Could not restart my Home Assistant after update of software
Was a few weeks behind all update, so today I update the following to currently latest versions:
Home Assistant Core
Home Assistant OS
Grafana
Node-Red
Studio Code Server
After all was updated, I decided to have a fresh restart of HA. Then I received some messages. Please see the attached images.
I’m still logged onto my HA and it seems working, but I don’t now if I should force a restart manually.
Since I’m new to HA, I hope anyone now exactly what I need to do now.
My HA is built on a Raspberry Pi 4 hardware.
TIA
//Lars
Please show the details of the error of 14:53:40 (“unable to install package PyBluez”)
Thanks for trying to help. I found the following details:
Logger: homeassistant.util.package
Source: util/package.py:107
First occurred: 22 August 2023 at 10:24:10 (12 occurrences)
Last logged: 22 August 2023 at 14:53:40
Unable to install package PyBluez==0.22: error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [19 lines of output] running bdist_wheel running build running build_py creating build creating build/lib.linux-aarch64-cpython-311 creating build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/init.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/widcomm.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/osx.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/msbt.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/btcommon.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/bluez.py → build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/ble.py → build/lib.linux-aarch64-cpython-311/bluetooth running build_ext building ‘bluetooth._bluetooth’ extension creating build/temp.linux-aarch64-cpython-311 creating build/temp.linux-aarch64-cpython-311/bluez gcc -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I./port3 -I/usr/local/include/python3.11 -c bluez/btmodule.c -o build/temp.linux-aarch64-cpython-311/bluez/btmodule.o error: command ‘gcc’ failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for PyBluez ERROR: Could not build wheels for PyBluez, which is required to install pyproject.toml-based projects [notice] A new release of pip is available: 23.1.2 → 23.2.1 [notice] To update, run: pip install --upgrade pip
//Lars
That’s the issue. HAOS tries to build the PyBluez python package but fails because the compiler is not actually installed.
No clue why it happens to you, all of a sudden.
Strange!
I tried to run some commands in Terminal at my HA, but it seems not understand because of a non bash shell (zsh). I also tried to access using an external terminal session from my laptop, but it always responds with “permission denied”.
Any suggestions?
//Lars
Not from me. HAOS is a total black box, as far as I’m concerned.
Hopefully, someone else will jump in.
Few Weeks or Few Month ? , could you maybe specify from which Core/OS you upgraded from/to, ( also just from a “security/stability” perspective, i use to install Core/OS separately, with a restart in between) … just a “side-point”
EDIT: Note the importance of reading Release-Notes, and follow up upon “Integrations”
PS: in (i believe) 2023.8 python 3.10 was removed, so i doubt there is anyway you can fix this, beside remove/disable bluetooth-tracker
Take a look here for possible solutions (not many available):
