Controlling Growatt inverter
I have a Growatt SPH3600 hybrid inverter. I have installed the Growatt integration, which has created 2 devices and 37 entities, which are all sensors. What I need to do is to inspect and change the settings of the inverter (e.g. to see when it is set to charge the battery from the grid, to what charge level, etc. and to change these things). How do I do this?
Thank you - Rowan
I havent tried the Growatt integration (I think it integrates with the openAPI) and wanted something local to control my Growatt inverters. I opted for Solar Assistant and have wonderful control over settings and stats. If you dont come right, its worth checking out - Configuring Growatt SPH inverter
I use the raspberry pi with Solar assistant to manage the BMS of my batteries and control my 2 Growatt inverters via MQTT - I then use Home Assistant to automate settings depending on Solar forecast for the next day, “load Shedding” and any other power monitoring requirements.
Can both HA and Solar Assistant run on the same Raspberry Pi? How?
Thank you - Rowan
Hey there,
I am using grott to get data from my growatt Inverter. Unfortunately pushing different setting doesnt work for my.
Does Solar Assistant allow changing setting, like Charge battery from grid when price is low?
I dont think so. I have a dedicated Pi for Solar Assistant
Yes, you can make changes directly from Solar Assistant, or via HA via the MQTT integration depending on the rules or automations you create.
