How to convert an 3 state Homematic window sensor into 2 state binary_sensor?
I get crazy to modify a Homematic window Sensor Typ HM-Sec-RHS-2 into a binary sensor.
I think I need to do so that I can use it in my sensor group.
I tried already
but I get no state. I think is is related that the HM Sensor can have 3 state.
0 = CLOSED should be OFF
1 = TILTED should be ON
2 = OPEN should be ON
Can someone guide me how to modify this?
in the meantime I tried several codes, still no success.
Below 2 Ideas, has nobody a hint for me?
template:
  - binary_sensor:
      - name: Balkontuer_Drehgriffsensor
        state: >
          {{ is_state('sensor_wz_terrassentuer.CLOSED', "off")
             or is_state('sensor_wz_terrassentuer.tilted', "on")
             or is_state('sensor_wz_terrassentuer.OPEN', "on") }}
      - friendly_name: Balkontuer_Drehgriffsensor
        value_template  "{% if is_state('sensor_wz_terassentuer', 'CLOSED') %}off
                         {% elif is_state('sensor_wz_terrassentuer', 'TILTED') %}on
                         {% elif is_state('sensor_wz_terrassentuer', 'OPEN') %}on
                         {% endif %}"
I don’t know where you find your coding samples, but that should work:
{{ not is_state('sensor.wz_terrassentuer', "CLOSED") }}
Hi, I entered in /config/configuration.yaml
template:
  - binary_sensor:
        state: >
It doesn matter if the window is open or closed, I get always “True” in the Template Editor or “on” in Zustand
Try ´closed´ (lowercase)
template:
  - binary_sensor:
        state: >
          {{ not is_state('sensor.wz_terrassentuer', "closed") }}
still no change. I get from sensor.wz_terassentuer CLOSED or OPEN but the binary_sensor.balkontuer_drehgriffsensor stay always at “on”
This is working code from my environment:
template:
  - name: Türgriffkontakt KU
    unique_id: "tuergriffkontakt_ku"
    device_class: "door"
    state: >
      {{ not is_state('sensor.turgriffkontakt_ku', 'closed') }}
Replace “closed” with the relevant return type of your sensor.
Hi, finally it works with
template:
  - binary_sensor:
        state: >
          {{ not is_state('sensor.wz_terassentuer_state', "CLOSED") }}
thanks for you patience :slight_smile:
