Core update 2024.2.0 broke all cloud based custom integrations
Help,
I don’t know what’s happening but the latest core update (2024.2.0) broke all my custom cloud based integrations (iCloud3, weather.com, Imou Life and AstroWeather).
I really don’t know what’s happening nor what to do. I tried everything, i restored HA from a previous backup with core 2024.1.6, which was working just fine… nothing, I tried reinstalling and reconfiguring the custom integrations and still nothing. Anyone else has encountered this issue?
I’m running HAOS on a raspberry Pi 4B.
These are the logs from one of the custom components:
Logger: homeassistant.setup
Source: setup.py:251
First occurred: 17:31:22 (1 occurrences)
Last logged: 17:31:22
Setup failed for custom integration 'weatherdotcom': Unable to import component: No module named 'custom_components.weatherdotcom.coordinator'
  File "/usr/src/homeassistant/homeassistant/setup.py", line 251, in _async_setup_component
    component = integration.get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 827, in get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 994, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/weatherdotcom/__init__.py", line 11, in <module>
    from .coordinator import WeatherUpdateCoordinator, WeatherUpdateCoordinatorConfig
ModuleNotFoundError: No module named 'custom_components.weatherdotcom.coordinator'
Looks like the custom integration is the problem. Have you rolled back, removed the custom integration then upgraded without the integration installed?
I believe there are CLI commands that can be used to remove a broken integration from an broken upgrade, however I don’t know what they are. Perhaps try a search on this news group to see if anything shows up.
If a custom integration is failing, take it up on the integrations GitHub.
