After updating from 0.84.6 to 0.85.1 I got a problems with a template sensor. It worked well with HA version 0.84.6, but after update to 0.85.1 the sensor is ‘unknown’ and I get the error message
2019-01-14 20:41:54 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Alarm tilkoblet, the state is unknown.
In 0.84.6, my sensor was defined as this:
sensors:
alarm_tilkoblet:
friendly_name: Alarm tilkoblet
value_template: >
{% if 'Systemet MYSYSTEM ble tilkoblet' in states.sensor.verisure_email.attributes.body %}
{{ True }}
{% elif 'Systemet MYSYSTEM er frakoblet' in states.sensor.verisure_email.attributes.body %}
{{ False }}
{% endif %}
I thought maybe it was a startup thing, so I enclosed the template as follows:
sensors:
alarm_tilkoblet:
value_template: >
{% if states.sensor.verisure_email.attributes.body is defined %}
{{ True }}
{{ False }}
{% endif %}
{% else %}
{{ False }}
{% endif %}
The result is, however, the same.
Any pointers would be welcome.
Ah, never mind. It’s the Slugify thing.
is now
sensor.verisure_e_mail
Issue solved.
You have to be careful using is defined
. E.g., even if sensor.xyz doesn’t exist, states.sensor.xyz is defined
will return True, because states.sensor.xyz
will be None, and None is defined. Your test should probably be states.sensor.verisure_email.attributes is defined
, or states.sensor.verisure_email is not none
. FYI, you can’t do states.sensor.verisure_email.attributes.body is defined
, because if sensor.verisure_email doesn’t exist, that will cause an error.
Also your template is unnecessarily complicated. Probably this will do what you want:
sensors:
alarm_tilkoblet:
value_template: >
{{ 'Systemet MYSYSTEM ble tilkoblet' in (state_attr('sensor.verisure_email', 'body') or '') }}
If sensor.verisure_email doesn’t exist, or if it doesn’t have a body attribute, then the state_attr function will return None. In that case, the or ''
comes into play, making sure that the in
test has a string on both sides. So, if the entity exists, and it has a body attribute, and the specified string is in it, then the result will be True
. Otherwise, it will be False
EDIT: Just saw your second reply. I’d still suggest changing as described above (for the reasons mentioned), but of course, changing sensor.verisure_email
to sensor.verisure_e_mail
Thank you, @pnbruckner!
Although my immediate problem was solved when I discovered that the entity name had changed, I can see, from your post, that my solution is not as robust as I would have liked it to be.
I will change my template using the suggestions in your post. Your input is much appreciated.
