I’m having a problem here because my covers are not a Device, they are an Entity.
How can I get around this?
Entities are correct. You say you are having problems, what’s not working are there any relevant errors in home-assistant.log?
I always try to fix things by my self because I like to know how they work. As I’m new to HA sometimes it’s not easy.
For example, I have my covers like this "“switch.persiana_do_escritorio”. I don’t have any idea on what to place in “script.office_cover_ up” for my “switch.persiana_do_escritorio”.
Same with “office_cover”…
I know that the example above it’s all I need, but I don’t understand where “script.office_cover_up” comes from…
Sorry about my English. My mother language it’s Portuguese.
Lets see if we can get you over the line by going back to the start
The device you are trying to control is a shutter, and you want to control it through a Broadlink controller. I’m guessing you want a nice button on Home Assistant front end that you can click on and the shutter opens/closes. To do that we:
Add an entity or a button to the front end selecting a Cover entity, the cover is called ‘cover.office_cover’, that cover entity is created by using the ‘cover_rf_time_based’ platform.
- platform: cover_rf_time_based
devices:
office_cover_time_based:
travelling_time_up: 17
travelling_time_down: 17
close_script_entity_id: script.office_cover_down
stop_script_entity_id: script.office_cover_stop
open_script_entity_id: script.office_cover_up
You want the cover to open so when you click on the open or up arrow on the front end it will call ‘script.office_cover_up’.
office_cover_up:
sequence:
- service: remote.send_command
entity_id: remote.office_broadlink
device: office_cover
command: open
You can see that script is using the service ‘remote.send_command’, that’s how HA communicates with the Broadlink device. In particular it’s communicating with the broadlink device called ‘remote.office_broadlink’. It’s sending that device a command to ‘open’ the ‘office_cover’.
Well not quite, first it goes and looks up the broadlink codes file, it works out what the RF code it needs to use for command ‘open’.
"version": 1,
"key": "broadlink_remote_780f77634fbf_codes",
"data": {
"office_cover": {
"close": "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",
"open": [
"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",
"stop": "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"
NOTE: there are different ways you can setup RF codes for the Broadlink platform in HA, it’s possible yours is slightly different and you don’t have the broadlink codes file, you might need to pass the code directly from within the ‘office_cover_up’ script.
You might want to review Broadlink - Home Assistant if our still struggling with this last part.
Hope this helps!
First of all I would like to thank you @Eoin Eoin for the time you spent writing this post!! AWESOME!!
This is one of the reasons I moved from Homebridge to HA. Great community!!!
I appologise if I was not clear about what I need. I already have all my covers working, what I would like to implement its the time based and “Stop” functions…
As you can see I already have the “Entity button” for my office cover (Persiana do Escritório).
What I don’t get (I understood your explanation) is where I should replace your “office_cover” for my “persiana_do_escritorio”… (dumb me)!!!
Here’s my config:
configuration.yaml
# Includes
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
switch: !include switches.yaml
cover: !include cover.yaml
cover.yaml:
devices:
persiana_do_escritorio_time_based:
name: Persiana do Escritório
travelling_time_up: 20
travelling_time_down: 20
close_script_entity_id: script.persiana_do_escritorio_down
stop_script_entity_id: script.persiana_do_escritorio_stop
open_script_entity_id: script.persiana_do_escritorio_up
scripts.yaml
office_cover_up:
sequence:
entity_id: remote.rm_pro_remote
device: persiana_do_escritorio
command: open
office_cover_down:
sequence:
command: close
office_cover_stop:
sequence:
command: stop
and broadlink_remote_XXXXXXXXX_codes
"version": 1,
"key": "broadlink_remote_XXXXXXXXX_codes",
"data": {
"persiana_do_escritorio": {
"close": "sgB4AC8RMRIxETISMhIOMDESMhIPLw8vDy8PLzESDy8yEg8wDi8yEjMRDzAyEg8wDzAOMA4AAcoxETISMhIyEjMSEDAyEjMSDzAPMA8wDjAyEg8xMhIPMA8wMhIiIw8xMhMPMA8wDzAOAAHNMRIyEhQEBCwzEjMdDwAF3A=="
"open": "sgB4AC8RMRIxETISMhIOMDESMhIPLw8vDy8PLzESDy8yEg8wDi8yEjMRDzAyEg8wDzAOMA4AAcoxETISMhIyEjMSEDAyEjMSDzAPMA8wDjAyEg8xMhIPMA8wMhIiIw8xMhMPMA8wDzAOAAHNMRIyEhQEBCwzEjMdDwAF3A=="
"stop": "sgCKAA4uDi8OLjESDi8xEw4wDi8xEjISDzAPLzISDzAOMA4AAcoxEjETMhIyEzITDzAyEzMSDzEOMQ4wDzAyEw4xMhMOMQ8wMhMzEg8xDzAzEg8xDzAPAAHOMRMyEjITMxMzEw8xMxIwFg8xDzEOMQ8wMxIQMDMTDzAPMTMSNBIPMRAwMxIPMg8wDwAF3AAAAAAAAAAAAAAAAAAA"
For some reason nothing happens when I click the cover buttons.
