It is still recommended to use this method only if your device is not supported by a “native” play controller. For example, if you have Android TV, use Android TV instead as that gives better experience (no need to have app launched before hitting play and more).
Having a play with this and some thoughts and observations. This works like a charm with my Shield and the android TV integration. It’s very quick and playback starts almost instantly.
My movie library is over 1,000 movies so without any limits it makes the browser very unresponsive for a while, but setting the limit doesn’t really make a lot of sense if you want to see all movies.
What would be really cool is rather than configuring a libary, we could configure recently added or continue watching instead. Not sure how feasible that is.
This doesn’t work in the mobile app, right? All i get is a spinning circle and nothing else.
For TV shows I tend to use shuffle quite a lot, so if a shuffle button could be added that would be awesome.
Planned, check OP. This will be resolved either with search working even with maxCount or filters (recently added etc.).
It does, if you are using https for hass, you also need to use https for plex (i need to add an error handler for that case)
Good idea, will add it to planned features.
Currently I am very busy with work project so unfortunately this card and my other opensource projects are going to get put into sideline for a while (few weeks, maybe a month or two). But I will review and accept any PRs! Adding filters for example etc are a fairly easy and quick thing.
Yup just hopped on Discord to see the dicussion and have now set my internal URL in the HA app to my internal instance, as I also use Nabu Casa. That worked and it’s now showing up correctly in the app.
My plex server is in the cloud in a Seedbox server and runs very very well. How do I configure the integration to point to the cloud service and not local IP address?
Cheers
Yes I did try the host however it does not seem to be pulling the data down to HA. I have only setup movies so far and it shows “Search Movies” search box with a orange circle going round and round like it is searching on the new created tab on Home Assistant dashboard? So i guess that means it is not pulling data from Plex server.
Any other thoughts on a possible reason would be appreciated
I’m not a programmer or developer so not sure what i am looking for. Only ref that I can see that makes any sense is reference to the token. I have checked to ensure token is correct and it is correct. Not sure what else i can do.
Do you know of any other user who are using your Custom component who may have a plex server in the cloud?
Glad to hear you got it working, yes, follow readme, you can add androidtv if you have androidtv, kodi if you have kodi, or plexPlayer if you have anything else. There are detailed instructions for each.
Smart loading was just added to the newest version, this means you can stop using maxCount because of performance reasons. It will now handle thousands of items in library smoothly.
