TL:DR question, is there a way to use DNS-01 challenge with the Lets-encrypt add-in, and without DuckDNS?
I am trying to setup my SSL certificate on my Hass.io install, but I’ve ran into a problem with the certificate generation with the LE add-in. I’ve read this post.
I have a registered domain name, and static IP address, so I don’t have a need for DuckDNS. My ISP blocks inbound port 80 to my firewall. For forwarding, I have External 443 --> hass.io (443), and External 8123 -->hass.io (8123). I have control of my DNS, so I can add any needed records for the LE DNS-01 challenge.
when I run the LE add-in, I get the error below. I’m positive its due to blocked port 80. Do I have any options on getting around the http-01 challenge, or am I stuck using DuckDNS when its not needed?
starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for ha.domain.com
http-01 challenge for domain.com
Waiting for verification...
Cleaning up challenges
IMPORTANT NOTES:
Failed authorization procedure. domain.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://domain.com/.well-known/acme-challenge/Ro-trc7vps8H19SPFm8QggyUh7W7lgr6PXEDZYH4VgY: Timeout during connect (likely firewall problem), ha.domain.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://ha.domain.com/.well-known/acme-challenge/YxPle_DUnJmso_yLRKFlao-oaEtY1uSR9KlsQfDKUAM: Timeout during connect (likely firewall problem)
- The following errors were reported by the server:
Domain: domain.com
Type: connection
Detail: Fetching
Domain: ha.domain.com
Type: connection
Detail: Fetching
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
