Does anyone have any documentation/how to on creating and or joining a thread network with the Open Thread Router/Multi-protocol add-on to HA?
I have a number of google nest devices and ultimately would like to have a single Thread network.
you’re probably looking forward to the 2023.3.x releases then…
read this:
Matter & Thread: where we’re at - Home Assistant (home-assistant.io)
Then specifically - you’ll probably be looking for this when it releases:
2023.3: Beta release notes - Home Assistant (home-assistant.io)
Dont usually assume someone’s running a beta, thank you for making it better - Unfortunately then you have probably seen the docs everyone else has
I’ve got a Skyconnect sitting next to my production system just waiting for stability. (and for everyone else to flesh out the documentation…)
So the current Matter integration docs dont show in search but ARE linked here:
Matter - Home Assistant (home-assistant.io) Its got some stuff in there about various fabrics - and I don’t see any good docs about Matter Server yet… I’m a week or so behind on my reading unfortunately.
(Edit - re: companion, I’d bet yes?)
I have some Eve Matter devices setup using both Apple and Nest Thread Border Routers. All seems a bit flaky at this point in time but that has nothing to do with Home Assistant.
Trying to work out if it is the Eve devices of the Thread Border Routers.
I’d bet - both. Still VERY VERY early. I don’t expect this stuff to start stabilizing till the next release. Kevin Tofel (Stacy on IoT podcast) is playing with a lot of the same stuff you are, seems very up to speed with the current happenings with Matter at Eve. He did a writeup on his experiences in December - which may already be dated at the speed of Internet, but there may be some stuff in his adventures that can help?
matter articles - Stacey on IoT | Internet of Things news and analysis
Thanks Nathan, yes I get the Stacy on IoT newsletter.
In case you are still looking for a solution, I tried to write a guide on how I got it working with a google tv streamer.
Thank you, long fixed by firmware upgrades from Google.
