Hello, I share my red node to select the person who weighs himself via the action notification.
As we can only do 3 actions maximum I split the users with a weight greater or less than 50kg
You can then use the bodimiscale custom components to use your data
https://community.home-assistant.io/t/custom-component-bodymiscale-for-xiaomi-miscale-1-2-esphome-or-ble-monitor/253542/8
[{"id":"449ac5cc.7a0abc","type":"tab","label":"Balance Connectée","disabled":false,"info":""},{"id":"54855646.8cde28","type":"server-state-changed","z":"449ac5cc.7a0abc","name":"Poids","server":"a8c279c8.be8be8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.xiaomi_mi_scale_weight","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":70,"y":80,"wires":[["ce82deff.cb494"]]},{"id":"21841a17.717626","type":"api-call-service","z":"449ac5cc.7a0abc","name":"Notification","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_aurelien","entityId":"","data":"{\"title\":\"Balance Connectée\",\"message\":\"Qui est sur la balance avec le poids de {{ payload }} kg ?\",\"data\":{\"actions\":[{\"action\":\"Sacha\",\"title\":\"Sacha\"},{\"action\":\"Noham\",\"title\":\"Noham\"}]}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":60,"wires":[[]]},{"id":"7be24aa0.3bfe84","type":"server-events","z":"449ac5cc.7a0abc","name":"Réponse notification","server":"a8c279c8.be8be8","event_type":"mobile_app_notification_action","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"x":110,"y":560,"wires":[["6a5e651d.7ac02c"]]},{"id":"6a5e651d.7ac02c","type":"switch","z":"449ac5cc.7a0abc","name":"","property":"payload.event.action","propertyType":"msg","rules":[{"t":"eq","v":"Aurelien","vt":"str"},{"t":"eq","v":"Siham","vt":"str"},{"t":"eq","v":"Theo","vt":"str"},{"t":"eq","v":"Sacha","vt":"str"},{"t":"eq","v":"Noham","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":290,"y":560,"wires":[["8adcb35.40ec25","4e1d75ec.9ef92c"],["2f38895c.6535f6","22867545.4e654a"],["4ac5d546.51219c","c730db95.5511d8"],["9d0744e0.dd8b38","a7ffae54.6dcd2"],["74cce82a.7361d8","fd3f8b8f.91b938"]]},{"id":"ce82deff.cb494","type":"switch","z":"449ac5cc.7a0abc","name":"Poids 50 kg","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"50","vt":"str"},{"t":"gte","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":230,"y":80,"wires":[["21841a17.717626"],["46ea1914.b76bb8"]]},{"id":"46ea1914.b76bb8","type":"api-call-service","z":"449ac5cc.7a0abc","name":"Notification","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_aurelien","entityId":"","data":"{\"title\":\"Balance Connectée\",\"message\":\"Qui est sur la balance avec le poids de {{ payload }} kg ?\",\"data\":{\"actions\":[{\"action\":\"Aurelien\",\"title\":\"Aurelien\"},{\"action\":\"Siham\",\"title\":\"Siham\"},{\"action\":\"Theo\",\"title\":\"Theo\"}]}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":120,"wires":[[]]},{"id":"e0f48aa8.4ebc68","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Poids Sacha","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weight Sacha"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weight-kilogram"},{"property":"unit_of_measurement","value":"kg"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":710,"y":620,"wires":[[]]},{"id":"d0fe40dd.aa4ad","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Poids Noham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weight Noham"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weight-kilogram"},{"property":"unit_of_measurement","value":"kg"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":720,"y":740,"wires":[[]]},{"id":"d40dcb04.d1d6a8","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Poids Théo","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weight Théo"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weight-kilogram"},{"property":"unit_of_measurement","value":"kg"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":710,"y":500,"wires":[[]]},{"id":"fd8f72be.6c546","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Poids Siham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weight Siham"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weight-kilogram"},{"property":"unit_of_measurement","value":"kg"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":710,"y":380,"wires":[[]]},{"id":"d784d1fc.3574a","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Poids Aurélien","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weight Aurélien"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weight-kilogram"},{"property":"unit_of_measurement","value":"kg"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":700,"y":260,"wires":[[]]},{"id":"645c197d.376198","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Impedance Siham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Impedance Siham"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:omega"},{"property":"unit_of_measurement","value":"ohm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":730,"y":440,"wires":[[]]},{"id":"5be0f792.71a698","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Impedance Théo","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Impedance Théo"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:omega"},{"property":"unit_of_measurement","value":"ohm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":730,"y":560,"wires":[[]]},{"id":"a6f7df44.e392","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Impedance Aurélien","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Impedance Aurélien"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:omega"},{"property":"unit_of_measurement","value":"ohm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":740,"y":320,"wires":[[]]},{"id":"445a7773.55e788","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Impedance Sacha","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Impedance Sacha"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:omega"},{"property":"unit_of_measurement","value":"ohm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":730,"y":680,"wires":[[]]},{"id":"ea3bee11.4232d","type":"ha-entity","z":"449ac5cc.7a0abc","name":"Impedance Noham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Impedance Noham"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:omega"},{"property":"unit_of_measurement","value":"ohm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":730,"y":800,"wires":[[]]},{"id":"8adcb35.40ec25","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Poids balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_weight') | float }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":500,"y":260,"wires":[["d784d1fc.3574a"]]},{"id":"4e1d75ec.9ef92c","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Impedance balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_impedance') | int }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":510,"y":320,"wires":[["a6f7df44.e392"]]},{"id":"22867545.4e654a","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Impedance balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_impedance') | int }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":510,"y":440,"wires":[["645c197d.376198"]]},{"id":"2f38895c.6535f6","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Poids balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_weight') | float }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":500,"y":380,"wires":[["fd8f72be.6c546"]]},{"id":"c730db95.5511d8","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Impedance balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_impedance') | int }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":510,"y":560,"wires":[["5be0f792.71a698"]]},{"id":"4ac5d546.51219c","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Poids balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_weight') | float }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":500,"y":500,"wires":[["d40dcb04.d1d6a8"]]},{"id":"a7ffae54.6dcd2","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Impedance balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_impedance') | int }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":510,"y":680,"wires":[["445a7773.55e788"]]},{"id":"9d0744e0.dd8b38","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Poids balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_weight') | float }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":500,"y":620,"wires":[["e0f48aa8.4ebc68"]]},{"id":"fd3f8b8f.91b938","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Impedance balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_impedance') | int }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":510,"y":800,"wires":[["ea3bee11.4232d"]]},{"id":"74cce82a.7361d8","type":"api-render-template","z":"449ac5cc.7a0abc","name":"Poids balance","server":"a8c279c8.be8be8","template":"{{ states('sensor.xiaomi_mi_scale_weight') | float }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":500,"y":740,"wires":[["d0fe40dd.aa4ad"]]},{"id":"a8c279c8.be8be8","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
