misse
(Martin Bergman)
December 3, 2022, 3:26pm
312
Hi! Thanks for a great card
I am trying to build room cards that have cards that show conditionally, but when Iām adding a cards: entry into the room - they seem to keep refreshing very often, which makes them reset while youāre interacting with them.
Iāll attach a gif of what it looks like.
Gist with yaml for the dashboard: blinking_hass.yaml Ā· GitHub
Does anyone know whatās causing this? It doesnāt seem to be just custom:mushroom-light-card, since custom:mini-media-player is refreshing as well.
If one of the entities used in the card changes value, the whole card refreshes. That includes the cards inside room card
misse
(Martin Bergman)
December 4, 2022, 1:55pm
314
Thanks Marco - so it makes more sense to have cards that are dynamic/update a lot outside of the baked in cards list? I ended up using vertical-stack and conditional cards like below.
type: custom:vertical-stack-in-card
cards:
- type: custom:room-card
title: Vardagsrum
entity: light.living_room
icon: mdi:lightbulb-outline
show_icon: true
tap_action:
action: toggle
entities:
- entity: light.livingroom_couch_ceiling_lamp
tap_action:
action: toggle
- entity: switch.livingroom_window_star
icon: mdi:star-outline
show_icon: true
state_color: true
tap_action:
action: toggle
- entity: switch.livingroom_corner_plug
icon: mdi:led-strip
show_icon: true
state_color: true
- entity: media_player.living_room_tv
show_icon: true
state_color: true
tap_action:
action: call-service
service: media_player.media_play_pause
service_data:
entity_id: media_player.living_room_tv
icon:
conditions:
- condition: equals
value: playing
icon: mdi:television-play
- condition: equals
value: paused
icon: mdi:television-pause
- condition: equals
value: stopped
- entity: media_player.living_room_speaker
show_icon: true
state_color: true
icon: mdi:google-home
- type: conditional
conditions:
state_not: 'off'
card:
type: custom:mini-media-player
- type: conditional
conditions:
state_not: 'off'
card:
- type: conditional
conditions:
state: 'on'
card:
type: custom:mushroom-light-card
show_brightness_control: true
show_color_temp_control: true
fill_container: true
Yes exactly. The room card isnāt really designed to house other cards, the fact it does is just something extra. But itās always best to not nest cards
foglietti
(Raúl HernÔndez Foglietti)
December 9, 2022, 3:56pm
316
Hello. I want to horizontally justify the entities of a row to avoid empty spaces in the right part of the cards.
The content_alignment option of configuration admits only Left, Center or Right.
How can I do it?
Thanks.
GH2user
December 10, 2022, 1:35pm
317
@marcokreeft87
We can already tailor the icon colour by using the template option so it is possible.
In view of the recent update 12-2 with the unfortunate colour changes of the icon states.
Would it be possible to create a shortcut for the colour similar as for the state-on/off like color-on/off?
EXAMPLE:
- entity: input_boolean.mailbox_full
show_icon: true
state_color: true
icon:
state_on: mdi:mailbox-up
color_on: red
state_off: mdi:mailbox-outline
color_off: green
You could use templates. So not for values but templates for the whole entities Configuration Ā· marcokreeft87/room-card Wiki Ā· GitHub
You could try card mod. Or conditions?
foglietti
December 11, 2022, 7:57pm
320
OK, I will investigate using these two options with the card.
Thanks.
ronvl
(Ron)
January 6, 2023, 3:32pm
321
First off all thank you for this awsome card! It allowed me to get everything on a single page and the interface it gives works very well.
nice is also the flexibility to use browser_mod.popup which creates a perfect interface, for example clicking the Lights icon in living room pops up:
Ofir
(Ofir)
January 8, 2023, 7:17am
322
Hey!
