve
# 17 Circulation pump
# 17~47 reserve
# 48 E0
# 49 E1
# 50 E2
# 51 E3
# 52 E4
# 53 E5
# 54 E6
# 55 E7
# 56 E8
# 57 E9
# 58 EA
# 59 EB
# 60 EC
# 61 ED
# 62 EE
# 63 EF
# 64 P0
# 65 P1
# 66 P2
# 67 P3
# 68 P4
# 69 P5
# 70 P6
# 71 P7
# 72 P8
# 73 P9
# 74 PA
# 75 PB
# 76 PC
# 77 PD
# 78 PE
# 79 PF
# 80 F0
# 81 F1
# 82 F2
# 83 F3
# 84 F4
# 85 F5
# 86 F6
# 87 F7
# 88 F8
# 89 F9
# 90 FA
# 91 FB
# 92 FC
# 93 FD
# 94 FE
# 95 FF
binary_sensor:
name: "PWP Error E0"
register_type: discrete_input
address: 48
device_class: PROBLEM
name: "PWP Error E1 - High Pressure Protection"
address: 49
name: "PWP Error E2 Low Pressure Protection"
address: 50
name: "PWP Warning E3 No Water Protection"
address: 51
name: "PWP Error E4 3 phase sequence protection"
address: 52
name: "PWP Warning E5 Power Supply Excesses Operation Range"
address: 53
name: "PWP Warning E6 Insufficient Water Flow"
address: 54
name: "PWP Error E7 Water Outlet Temp too high or too low"
address: 55
name: "PWP Error E8 High Exhaust Temp Protection"
address: 56
name: "PWP Error E9"
address: 57
name: "PWP Error EA Evaporator overheat protection"
address: 58
name: "PWP Warning EB Ambient Temperature too high or too low"
address: 59
name: "PWP Error EC"
address: 60
name: "PWP Warning ED Anti-Freezing Reminder"
address: 61
name: "PWP Error EF"
address: 62
name: "PWP Error P0 Controller Communication Failure"
address: 64
name: "PWP Error P1 Water Inlet Temp Sensor Failure"
address: 65
name: "PWP Error P2 Water Outlet Temp Sensor Failure"
address: 66
name: "PWP Error P3 Gas Exhaust Temp Sensor Failure"
address: 67
name: "PWP Error P4 Evaporator Coil Pipe Temp Sensor Failure"
address: 68
name: "PWP Error P5 Gas Return Temp Sensor Failure"
address: 69
name: "PWP Error P6 Cooling Coil Pipe Temp Sensor Failure"
address: 70
name: "PWP Error P7 Ambient Temp Sensor Failure"
address: 71
name: "PWP Error P8 Cooling Plate Sensor Failiure"
address: 72
name: "PWP Error P9 Current Sensor Failure"
address: 73
name: "PWP Error PA Restart Memory Failure"
address: 74
name: "PWP Error PB"
address: 75
name: "PWP Error PC"
address: 76
name: "PWP Error PD"
address: 77
name: "PWP Error PE"
address: 78
name: "PWP Error PF"
address: 79
name: "PWP Error F0"
address: 80
name: "PWP Error F1 Compressor Drive Module Failure"
address: 81
name: "PWP Error F2 PFC Module Failure"
address: 82
name: "PWP Error F3 Compressor Start Failure"
address: 83
name: "PWP Error F4 Compressor Running Failure"
address: 84
name: "PWP Error F5 Inverter Board Over Current Protection"
address: 85
name: "PWP Error F6 Inverter Board Over Temperature Protection"
address: 86
name: "PWP Error F7 Current Protection"
address: 87
name: "PWP Error F8 Cooling Plate Overheat Protection"
address: 88
name: "PWP Error F9 Fan Motor Failure"
address: 89
name: "PWP Error FA PFC Module Over Current Protection"
address: 90
name: "PWP Error FB Power Filter Plate No-Power Protection"
address: 91
name: "PWP Error FC"
address: 92
name: "PWP Error FD"
address: 93
name: "PWP Error FE"
address: 94
name: "PWP Error FF"
address: 95
see Richrd’s [esphome_snippet.yaml]
What should I do? :frowning:
It’s a bit hard to see on the photos but i think you need to swap the rx and Tx wires on the esp.
