Crazy Numbers in Energy Dashboard - Manual Override possible?
Hi there, i just noticed that the numbers in the energy dashboard are crazy high. All values are driven by the tesla integration sensors.
Is there some guide available on how to manually update these numbers? it messes up the statistics. :frowning:
Thanks. Ike
You should also look into why it happened to prevent it happening again.
Most likely one of your energy sensors reported 0 instead of unavailable. When it returned to the actual value the jump from 0 to the value was recorded as an increase in that much energy.
Will do! Thanks so much.
