Hello everybody.
I have two led strips managed by a d1 mini with esphome that I integrated into the home assistant. Can I save selected colors from the color palette in order to make presets? to know the RGB values that match a selected color? Grazie
So you just want to know the RGB value when you chose one?
You could check the developer tools / states menu, find your light and look in the right hand column for the rgb_color attribute. This will be of the form 0-255, 0-255 0-255. You will have to convert this to hexadecimal for a #0-FF 0-FF 0-FF value.
Thanks I found the values and they will be useful for creating scenes.
I would also like to create something that once the color is selected I can save it in a preset. Create some that you can always change when I go to save another color without creating an additional scene.I’m not very practical, he ran a script …
I don’t know of anything that can save the values for later use. Even this relies on manually presenting the values:
Well, you can actually call the scene.create
service to create a scene using the state of one or multiple entities
However, your scene will be deleted if your restart your home-assistant server…
Create a new scene without having to configure it by calling the
scene.create
service. This scene will be discarded after reloading the configuration.
Thanks … already using rgb light card and I am very satisfied.
I had seen on the net a video of a LED lamp project where he saved the colors he selected from the 2 LED strips in presets. Unfortunately, he has no longer published the programming. Two led strips driven by d1 mini with esphome, a rotary sensor all integrated into the home assistant. It is probably the same creator of this project, where I used programming.
