Custom: button-card
Is there a way to include a title above the icon when using a custom: button-card? I have only just begun to use this custom card (for my garage door) and co not see a way to include a title/label/name/some sort of text - above the icon.
Thanks.
By default the custom button card layout [1] does not provide this option.
But you may set show_icon: false, show_label: true and use the label to populate whatever layout and components you want., e.g.:
card:
  type: custom:button-card
  styles:
    label:
      - font-size: 85%
    card:
      - height: 70px
  label: >
      var label = ""
      label = `my title<br><ha-icon icon=mdi:wrench"` +
                 `" style="width: 30px; height: 30px; padding-top: 7px;">` +
                  `</ha-icon><br>my footer`;
      return label;
  show_label: true
  show_name: false
  show_icon: false
[1] GitHub - custom-cards/button-card: ❇️ Lovelace button-card for home assistant
Alternatively you can use button card grid-layout:
Some examples:
label on top:
styles:
  grid:
    - grid-template-areas: '"l" "i" "n" "s"'
    - grid-template-rows: min-content 1fr min-content min-content
    - grid-template-columns: 1fr
Thank you. The reason I’m using the custom:button-card is to give the ability to change the icon with the state of the garage door being open or closed. What I have works fine but I wanted to see if I could put a label on the card at the top. Not necessary, but all the other cards on my dashboard have labels. So I don’t believe the grid card will allow for the icon to change based on entity state. The solution above turning off show_icon and providing label as a var did not work for me. The only things that were visible were the “my title” and “my footer” text. I guess it’s possible to program change the label based on state in the custom:button-card but only if I get the icon within the label to show. Is ha-icon the right tag? It just doesn’t seem to pick up the icon.
Grid layout is part of custom:button-card.
I didnt realize grid was part of custom:button-card. That works very well. Thank you!
And the Garage Door - OPEN state:
Very nice!
The documentation is very large, so it can happen quickly to overlook something.
Could you share your lovelace snippet for this? I’ve been looking to replicate exactly this: a garage door button with hold functionality
EDIT: Got it working
type: horizontal-stack
cards:
  - type: custom:button-card
    label: Main Garage
    styles:
      card:
        - height: 150px
      grid:
        - grid-template-areas: '"l" "i" "s" "n"'
    entity: cover.garage_door
    tap_action:
      action: none
    hold_action:
      action: call-service
      service: switch.turn_on
      service_data:
        entity_id: switch.garage_main_door_opener_2
    show_state: true
    show_label: true
    state:
      - color: green
        icon: mdi:garage
        value: closed
        state: CLOSED
        name: (Hold to Open)
      - color: red
        icon: mdi:garage-open
        value: open
        name: (Hold to Close)
How did you get the second line added to the card?
Hi, I had the same need (add a title above the icon in a button card. I see you succeeded, complete!!! Can you send or show the code you used? Thanks
Please post in English. See #0 in the link below
hey @slimmypizza can you share your snippet code with the rest?
I’m sure I’m going to feel stupid when I see the solution, but I’m trying to get “SOLAR” closer to the icon. BTW, I also notice the icon is not centered vertically with “SOLAR”.
icon: mdi:solar-power-variant-outline
show_name: true
show_icon: true
layout: icon_name
styles:
  card:
    - background-color: black
    - border-color: black
    - color: white
    - font-weight: bold
    - font-size: 45px
    - text-shadow: 3px 5px 6px black, 0 0 2em yellow, 0 0 0.2em yellow
    - padding: 0%
  icon:
    - color: yellow
    - height: 35px
Instead of “layout: icon_name” I also tried under styles:
  grid:
    - grid-template-areas: '"i n n"'
Trying to figure out how to fix the mini-graphcard at the bottom.
any sugestion?
Br
          # Inside
            aspect_ratio: 10/3.2
            custom_fields:
              value:
                card:
                  entity: sensor.indoor_temperature
                  show_icon: false
                  show_state: true
                  show_name: true
                  name: "Indoor Temperature :"
                  styles:
                    name:
                      - padding-left: 70px
                      - justify-self: start
                      - font-size: 0.9em
                      - font-weight: bold
                    state:
                      - padding-left: 100px
                      - font-size: 0.7em
                    card:
                      - background: >-
                          linear-gradient(90deg, rgba(28,28,28,1.0) 0%, rgba(28,28,28,0.0)
                          100%)
                      - width: 500px
                      - border-radius: 0%
                      - z-index: 1
                  tap_action:
                    action: none
                  hold_action:
                    action: none
              graph:
                card:
                  type: custom:mini-graph-card
                  entities:
                    - entity: sensor.indoor_temperature
                  color_thresholds:
                    - value: -20
                      color: "#0000FF" # Deep blue (very cold)
                    - value: -10
                      color: "#00BFFF" # Ice blue
                    - value: 0
                      color: "#ADD8E6" # Light blue
                    - value: 10
                      color: "#00FF00" # Green (normal)
                    - value: 20
                      color: "#80FF00" # Yellow-green (getting warm)
                    - value: 25
                      color: "#FF8000" # Orange (hot)
                    - value: 30
                      color: "#FF0000" # Red (very hot)
                  hours_to_show: 24
                  hour24: true
                  points_per_hour: 2
                  animate: true
                  update_interval: 30
                  aggregate_func: avg
                  line_width: 2
                  bar_spacing: 5
                  height: 100
                  group: true
                  card_mod:
                    style: |
                      ha-card {border: none;
                      background-color: transparent;
                  show:
                    labels: false
                    fill: fade
                    state: false
                    icon: false
              icon:
                card:
                  icon: mdi:thermometer
                  show_name: false
                  styles:
                    icon:
                    card:
                      - background-color: transparent
                      - border: none
                      - border-radius: 50%
                      - width: 48px
                      - height: 48px
                      - z-index: 1
                  tap_action:
                    action: none
                  hold_action:
                    action: none
            styles:
              card:
                - background-color: var(--button-card-background-color)
              custom_fields:
                graph:
                  - position: absolute
                  - bottom: "0px" # Anchor to the bottom
                  - left: "0px"
                  - width: 100% # Span the full width
                  - height: 70% # Adjust height as needed
                  - padding-bottom: 0
                icon:
                  - left: 3%
                  - top: 18%
                value:
                  - left: 0%
                  - top: 0%
            tap_action:
              action: none
            hold_action:
              action: none
bottom: -10%
Can You share this code?
I want to realize this too!
Can I create a variable
    variables:
      test_the_panel: false
and then change the variable state with a button press? I could not figure-out how to update the variable. I did not want to create any “global” variables, would like to do everyting within the card.
Set a template for this variable like
variables:
  xxx: >-
    [[[ return (states['input_boolean.xxx'].state === 'on'); ]]]
Then create an automation which sets that “input_boolean” on some button press (if you need to associate this variable with some particular “input_button” entity).
Or just call “input_boolean.turn_on(off)” service in some “tap_action”.
I was trying to create a variable that keeps some state of that particular use of the dashboard (this dashboard will be on multiple devices, so I want to isolate state changes to each user)
Second, I was hoping to contain all the information within the dashboard yaml file for nicer software engineering.
Basically, a “local variable” with scoped within each instance of the dashboard.
