Continuing the discussion from Revert to "mode: yaml" after storage mode:
I am rather taken by the new VSCode addon for Home Assistant so do not really want to use the built-in GUI. I had resisted moving to lovelace but it seems that resistance is futile.
The first question then is how do I migrate to a editable Lovelace file without starting from scratch?
Is it as simple as going into the raw mode, copying what is there into a ui-lovelace.yaml
and adding in to the configuration file
lovelace:
mode: yaml
Is this yaml file just layout information for your Home Assistant instance? I had thought it was more, but perhaps I am mistaken.
Second question, is Lovelace compatible with Custom_UI? I am reasonably sure it is; just want to check.
