Howdy, So I am new to Home Assistant, but not to home automation. Been around for more than 15 years or so, with the last about 10 years in Z-Wave mess…
While digging around to figure out a challenge I seem to have with lights turning on, though they was just turned off, I stumbled onto my “system core logg”, and after the last restart (however I had this before, I just did not pay any attention), I seem to have a bit of a challenge to something - can anyone point me in the right direction?
File "/usr/local/lib/python3.9/site-packages/pysyncthru/__init__.py", line 69, in update
self.data = await self._current_data()
File "/usr/local/lib/python3.9/site-packages/pysyncthru/__init__.py", line 94, in _current_data
raise SyncThruAPINotSupported(
pysyncthru.SyncThruAPINotSupported: Invalid host, does not support SyncThru JSON API.
2022-02-21 22:37:09 WARNING (MainThread) [homeassistant.components.automation.hotelknapp] Hotelknapp: Already running
2022-02-21 22:37:24 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall light.toggle (c:e0670887b94d40677129ba9dee2167f3): area_id=['sovrum'], params=>
File "/usr/src/homeassistant/homeassistant/core.py", line 1648, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1667, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 668, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 705, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 518, in async_handle_toggle_service
await async_handle_light_off_service(light, call)
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 513, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/zwave_js/light.py", line 287, in async_turn_off
await self._async_set_brightness(0, kwargs.get(ATTR_TRANSITION))
File "/usr/src/homeassistant/homeassistant/components/zwave_js/light.py", line 337, in _async_set_brightness
await self.info.node.async_set_value(
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node.py", line 478, in async_set_value
result = await self.async_send_command(
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node.py", line 435, in async_send_command
result = await self.client.async_send_command(message, **kwargs)
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/client.py", line 103, in async_send_command
return await future
zwave_js_server.exceptions.FailedZWaveCommand: Z-Wave error 204: Failed to send the command after 3 attempts (Status NoAck) (ZW0204)
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547415506080] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547397543200] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547425397104] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414316944] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547407505008] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414316224] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414112816] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414113776] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547419883168] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414499280] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414497168] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547419880032] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547420421856] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547414388944] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 02:09:25 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547415504880] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547415522608] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547403338416] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547456045696] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547397250544] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547458125936] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547538223792] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547415387968] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547415422576] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547397629024] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547419983632] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547420873392] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547413857184] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547458216144] Disconnected: Did not receive auth message within 10 seconds
2022-02-23 04:09:56 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547455923440] Disconnected: Did not receive auth message within 10 seconds
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
2022-02-23 11:32:28 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/reboot request Server disconnected
2022-02-23 11:32:28 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /host/reboot -
[finish] process exit code 0
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-02-23 11:47:06 ERROR (MainThread) [frontend.js.latest.202202031] :0:0 ResizeObserver loop completed with undelivered notifications.
2022-02-23 11:47:08 ERROR (MainThread) [frontend.js.latest.202202031] :0:0 ResizeObserver loop completed with undelivered notifications.
2022-02-23 11:47:09 ERROR (MainThread) [frontend.js.latest.202202031] :0:0 ResizeObserver loop completed with undelivered notifications.
2022-02-23 11:47:12 ERROR (MainThread) [frontend.js.latest.202202031] :0:0 ResizeObserver loop completed with undelivered notifications.
2022-02-23 11:47:13 ERROR (MainThread) [frontend.js.latest.202202031] :0:0 ResizeObserver loop completed with undelivered notifications.
