Hi All. I’ll start by saying that I am loving this automation blueprint. It’s somewhat complicated, but worth it.
Question:
I have daily automatic opening and closing, and automatic sun protection working fine. But the sun elevation control does not work and I cannot find out why. (I might have to learn analysing traces)
Under sun elevation automation, it says " Important: If you want to use automatic shading, the sensor must also be specified here. Regardless of whether the basic sun control is used.". But where is “here” in this case? I have sun.sun configured in the only input box that there is.
Hi, I cant find the answer in the topic, how can I disable opening of the curtain in my case based on the brightness? Set to 0? to 10000? I only want closing in the evening and opening in the morning based on time only. Thanks
I’m having a similar issue with sun elevation. I’ve exposed elevation through the sun.sun device and selected it in the blueprint but in shutters open and close far too early, seem to be triggered by the timer. I’ve set elevation to -4 for closing and -1.5 for opening.
It’s a rather long thread so I couldn’t read it all, but I am very keen to move my shutter automation from Homee to Home Assistant, using this great blueprint.
The one thing I could not see in the options is the ability to track the slat rotation angle with the sun so that there is always shade. I believe that currently, there is only one fixed angle. I’d love to have this as a dynamic setting as it works in Homee.
Hey Guys,
don´t know if i oversee something but it tried to configure my ikea PRAKTLYSING blinds with this blueprint. The thing is that i don´t wont to open or close them completely. They should go down to like 50% in the morning, later to 25% and be completely closed when nobody is @ home. In the night they don´t shoult be completely closed… Is this possible with this Blueprint or does anybody know one, which fits my needs better because this one is originally build with the thought of external roller blinds. I couldn find the right configuration…
Greetings
Yes i have! Its the first “blind controlling” for me, so all the options are overwelming. But if you say all the things i mentioned are possible, i´ll try harder to get this working!
Understood. Looks like I need to combine CCA with the Adaptive Covers custom integration to achieve this. CCA does up and down, AC does rotation tracking. Just not sure about the best way to achieve this.
I’ll try to explain why it came to my problem and question… First of all, the blueprint is quite complicated. I started working with it by configuring basic opening/closing at fixed times, then figured out how to set up the helpers, then figured out how to set up shading, and only then started trying to open/close with sun elevation. I thought I knew enough, understood enough, and never went back to reading the descriptions in the Time Control Configuration part where it says:
The earliest time at which the cover may be opened. The cover will be opened if AFTER this time the defined brightness or sun-elevation value is high enough. (NOTE: If a resident is defined, he must also be awake).
Again, thank you very much for the help. And to anybody reading this topic and looking for help: I recommend to read EVERYTHING very thoroughly and read it again if you have to!