I am trying to do something similar to this dude example
but I keep getting an error:
type: custom:button-card
template:
- card_room
- red_no_state
entity: light.bathroom
icon: mdi:shower-head
tap_action:
action: navigate
navigation_path: /ui-lovelace-minimalist/bathroom
variables:
label_use_temperature: false
label_use_brightness: true
entity_1:
entity_id: light.bathroom
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
entity_id: binary_sensor.badkamer_motion_sensor
templates:
- blue_on
tap_action:
action: none
entity_3:
entity_id: input_boolean.badkamer_motionsensor_enabled
templates:
- green_on
- red_off
tap_action:
action: toggle
entity_4:
entity_id: input_boolean.bath_mode
templates:
- pink_on
tap_action:
action: toggle
I do have a room card in HACS and I did empty my cache and did reload the page as well.
pkscout
(Kyle Johnson)
January 8, 2023, 1:41pm
323
Seems like you have the wrong name for Custom Room Card. Try room-card or maybe custom:room-card. Iām not familiar with button-card, so Iām not sure what that template section is expecting. Or maybe there is some step in button-card you need to do to make the card_room template?
Ofir
(Ofir)
January 8, 2023, 1:51pm
324
Great, now it showing me some card, but not what they should look like
should look like this:
https://ui-lovelace-minimalist.github.io/UI/usage/cards/card_room/#usage
What am I missing here?
pkscout
(Kyle Johnson)
January 8, 2023, 5:01pm
325
Ofir:
Youāre in the wrong thread for starters. This thread is for a custom card called Room Card. You seem to be trying to use UI Lovelace Minimalist, which has an option for something called a room card. But itās not this one. Iād try this thread for UI Lovelace Minimalist.
My Home Assistant
Hi, my name is Thomas and Iām a UX designer and have been using Home Assistant for 4 years.
After showing a little bit of my interface on Bokubās post , I had several requests for more details on my configuration. I drew a lot of inspiration from 7ahangās work that I found on Behance.
[HA]
Interface composition
I use my phone most of the time to access the interface. I chose to use only one column to facilitate maintenance between the different devices.
I have beeā¦
Beersteddy
(Beersteddy)
January 8, 2023, 6:31pm
326
Any chance you can share the code?
pkscout
(Kyle Johnson)
January 9, 2023, 12:58am
327
Iām stumped. I have a socket for a fan that I use to control the Christmas tree during the holidays. I also have a couple sockets I only plug in during the holidays, so Iām trying to use their availability to set a name and icon for another entity so that my interface either shows a Fan or a Tree. It doesnāt seem like room-card understands unavailable as a state for an entity, or at least I canāt figure it out. Hereās what I have that doesnāt work (i.e. it always shows the Tree even when the sockets are unavailable).
entities:
- entity: fan.living_room
hide_if:
conditions:
- condition: not_equals
entity: switch.holiday_lights_1
attribute: state
value: 'unavailable'
state_color: true
show_icon: true
tap_action:
action: toggle
hide_if:
conditions:
- condition: equals
attribute: state
state_color: true
show_icon: true
icon: mdi:pine-tree
tap_action:
action: toggle
State isnt an attribute, try without the āattributeā
ronvl
(Ron)
January 9, 2023, 3:50pm
329
Not all of it but here is something to get you going
type: vertical-stack
cards:
title: Living Room
entities:
- entity: light.living_room_lights
show_icon: true
icon:
state_on: mdi:light-switch
state_off: mdi:light-switch-off
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
content:
type: entities
state_color: true
show_header_toggle: true
entities:
- type: custom:slider-entity-row
entity: light.living_room_sphere
hide_state: true
toggle: true
step: 1
entity: light.living_room_ceiling
hide_state: true
toggle: true
step: 1
entity: light.living_room_leds_channel_1
hide_state: true
toggle: true
step: 1
entity: light.sideboard_stairs_channel_1
hide_state: true
toggle: true
step: 1
entity: light.staircase_kg_2
hide_state: true
toggle: true
step: 1
entity: light.living_room_leds_channel_3
hide_state: true
toggle: true
step: 1
entity: light.living_room_leds_channel_2
hide_state: true
toggle: true
step: 1
entity: light.kitchen_light
