Version 0.0.4 custom_components disponible.
https://github.com/dckiller51/bodymiscale
How i can configure Miscale with ESP?
Look here.
Sorry but i don’t understand
I cannot add new integration on my ESP
Do you have at least this :
esp32_ble_tracker:
- platform: xiaomi_miscale2
The sensor depends on ble_tracker.
I use ESP from HA
I should install something else?
For now you must use the Esphome DEV version with in the configuration tab
esphome_version: 'dckiller51:dckiller51'
The version will normally be available soon in the stable version of esphome
Sorry i don’t know how to install this version
Can You help me? If yes i can do some test for integration.
Hello, you need to install the dev version of esphome. Then in the configuration tab you delete everything and you must put esphome_version: ‘dckiller51:dckiller51’
Then it works as for the stable version except that it will use files from my github.
Dear dckiller,
I installed the dev version of ESPHome and put the dckiller51:dckiller51 in the configuration tab:
But in the log I have the following errors:
[23:36:12] INFO: Installing esphome version 'dckiller51:dckiller51' (https://github.com/dckiller51/esphome/archive/dckiller51.zip)...
Collecting https://github.com/dckiller51/esphome/archive/dckiller51.zip
Could not install packages due to an EnvironmentError: 404 Client Error: Not Found for url: https://codeload.github.com/dckiller51/esphome/zip/dckiller51
[23:36:13] FATAL: Failed installing esphome pinned version.
[cont-init.d] 30-esphome.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Any help about this?.
Thanks,
Jose
Hello, you can switch to the official DEV version.The integration has since been validated.
Sorry dckiller51, but, how I can install the officla DEV version?, to install dev version is necessary to add the following repository (accoding with the esphome docs):
To install the dev version of ESPHome:
- In Hass.io: Add the ESPHome repository GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on https://github.com/esphome/hassio in Add-on store → Repositories. Then install the add-on
ESPHome Dev
But is impossible to me to add this repository, and I cant find the ESPHome Dev available…
If I select:
Also, is not working, and the log shows:
[17:27:41] INFO: Installing esphome version 'dev' (https://github.com/esphome/esphome/archive/dev.zip)...
Collecting https://github.com/esphome/esphome/archive/dev.zip
Downloading https://github.com/esphome/esphome/archive/dev.zip (2.0MB)
esphome requires Python '>=3.7,<4.0' but the running Python is 3.6.9
[17:27:43] FATAL: Failed installing esphome pinned version.
Sorry for my understanding…
Jose
Finally I installed the dev version thank to your reply. But I continue with the error with the dckiller51:dckiller51 version:
[23:42:22] INFO: Installing esphome version 'esphome_version:dckiller51:dckiller51' (https://github.com/esphome_version/esphome/archive/dckiller51.zip)...
Collecting https://github.com/esphome_version/esphome/archive/dckiller51.zip
Could not install packages due to an EnvironmentError: 404 Client Error: Not Found for url: https://github.com/esphome_version/esphome/archive/dckiller51.zip
[23:42:23] FATAL: Failed installing esphome pinned version.
The dckiller51 version no longer exists. it has been integrated into the official dev. you must not specify a version in the configuration.
Dear dckiller,
Thanks a lot, the integration works perfectly now, I can read all the data from my BodyScale.
Thanks,
Hi @dckiller51,
Thanks again for a new great integration.
I use Passive BLE Monitor integration and it added automatically my Mi Body Composition Scale 2. Thanks to this I can read the impedance and the non-stabilized and stabilized weight given by the scale.
I also added your component using HACS and following your steps explained on GitHub.
How do I make the link between both? Is there anything else to do to make it work?
Right now, I see bodymiscale entities but not the weight and impedance entities.
Does that answer your question?
Actually, I understood after posting this that I need to give the same entity names for the weight and impedance between the bodymiscale and the blemonitor integrations.
this is my card for MIScale:
You can make template sensors for the attributes if you change it to “easy readable” format in the /config/custom_components/bodymiscale/const.py.
For example ATTR_FATMASSTOLOSE = “Fat mass to lose” has to be changed to ATTR_FATMASSTOLOSE = “fat_mass_to_lose”
There is only one question left, which is the right evaulation, the results in the official app Zepp or these ones? Because lot of result differrent between the results.
