Can you share you yaml?
In the config i have
lovelace:
resources:
- url: /hacsfiles/room-card/room-card.js
type: module
and tried without, no change
It never loads
Have you checked the installation steps?
And there are examples here : https://github.com/marcokreeft87/room-card
Yes I installed it twice. the card never shows up. I also added the examples manually. No card type configured. On resoursess it shows/ hacsfiles/room-card/room-card.js?hacstag=4544409490xx type javascript-modul
Ok, have you added it to your dashboard?
I got it working but I believe the instructions need a bit more clarity
My take:
- used github url to add as a custom repository in HACS, it shows nicely as a tile then (after download)
- added it as a MANUAL card, using your yaml example …this is not too clear, I was expecting a visual setup but…have done plenty without too
@vingerha hnx for the info. I am currently waiting for my Pull Request to complete so it will be in the HACS default repository list. Its weird that some cant download it from HACS. But that should make things a lot easier.
The card didn’t like the extra - inside the file.
I removed the first and now it works ( some space removed) and its ok
Thx
That’s basic yaml. But glad you found it!
Glad to inform you, the repo is now added to the HACS default repo and is now easier to find and install!
How to use the haptic option in room card?
It has the standard tap and hold actions, the haptic feedback is provided by the app.
You need to use the styles option
Can you plz post an example??
- type: custom:room-card
title: Mancave
entity: group.mancave_lights
icon: mdi:lightbulb-outline
styles:
color: red
But currently this applies to all entities in the header. If you want to apply it to each entity individually you will have to wait till I fix the bug in it
Thank you… Great work really loving the card…
Can we also change the colors of “Front” , ‘Driveway’, ‘Deck’ etc and also the font size ?
Please post an example…
Thank you for the great work.
You can now set the styles on any entity
styles:
color: red
But you have to have version 0.0.11
I just updated to 0.0.11. Restarted HA.
entities:
- entity: switch.speaker
styles:
color: green
toggle: true
state_color: true
The color of text “Nest” is not changing … what am I doing wrong ?
