Correct image aspect ratio for Android Notifications
Something I have been struggling with for a while is getting my camera notification images to display correctly on my phone. The image from my camera is in a 4:3 ratio and android crops the image to 2:1 ratio in the notification and I often lose the parts of an image where people enter and exit the view.
The camera_proxy has some image resizing options, however they dont do exactly what I need. so I started there and modified the crop/resize function and have come up with this. it creates a new black image of the desired aspect ratio and pastes in the original image. essentially padding the image, the idea being that the whole image is visible in the notification but with a black bar on the side or bottom
def _pad_2to1ratio(image, opts):
    """Pad image to 2:1 ratio"""
    try:
        img = _precheck_image(image, opts)
    except ValueError:
        return image
    quality = opts.quality or DEFAULT_QUALITY
    (old_width, old_height) = img.size
	old_size = len(image)
    if old_width == (2 * old_height):
        _LOGGER.debug("Image is correct ratio")
        return image
    elif old_width > (2 * old_height):
        result = Image.new(img.mode, (old_width, old_width / 2), (0, 0, 0))
        result.paste(img, (0, (old_width - old_height) / 2))
    else:
        result = Image.new(img.mode, (old_height * 2, old_height), (0, 0, 0))
        result.paste(img, ((old_height * 2 - old_width) / 2, 0))
    imgbuf = io.BytesIO()
	result.save(imgbuf, "JPEG", optimize=True, quality=quality)
    newimage = imgbuf.getvalue()
	(new_width, new_height) = newimage.size
    _LOGGER.debug(
        "Padded image from (%dx%d - %d bytes) to (%dx%d - %d bytes)",
        old_width,
        old_height,
        old_size,
        new_width,
        new_height,
        len(newimage),
    return newimage
there is also some other changes to the file to call the method etc… however this is way above my pay grade. I just don’t how how to take this further and test it out. I have been trying for months now…
have you seen this comment Home Assistant Companion Apps: New and Upcoming Features - #48 by joax01
I hadn’t seen that thread, I have just tried to create proxy as per the other thread, tried a dozen different resolutions and it still crops the image. the issue being the proxy doesn’t adjust the aspect ratio. hence the need to pad the image
my notification images are 640x480 and 640x360.
I cant be the only one who see’s this?
Four and a half years later.. i finally got around to making this fix! i now see the full image without the top and bottom being cropped, and with the colour adjustment to match my phones dark theme i cant even see the padding at all.
Start by installing pyscript from hacs and adding the integration
then put this pad_image.py script in the config/pyscript folder
import os
from PIL import Image, ImageOps
@service
def pad_image_2to1(input_path=None, output_path=None):
    if not input_path or not os.path.exists(input_path):
        log.error(f"Input image path does not exist: {input_path}")
        return
    img = Image.open(input_path).convert('RGB')
    width, height = img.size
    target_width = height * 2
    # Match notification background colour here
    bg_color = (38, 38, 41)
    if width < target_width:
        total_pad = target_width - width
        left_pad = total_pad // 2
        right_pad = total_pad - left_pad
        padded_img = ImageOps.expand(img, border=(left_pad, 0, right_pad, 0), fill=bg_color)
    else:
        padded_img = img
    padded_img.save(output_path, quality=95)
then from tools menu select yaml, then reload Pyscript Python scipting.
create a folder in your config/www folder called snapshots, then reboot HA so it loads the new folder properly
in your automation add a couple of actions - save the snapshot, then pad the sides before sending the image
  - action: camera.snapshot
      entity_id: camera.frontdoor
      filename: /config/www/snapshots/motion_raw.jpg
  - action: pyscript.pad_image_2to1
      input_path: /config/www/snapshots/motion_raw.jpg
      output_path: /config/www/snapshots/motion_padded.jpg
then for the image in the notification the line should point to this folder
image: /local/snapshots/motion_padded.jpg