hide_state: true
toggle: true
step: 1
entity: light.gallery_wall_light
hide_state: true
toggle: true
step: 1
- entity: light.kitchen_counter
- entity: light.black_1_switch
double_tap_action:
action: none
hold_action:
action: none
- entity: input_boolean.scene_livingroom_off
icon:
state_off: mdi:lightbulb-group
state_on: mdi:lightbulb-group-off-outline
template:
styles: >
if (states["input_boolean.scene_livingroom_off"].state == 'off')
return 'color:var(--paper-item-icon-active-color)';
show_icon: true
state_color: false
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
state_color: true
tap_action:
action: toggle
- entity: input_boolean.scene_livingroom_normal
state_color: true
tap_action:
action: toggle
- entity: input_boolean.scene_livingroom_dim
state_color: true
tap_action:
action: toggle
- entity: input_boolean.scene_livingroom_tvtime
state_color: true
tap_action:
action: toggle
- entity: input_boolean.livingroom_motion_control
state_color: true
tap_action:
action: toggle
- entity: binary_sensor.living_room_motion
state_color: true
show_icon: true
- entity: cover.living_room_shutters
state_color: true
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
full_row: true
step: 1
- type: divider
- entity: cover.living_room_1
full_row: true
step: 1
- type: divider
- entity: cover.living_room_2
full_row: true
step: 1
- type: divider
- entity: cover.living_room_3
full_row: true
step: 1
- type: divider
- entity: cover.living_room_4
full_row: true
step: 1
- entity: media_player.livingroom
state_color: true
show_icon: true
tap_action:
browser_mod:
content:
type: media-control
- entity: media_player.home_theater
state_color: true
show_icon: true
icon: mdi:audio-video
tap_action:
browser_mod:
content:
type: media-control
state_color: true
show_icon: true
tap_action:
browser_mod:
content:
type: media-control
- entity: binary_sensor.sliding_door_access_control_window_door_is_open
show_icon: true
state_color: true
icon:
state_on: mdi:door-sliding_open
state_off: mdi:door-sliding
- entity: switch.fridge
show_icon: true
state_color: true
- entity: switch.dishwasher_power_on
show_icon: true
state_color: true
- entity: switch.steam_combination_oven_power_on
show_icon: true
state_color: true
info_entities:
- entity: sensor.multisensor_6_air_temperature
- entity: sensor.multisensor_6_humidity
- entity: sensor.multisensor_6_illuminance
card_mod:
style: |
ha-card {
height: 100% !important;
.card-header .entities-info-row {
padding: 0px 0px 0px 0px;
margin: 0px;
right: 10px;
top: 0px;
.card-header {
margin: 0px;
padding: 0px 0px 0px 8px;
right: 10px;
top: 0px;
font-size: 18px !important;
.entities-row.content-left {
margin-right: 0px;
margin-left: 0px;
.entities-row.content-left .entity {
margin-right: 3px;
margin-left: 3px;
title: Living Room Luca
entities:
- entity: light.living_room_luca_lights
show_icon: true
icon:
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
entity: light.luca_living_room_ceiling
hide_state: true
toggle: true
step: 1
entity: light.living_room_luca_spheres
hide_state: true
toggle: true
step: 1
entity: light.living_room_luca_right_sphere
hide_state: true
toggle: true
step: 1
entity: light.living_room_luca_left_sphere
hide_state: true
toggle: true
step: 1
double_tap_action:
action: none
hold_action:
action: none
- entity: cover.luca_living_room
state_color: true
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
full_row: true
step: 1
- entity: media_player.nestaudio5366
state_color: true
show_icon: true
icon: mdi:speaker
tap_action:
browser_mod:
content:
type: media-control
- entity: media_player.samsung_ue55ku6079_3
state_color: true
show_icon: true
tap_action:
browser_mod:
content:
type: media-control
info_entities:
- entity: sensor.luca_living_room_ht_temperature
- entity: sensor.luca_living_room_ht_humidity
card_mod:
style: |
ha-card {
margin: 0px;
right: 10px;
top: 0px;
.card-header {
margin: 0px;
right: 10px;
top: 0px;
margin-right: 0px;
margin-left: 0px;
margin-right: 3px;
margin-left: 3px;
title: Bedroom
entities:
- entity: light.bedroom_lights
show_icon: true
icon:
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
- entity: light.bedroom_ron
- entity: light.bedroom_ledi
double_tap_action:
action: none
hold_action:
action: none
- entity: input_boolean.bedroom_motion_control