The ones I have as switches are working just fine!
I’m using HA for about a month. I have a LOT to learn…
The good news is I think were nearly there! Try changing your scripts.yaml to this:
persiana_do_escritorio_up:
sequence:
command: open
persiana_do_escritorio_down:
sequence:
command: close
persiana_do_escritorio_stop:
sequence:
command: stop
Not yet…
Logger: homeassistant.components.script.persiana_do_escritorio_down
Source: components/broadlink/remote.py:194
Integration: Script (documentation, issues)
First occurred: 14:23:19 (2 occurrences)
Last logged: 14:23:27
persiana_do_escritorio_down: Error executing script. Unexpected error for call_service at pos 1: Command not found: 'close'
File "/usr/src/homeassistant/homeassistant/components/broadlink/remote.py", line 192, in _extract_codes
codes = self._codes[device][cmd]
KeyError: 'persiana_do_escritorio'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 363, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 563, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1481, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1516, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 726, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/broadlink/remote.py", line 275, in async_send_command
code_list = self._extract_codes(commands, device)
File "/usr/src/homeassistant/homeassistant/components/broadlink/remote.py", line 194, in _extract_codes
raise ValueError(f"Command not found: {repr(cmd)}") from err
ValueError: Command not found: 'close'
Logger: homeassistant.components.broadlink.remote
Source: components/broadlink/remote.py:277
Integration: Broadlink (documentation, issues)
First occurred: 14:23:10 (5 occurrences)
Failed to call remote.send_command: Command not found: 'open'
Failed to call remote.send_command: Command not found: 'close'
Failed to call remote.send_command: Command not found: 'stop'
Damn! What am I missing?
Sorry to be waisting your time!|
Whre’s my saviour @Eoin ??
Can you paste in your full scripts.yaml file again?
The error is suggestion the script ‘persiana_do_escritorio_down’ does not have the command ‘close’ set.
Sure…
sequence:
command: open
sequence:
command: close
sequence:
command: stop
That code for the script looks perfect. I’m confused!
Anyone else have any suggestions?
Did I mention that “persiana_do_escritorio” it’s an entity and not a device on my HA?
This is what I get after pressing a button:
First occurred: 20:59:36 (6 occurrences)
Last logged: 23:42:23
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 404, in _async_run
return await self.script.async_run(variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1209, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 345, in async_run
await self._async_step(log_exceptions=False)
await service_task
task.result()
await coro
await result
ValueError: Command not found: 'open'
I see at the end…
Does it help?..
Anyone? I’m stuck in here!
Nice custom component, i ‘am using it with my somfy covers which i control met rfxtrx.
Is there a way to restore the State after a restart of home assistant?
Hi, thanks for your Great work! It was working great for me until i made latest Update.
I hade a Register called cover and all covers was inside. In total I have 4. Now all are gone and i can t add new card.
When i search the entitys i only can find 1 of 4 covers… only the first one can be found. Her is my Config:
# Rolladen Schalter
cover:
devices:
my_room_cover_time_based:
travelling_time_down: 19
close_script_entity_id: script.rf_myroom_cover_down
stop_script_entity_id: script.rf_myroom_cover_stop
open_script_entity_id: script.rf_myroom_cover_up
aliases:
- my_room_cover_time_based
devices:
close_script_entity_id: script.lina_rolladen_runter
stop_script_entity_id: script.lina_rolladen_stop
open_script_entity_id: script.lina_rolladen_hoch
aliases:
devices:
name: Wohnzimmer Links Rolladen
travelling_time_up: 36
travelling_time_down: 24
close_script_entity_id: script.wohnzimmer_links_runter
stop_script_entity_id: script.wohnzimmer_links_stop
open_script_entity_id: script.wohnzimmer_links_hoch
aliases:
devices:
name: Wohnzimmer Rechts Rolladen
travelling_time_up: 34
close_script_entity_id: script.wohnzimmer_rechts_runter
stop_script_entity_id: script.wohnzimmer_rechts_stop
open_script_entity_id: script.wohnzimmer_rechts_hoch
aliases:
I’m still trying to find why it doesn’t work with my HA…
Someone could please help me?
It should be:
# Rolladen Schalter
cover:
devices:
my_room_cover_time_based_1:
my_room_cover_time_based_2:
my_room_cover_time_based_3:
my_room_cover_time_based_4:
Thanks it is working again!!
Am I the only one that cannot make this run?
