To do that I can only think to trigger on the state of alarmo changing to armed_way and then check the cleaning status, but that wouldn’t work when cleaning is started later when the alarm is already armed_away.
I’ve created this flow for now and I think it may avoid those potential issues. Not sure if there’s something else I haven’t considered.
That sounds like a decent workaround. Not sure how long it would take me to figure out how to do that so I’ll try the custom_bypass way for now. Thanks for your help.
The json looks fine to me.
I assume you enabled MQTT in Alarmo, and the topic is correct? You also need to match the command with what’s configured here (by default arm_away should be accepted).
Otherwise, check the HA logs or subscribe to the alarmo/event topic to get more insight in why arming failed (maybe a sensor is blocking the arming)?
From what I can see your flow should take cover all scenarios, I’d say just let it run for a few weeks
Thanks for enjoying my project! I appreciate your donation
Let me know if you’re missing anything
@neliss and hello all, this may have been answered before and I am sorry if it has been. I am very new to home assistant and moved here from smarrthings a few weeks ago. On the push notifications that you can setup on the dashboard. Is there anyway to get them to say door “open” rather than door “on”? Thank you ahead of time for your response.
Hey Guys,
While trying to make a push notification (in this case for an android device) I can’t add an image like I can add it under regular automation - push notification ( notify. )
This might be a user error but I still would like to get some help, Thanks.
What I’m trying to write that is working in regular automation:
service: notify.addnamehere
title: ALARM
message: The Alarm Is Disarmed
image: /local/Notification_PNGs/nameofimage.png
@neliss are you aware that alarmo will cause the folloing warning in the next release (2022.6)?
WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that uses deprecated async_get_registry to access device registry, use async_get instead. Please report issue to the custom component author for alarmo using this method at custom_components/alarmo/init.py, line 58: device_registry = await dr.async_get_registry(hass)
Are you using a pin code embedded into your script? Ideally I’d like to say “disarm alarm” and it prompt me for the code. It seems very insecure otherwise.
Did you update to HA 2022.6?
I noticed that this version contains some changes which break the notifications in Alarmo.
The HA logs should give you errors as well.
I’m working on a new release to tackle this issue.
In my opinion this is currently the biggest (and most frequently asked) missing feature (correct me if I’m wrong) so I would like to pick it up for a next release.
PS: I’m new to Github discussions, but it seems like a great place to pitch ideas for bigger feature requests. So if you have an idea for a next step, feel free to open a discussion topic for it.
Hey Guys,
title: ALARM
does anyone try to add an image to a notification via Alarmo?
