Note: my binary sensor is working fine. When my door are open and the sun goes down, the cover is closing but it normally does’nt because the door is open no?
Is it possible to configure shading using only open/close cover? The covers in our bedroom are RFX and do not support position or tilting.
I think I figured it using “Prevent the use of ‘set_cover_position’ and ‘set_cover_tilt_position’ and only use the additional actions” and configuring open/close in additional actions.
Very good job, it’s a very good template, I’m changing it because I had it organized in node red.
In case it helps you improve or to add something in the future, in my node red I have a node that is to raise the blinds in the morning randomly between the hours that I set, so every day that there are no people at home the blinds go up at a random hour or minute. It’s very good for a vacation mode or if you’re not at home.
I am currently going through very well presented and detailed information from darkm242. My head is spinning. I still need to change a few things in the beta. It’s not bug-free at the moment. I hope I’ll find the time soon.
i tested the beta-version, and as i can say for today, the new lockout protection when “Contact Sensor For Open Window” is selected works, but the cover wouldn’t close if i close the door and the shading started during the door was open! I got some traces for you
@Herr.Vorragend : today the same issue: door was open, shading started, but cover still open, because of the lockout protection, than door closed, but cover still open!
After opening the door again, and closing it, the cover closed as it should! Maybe there is a prob. with the status helper!
Today the shading started to work. I have shading position set to 80.
open_position: 0
close_position: 100
but the shade is moved to position 20 and not 80.
Seems I need to change the configuration. it seems to be different to what I have used in FHEM.
br,
Matthias
