☀️ Cover Control Automation (CCA) - a comprehensive and highly configurable roller blind blueprint
Please create an issue. Just copy&paste your posts to Issues · hvorragend/ha-blueprints · GitHub. Thank you.
New update
2024.02.01-01:
* Minor Layout changes
* Removed commented out code
* Fixed closing-condition
* Fixed cover status helper initialisation and still make the first cover drive possible
I have done that for you: Individual opening and closing times · Issue #6 · hvorragend/ha-blueprints · GitHub
Please take a look in the issue: Adaptive Cover? · Issue #3 · hvorragend/ha-blueprints · GitHub
But I am not sure if I really will do this.
Sorry, I haven’t read your reply before I added a new issue #9.
Maybe you can close #6 as a duplicate?
New update:
BREAKING CHANGE:
Please reconfigure/rename the variables close_position and shading_position in your blueprint config.
2024.02.02-01:
  - BREAKING CHANGE: Please reconfigure/rename the variables close_position and shading_position in your blueprint config
    Old: closed_position - New: close_position
    Old: shading_cover_position - New: shading_position
  - Added tilt positions for open, close and ventilation
I was wondering if there might be an option for a „drive down up late on non-workdays“
Example: kids have to get up latest 7am on workdays but on weekend 8:30 is ok.
Maybe I’m thinking wrong and should adjust sun elevation instead!?
Hi, automation with external helper seems to function not as intended.
I’ve set up an helper and moved a cover manually (manual: on in text_input). This evening the cover didn’t close automatically.
Which version are you using?
Could you please show me the history of the helper?
Version: 2024.02.03-01
alias: 'CCA: Büro'
description: ''
use_blueprint:
  path: hvorragend/cover_control_automation.yaml
  input:
    blind: cover.beschattung_buro_empfanger
    auto_options:
      - auto_up_enabled
      - auto_down_enabled
      - auto_brightness_enabled
      - auto_ventilate_enabled
      - auto_shading_enabled
    time_up_early: '07:30:00'
    time_up_early_non_workday: '08:00:00'
    time_up_late: '08:30:00'
    default_brightness_sensor: sensor.illumination_average
    brightness_up: 80
    brightness_down: 20
    brightness_time_duration: 60
    workday_sensor: binary_sensor.workday_sensor
    contact_cover_place: door
    contact_sensor: binary_sensor.fenstergriff_buro_offen
    ventilate_position: 89
    drive_delay_random: 5
    position_tolerance: 1
    shading_temperatur_sensor1: sensor.temperatursensor_temperatur
    shading_min_temperatur1: 24
    shading_temperatur_sensor2: sensor.hue_motion_buro_temperature
    shading_min_temperatur2: 24
    shading_forecast_temp: 24
    sun_time_duration: 60
    shading_azimuth_start: 185
    shading_azimuth_end: 315
    shading_elevation_min: 7
    shading_sun_brightness_start: 10000
    shading_sun_brightness_end: 5000
    drive_delay_fix: 0
    check_config: false
    check_config_debuglevel: ''
    auto_shading_end_condition:
      - condition: state
        entity_id: input_boolean.automatik_beschattung_nach_sonnenstand
        state: 'on'
    auto_shading_start_condition:
      - condition: state
        state: 'on'
    close_position: 0
    shading_position: 45
    cover_status_options: cover_helper_enabled
    cover_status_helper: input_text.cover_status_helper_buro
Good morning, i have got the same probleme like @crandler . Last night I opened a blind to 20% (after all blindes were closed) to find out if I had the same problem and this morning the blind didn’t open. The Logbook says, it opened, but it won’t open.
Using the Version 2024.02.03-01
@Loi
@crandler
Isn’t that exactly how it should be?
The status is not known, so it is not driven. It is only opened if the status is “closed”. And vice versa.
But I don’t think that’s good either. Let’s see if we can change that in the future.
I just don’t understand how the logbook should say anything else. Then I need to know whether the automation has started the blinds or not.
You shut down manually at 17:40, didn’t you?
in a different shutter-automation-solution it was implemented like this:
shutter status unknown (manual interaction) > automatic shading stops, but auto-down and auto-up keeps working (and then you have a known state again)
for me this bahaviour made sense…
yes, bc it didn’t close as per definition:
If you want to be able to intervene manually and the automation should execute the next movement as usual, a helper is required.
Maybe I misunderstood something again. I thought that if I use a helper, I can put the blind in any position and by using the helper the blind will still open or close
How about following idea:
Helper variable keeps last state and timestamp of CCA and timestamp of manual movement.
You add a field for “ignore for time x after manual movement”. One can enter e.g. 3 hours to temporarily ignore CCA movements. After this period, last state of CCA is restored or next step is calculated to prevent first up, then down.
If too complicated, a selectable force up/force down with unknown state would be helpful.
To be honest, I don’t like it at all when the blinds are suddenly moved after x hours. I didn’t like that in the FHEM module AutoShuttersControl (ASC) either. I always had the problem that I wondered about spontaneous movements. :grinning:
But I have an idea. I’m working on something. I also want the roller blinds to be operated only once. I’ll check it in at a GitHub branch first.
Originally, the behavior was planned differently. That was also the reason why I didn’t go Eimeel’s way and introduced the helpers for this purpose.
A few days ago, I adapted the behavior of the helpers to the other procedure. Otherwise manual overrides would have been overwritten again and again.
I just want to control my blinds via sunrise and sunset but it doesn’t work. I use sun.sun and it also says 7:52h. But they go up at 8 o’clock sharp. what could be the reason? :frowning:
Couldn’t someone here who understands everything make a tutorial video about it?
