I’m passing the battery state over to HA via MQTT. One of the attributes is the charging status, and to grab this I’m using the following without issues:
sensors:
ls_charge_tablet:
friendly_name: "Tablet Charge State"
value_template: >-
{{ states.sensor.tablet_lstablet_ls_battery_sensor.attributes.charging_state }}
This creates a sensor that returns a value of charging / discharging. However, I’d prefer to convert this to a binary sensor if at all possible. This would need to return on/true when the state is ‘charging’ and false/off at other times.
I can’t work out how to do this despite looking at HA docs for binary template sensors. Any assistance would be greatly appreciated.
tom_l
September 28, 2019, 11:20am
2
binary_sensor:
sensors:
ls_charge_tablet:
value_template: "{{ state_attr('sensor.tablet_lstablet_ls_battery_sensor', 'charging_state') == 'charging' }}"
Thanks, that works perfectly.
xbmcnut
(xbmcnut)
March 4, 2020, 12:32am
4
I’m trying to do a similar thing with the Android app but getting no data with the following template. Stole the config from my opengarage yaml.
nokia_charging_state:
friendly_name: Nokia Charging State
value_template: '{% if states.sensor.nokia_battery_level %}
{% if states.sensor.nokia_battery_level.attributes["is_charging"] == "false" %}
No
{% elif states.sensor.nokia_battery_level.attributes["is_charging"] == "true" %}
Yes
{% endif %}
{% endif %}'
icon_template: >
'{%- if is_state('sensor.nokia_charging_state', 'Yes') -%}mdi:battery-charging-high{% else %}mdi:battery-medium{%- endif -%}'
Can you spot what I’m doing wrong? Sensor reports as true or false in states panel.
xbmcnut
(xbmcnut)
March 4, 2020, 1:22am
5
FYI, I’ve also tried this which reports false even though it should be true.
{% if is_state('states.sensor.nokia_battery_level.attributes.charger_type', 'AC') %} True
{% else %} False
{% endif %}
It’s generally considered bad form to resurrect and old forum thread with a new question. You’ll have much more chance of getting help with your issue if you open a new thread.
xbmcnut
(xbmcnut)
March 5, 2020, 10:26am
7
Thanks. I’ll make sure I do that in the morning.
tom_l
March 5, 2020, 10:55am
8
Good advice for next time.
While I’m here I might as well show what I think should work, and what I think you were trying to do:
entity_id: sensor.nokia_battery_level
value_template: >
{% if not states('sensor.nokia_battery_level') == 'undefined' %}
{% if state_attr('sensor.nokia_battery_level', 'is_charging') %}
Yes
{% else %}
No
{% endif %}
{% else %}
Undefined
{% endif %}
icon_template: >
{% if is_state('sensor.nokia_charging_state', 'Yes') %}
{% else %}
mdi:battery-medium
{% endif %}
xbmcnut
(xbmcnut)
March 10, 2020, 9:06am
9
Hey thanks for that. No wonder I couldn’t figure it out!! Testing now. Appreciate your input as always.