Unfortunately no, they are connected correctly (but I also twisted it…just for fun…no effect). I ran the ESP installation again (took aprox 5 min). ESP is online but there are no sensor data available (e.g. PWP speed percentage). e.g. PWP power switch is available but no reaction at the heating pump when pushed.
Here are the data from fairyland for MY board (MWH298-V2 2018.03.26). :slightly_smiling_face:
Yeahhhhhh. It’s working fine now. There was no hardware problem…after reading some scripts regarding “modbus” I’ve found the failure. I had to add this to my ESP-Home yaml
Enable logging
logger:
hardware_uart: UART0_SWAP
Now it’s working and all of the sensors are really nice.
Remark: don’t forget to unplug the original wifi-adapter. Otherwise you will risk a “shot circuit” or a “loop”.
It’s a pity that you can’t select a “thermostat template” for the dashboard. It’s just not a “climate” entity. And for “sensors” you can’t use ist…any ideas? The template for my softub looks nice.
My Dashboard from the evening. The heating pump is currently not running
That’s great to hear!
It’s also bugging me a bit, that so far I have not figured out how to make this into a climate entity. I tried, couldn’t figure it out and then just built the dashboard with regular elements. Guess I’ll get back to it over winter when the nights are long :slight_smile:
After two weeks of usage …everything is still working…very well :slight_smile:
Thank you very much . After few days it works for me . Mainly I wait for HW to come from shop. At first I ordered another type of TTL2RS485 board. I doesn’t work . So I decided to buy very similar to yours. It has TX and RX LED. I helps me a lot. And reading logfile !!! I am using ESP32 board , and it uses logging on standard RX,TX ( GPIO1 &3 ). When I did change output to GPIO16&17 it works . Thanks again for your work.
P.S. Right now I am waiting for ESP32 board with connector for external antenna to have better wifi signal.
I am trying to add to your code also other entities ( like reading/setting defrosting etc. ) .
Just quick correction for now. You are calculating Actual power = Actual current * 230V. That is not correct. Because it is inverter, it is not using 230V internally . There is inverter inside . It uses PFC Voltage.
Just
add following code
  • platform: modbus_controller
    name: “Voltage of PFC”
    register_type: read
    address: 0x2
    value_type: U_WORD
    unit_of_measurement: “V”
will give you actual voltage , and correct following code
  • platform: template
    name: “PWP Compressor Power”
    unit_of_measurement: “W”
    lambda: |-
    return id(pwp_compressor_current).state * id(voltage_of_pfc).state;
    } else {
    return 0.0;
    update_interval: 1s
    At least for me , is is much more accurate. I have HW power meter for my heatpump. After correction , it is accurate ±5%.
Oh, very cool! Thanks for this correction.
UPDATE: Fix is now included in the github repository
Hi guys.
I found other mistake.
Ambient temperature , address should be 0x5 not 0x4 . Probably just typo during copy .
Anyway , it is not measuring incoming air correctly. For my situation , it is showing 4 degrees less than reality. I am not sure , where that temperature sensor is installed , maybe it is measuring outgoing air temperature. I will measure it in next days . Right now I am 10km away, connected remotely. I have two other thermometers , which shows higher temperature.
I tried to setup everything the way @rstcologne and @deepstahl77 did.
However the RS485 Converter only lights up one LED and the ESP is sending Data to the Controller Board. The Controller Board never sends anything back. I have a MWH298-V2.1 Board.
Does it matter if the heatpump is installed properly? Right now its not installed yet and I wanted to test the ESPHome Modbus Implementation.
“hardware_uart: UART0_SWAP” didn’t help.
Did anybody else have that issue?