state_color: true
tap_action:
action: toggle
- entity: binary_sensor.bedroom_home_security_motion_detection
state_color: true
show_icon: true
- entity: cover.bedroom_shutters
state_color: true
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
full_row: true
step: 1
- type: divider
- entity: cover.bedroom_1
full_row: true
step: 1
- type: divider
- entity: cover.bedroom_2
full_row: true
step: 1
- type: divider
- entity: cover.bedroom_3
full_row: true
step: 1
- entity: media_player.bedroom_display
state_color: true
show_icon: true
tap_action:
browser_mod:
content:
type: media-control
info_entities:
- entity: sensor.bedroom_air_temperature
- entity: sensor.bedroom_humidity
- entity: sensor.bedroom_illuminance
card_mod:
style: |
ha-card {
margin: 0px;
right: 10px;
top: 0px;
.card-header {
margin: 0px;
right: 10px;
top: 0px;
margin-right: 0px;
margin-left: 0px;
margin-right: 3px;
margin-left: 3px;
title: Bedroom Luca
entities:
- entity: light.bedroom_luca_lights
show_icon: true
icon:
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
entity: light.luca_bedroom_light
hide_state: true
toggle: true
step: 1
hide_state: true
toggle: true
step: 1
entity: light.right_sphere_light_0
hide_state: true
toggle: true
step: 1
entity: light.left_sphere_light_0
hide_state: true
toggle: true
step: 1
double_tap_action:
action: none
hold_action:
action: none
- entity: media_player.luca_bedroom
state_color: true
show_icon: true
icon: mdi:speaker
tap_action:
browser_mod:
content:
type: media-control
- entity: media_player.chromecast
state_color: true
show_icon: true
icon: mdi:google-chrome
tap_action:
browser_mod:
content:
type: media-control
info_entities:
- entity: sensor.luca_bedroom_ht_temperature
- entity: sensor.luca_bedroom_ht_humidity
card_mod:
style: |
ha-card {
margin: 0px;
right: 10px;
top: 0px;
.card-header {
margin: 0px;
right: 10px;
top: 0px;
margin-right: 0px;
margin-left: 0px;
margin-right: 3px;
margin-left: 3px;
title: Bathroom
entities:
- entity: light.bathroom_lights
show_icon: true
state_color: true
icon:
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
entity: light.bathroom_eg_ceiling
hide_state: true
toggle: true
step: 1
entity: light.bathroom_cabinet_channel_1
hide_state: true
toggle: true
step: 1
double_tap_action:
action: none
hold_action:
action: none
- entity: input_boolean.scene_bathroom_eg_off
icon:
template:
styles: >
if (states["input_boolean.scene_bathroom_eg_off"].state == 'off')
show_icon: true
state_color: false
tap_action:
browser_mod:
content:
type: entities
state_color: true
entities:
state_color: true
tap_action:
action: toggle
- entity: input_boolean.scene_bathroom_eg_on
state_color: true
tap_action:
action: toggle
- entity: input_boolean.scene_bathroom_eg_dim
state_color: true
tap_action:
action: toggle
- entity: input_boolean.bathroom_eg_motion_control
state_color: true
tap_action:
action: toggle
- entity: binary_sensor.bathroom_eg_home_security_motion_detection
state_color: true
show_icon: true
- entity: media_player.bathroom
state_color: true
show_icon: true
icon: mdi:speaker
tap_action:
browser_mod:
content:
type: media-control
info_entities:
- entity: sensor.bathroom_eg_air_temperature
- entity: sensor.bathroom_eg_humidity
- entity: sensor.bathroom_eg_illuminance
card_mod:
style: |
ha-card {
margin: 0px;
right: 10px;
top: 0px;
.card-header {
margin: 0px;
right: 10px;
top: 0px;
margin-right: 0px;
margin-left: 0px;
margin-right: 3px;
margin-left: 3px;
view_layout:
grid-area: main1
pkscout
(Kyle Johnson)
January 9, 2023, 11:06pm
330
Thanks. That did it. I swear I thought I had tried that variation, but if I did I had the logic wrong.
Good news! Another bug fixed :
opened 08:53PM - 22 Oct 22 UTC
bug
Version: 1.07.00 but I guest for all of them
**Describe the bug**
On and off⦠(toggle) entities on phone where we`re using finger and scrolling entities turn on... but should on when I press on that button, please have a look on video, this is not happened on other entities or some other functions on HA :)
**To Reproduce**
use phone or watch a movie..
**Screenshots**
https://youtu.be/uit821515mQ
**Desktop (please complete the following information):**
On laptop we don`t use touch screen but will be the same.
- Device:iphone and adroid
