Paul, is the recycle app connection working again.
How do you get the next pickup item sensor
To enable the today and tomorrow sensors set the upcomingsensor
to 1 in your config (docs)
I already have but not showing the next pickup item. In the Image from Ralfkroon you see a sensor Next pickup Item.
Sorry @rswennen, missed your message. But I can confirm the RecycleApp connection has started working again shortly after noting the problem, and has not failed anymore since …
I have created the nextpickitem and nextpickdays myself
Here is the code for the sensors
nextpickdays:
value_template: >-
{% set sensors = [
state_attr('sensor.circulus_berkel_papier', 'Days-until') | int,
state_attr('sensor.circulus_berkel_gft', 'Days-until') | int,
state_attr('sensor.circulus_berkel_pmd', 'Days-until') | int,
state_attr('sensor.circulus_berkel_restafval', 'Days-until') | int,
{{ sensors|min }}
nextpickitem:
value_template: >-
{% if state_attr('sensor.circulus_berkel_papier', 'Days-until') | int == states('sensor.nextpickdays') | int %} Papier
{% elif state_attr('sensor.circulus_berkel_gft', 'Days-until') | int == states('sensor.nextpickdays') | int %} GFT
{% elif state_attr('sensor.circulus_berkel_pmd', 'Days-until') | int == states('sensor.nextpickdays') | int %} PMD
{% elif state_attr('sensor.circulus_berkel_restafval', 'Days-until') | int == states('sensor.nextpickdays') | int %} Restafval
{% endif %}
One sensor is telling you how many days till next pickup and this sensor is needed to tell you the next pickup Item.
----Edit–
Fix the nextpickupitem
what if you have 2 pick-ups on the same day, the sensor will show one in this case?
yes only one. It is really rare to get 2 pickups a day
every 2 weeks here 2 pick-ups
restafval + papier
restafval + pmd
restafval + plastic
i have just the same every 2 weeks gft and pmd?
Hey @Pippyn,
Thank you so much for the great work. I tried to set up all. But got the following message:
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 471, in async_device_update
await self.hass.async_add_executor_job(self.update) # type: ignore
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/afvalbeheer/sensor.py", line 1367, in update
collection = self.data.collections.get_first_upcoming_by_type(self.waste_type)
File "/config/custom_components/afvalbeheer/sensor.py", line 443, in collections
return self.collector.collections
AttributeError: 'NoneType' object has no attribute 'collections'
My sensor Yaml:
- platform: afvalbeheer
wastecollector: Twente Milieu
resources:
- restafval
- gft
- papier
- pmd
postcode: 0000XX
streetnumber: 00
upcomingsensor: 0
dateformat: '%d-%m-%Y'
dateonly: 0
dateobject: 0
nameprefix: 1
builtinicons: 0
disableicons: 0
dutch: 0
Can you help me figure out what is wrong?
Can you DM me an address that is in your neighbourhood? So I can do some tests?
I have the same situation here but the below config results in 5 sensors with the 5 states
sensor.recycleapp_vandaag > geen
sensor.recycleapp_morgen > restafval, pmd
sensor.recycleapp_papier > 23-11-2020
sensor.recycleapp_pmd > Morgen, 16-11-2020
sensor.recycleapp_restafval > Morgen, 16-11-2020
wastecollector: RecycleApp
resources:
- restafval
- papier
- pmd
postcode: 1234
streetname: xxxxx
streetnumber: xx
upcomingsensor: 1
dateonly: 0
dateobject: 0
dayofweek: 1
alwaysshowday: 0
nameprefix: 1
builtinicons: 1
disableicons: 0
dutch: 1
# printwastetypes: 1
According to me this is how I should expect it.
Another thing I saw is that in the recycle app I only have 1 collection on the “home” screen, but when I go to the calendar, I have the 2 collections that appear… Could be linked perhaps?
I have sent a message through the reycle app to the developers
I think my email worked
Seems they fixed the bug in the recycleapp API
How do you add Nog 0 dag(en) to the card?
This looks nice
Tnx
card:
show_header_toggle: false
type: entities
filter:
include:
- attributes:
Days-until: < 3
entity_id: sensor.recycle*
options:
secondary_info: 'Nog [[ {entity}.attributes.Days-until ]] dag(en)'
type: 'custom:secondaryinfo-entity-row'
show_empty: false
sort:
method: state
numeric: true
type: 'custom:auto-entities'
which gives then this:
Sorts the most upcoming event, and only the ones due in 3 days (but this you can change of course )
I just installed the code on my HA (Docker image) and get these errors in the log of HA
Logger: homeassistant
Source: custom_components/afvalbeheer/sensor.py:927
First occurred: 9:14:44 PM (1 occurrences)
Last logged: 9:14:44 PM
Error doing job: Task exception was never retrieved
File "/config/custom_components/afvalbeheer/sensor.py", line 437, in async_update
await self.collector.update()
File "/config/custom_components/afvalbeheer/sensor.py", line 949, in update
await self.hass.async_add_executor_job(self.__fetch_address)
File "/config/custom_components/afvalbeheer/sensor.py", line 927, in __fetch_address
response = requests.get(
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 900, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.8/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Is there anyone who knows what i’m doing wrong?
Please make a new issue at my github, with these errors, your config and an address in your neighbourhood.
