You messed something up completely. Impossible for us to determine what.
Delete everything, start from zero, and read each step from the description very carefully.
@rn1, it seems by your error your broadlink is processing the literal word âopenâ instead of the value open refers to in your broadlink_remote_xxx file. Try just putting the actual code in your script. You can do that by prepending âb64:â to it. Test it in developer tools->services. The screenshot below works on mine. Of course use your command and not mine
Thank you very much @steelincable !!
When you mentioned b64 I took a look at my codes and realised that I was using the old codes from my old Homebridge config. Everything itâs working now!! Stupid me!!!
Thank you very much!!
I just have one more problemâŠ
My first cover works fine but when I add the other ones some went to ENTETIES but some didnât.
And the one after the firts one donât respond.
For some reason only the first 4 are in ENTETIES:
- Persiana do Escritorio (works)
- Persiana da Cozinha (doesnât work)
- Persiana da Direita (doesnât work)
- Persiana da Esquerda (doesnât work)
I think I didnât add them correctlyâŠ
my cover.yaml
- platform: cover_rf_time_based
devices:
persiana_do_escritorio_time_based:
name: Persiana do EscritĂłrio
travelling_time_up: 20
travelling_time_down: 20
close_script_entity_id: script.persiana_do_escritorio_down
stop_script_entity_id: script.persiana_do_escritorio_stop
open_script_entity_id: script.persiana_do_escritorio_up
persiana_da_cozinha_time_based:
name: Persiana da Cozinha
travelling_time_up: 17
travelling_time_down: 17
close_script_entity_id: script.persiana_da_cozinha_down
stop_script_entity_id: script.persiana_da_cozinha_stop
open_script_entity_id: script.persiana_da_cozinha_up
persiana_esquerda_time_based:
name: Persiana da Esquerda
close_script_entity_id: script.persiana_esquerda_down
stop_script_entity_id: script.persiana_esquerda_stop
open_script_entity_id: script.persiana_esquerda_up
persiana_direita_time_based:
name: Persiana da Direita
close_script_entity_id: script.persiana_direita_down
stop_script_entity_id: script.persiana_direita_stop
open_script_entity_id: script.persiana_direita_up
persiana_do_quarto_time_based:
name: Persiana do Quarto
close_script_entity_id: script.persiana_do_quarto_down
stop_script_entity_id: script.persiana_do_quarto_stop
open_script_entity_id: script.persiana_do_quarto_up
persiana_do_quarto_da_lara_time_based:
name: Persiana do Quarto da Lara
close_script_entity_id: script.persiana_do_quarto_da_lara_down
stop_script_entity_id: script.persiana_do_quarto_da_lara_stop
open_script_entity_id: script.persiana_do_quarto_da_lara_up
persiana_do_quarto_de_brincar_time_based:
name: Persiana do Quarto de Brincar
close_script_entity_id: script.persiana_do_quarto_de_brincar_down
stop_script_entity_id: script.persiana_do_quarto_de_brincar_stop
open_script_entity_id: script.persiana_do_quarto_de_brincar_up
my scripts.yaml
persiana_do_escritorio_up:
sequence:
- service: remote.send_command
entity_id: remote.rm_pro_remote
device: persiana_do_escritorio
command: open
persiana_do_escritorio_down:
sequence:
command: close
persiana_do_escritorio_stop:
sequence:
command: stop
persiana_da_cozinha_up:
sequence:
device: persiana_da_cozinha
command: open
persiana_da_cozinha_down:
sequence:
command: close
persiana_da_cozinha_stop:
sequence:
command: stop
persiana_esquerda_da_sala_up:
sequence:
device: persiana_esquerda_da_sala
command: open
persiana_esquerda_da_sala_down:
sequence:
command: close
persiana_esquerda_da_sala_stop:
sequence:
command: stop
persiana_direita_da_sala_up:
sequence:
device: persiana_direita_da_sala
command: open
persiana_direita_da_sala_down:
sequence:
command: close
persiana_direita_da_sala_stop:
sequence:
command: stop
persiana_do_quarto_up:
sequence:
device: persiana_do_quarto
command: open
persiana_do_quarto_down:
sequence:
command: close
persiana_do_quarto_stop:
sequence:
command: stop
persiana_do_quarto_da_lara_up:
sequence:
device: persiana_do_quarto_da_lara
command: open
persiana_do_quarto_da_lara_down:
sequence:
command: close
persiana_do_quarto_da_lara_stop:
sequence:
command: stop
persiana_do_quarto_de_brincar_up:
sequence:
device: persiana_do_quarto_de_brincar
command: open
persiana_do_quarto_de_brincar_down:
sequence:
command: close
persiana_do_quarto_de_brincar_stop:
sequence:
command: stop
my broadlink_remote_XXXXXXXXXX_codes
"version": 1,
"key": "broadlink_remote_XXXXXXXXXX_codes",
"data": {
"persiana_do_escritorio": {
"close": "sgCsACURMREyEg8vMhEzERAvEC4QLw8vMhEQLzMREC8QLzMRMxIQLxAvEDAyERAwDwABzTIRMxE0ETQSNBEQMDQRNREQMBAwDzAPMDMSEC80EhAwDzA0ETQSEDAQMBAvNBERMA8AAdEyEjMRNBI0EjUREDE0EjQSEDEPMQ8wEDA0ERAwNBIQMBAwNBI1ERAxEDAQMDQSDzEQAAHSMxIzEjQSNBI1EhAxNBI1EhAABdwAAAAAAAAAAAAAAAA=",
"open": "sgDgADEQMREyETIRMxEQLjMRMxEQLw8vDy8PLzIREC8yEg8vEC4zETMREDAzERAvEC4QLxAAAcoyEDMRMxE0ETQREC80ETQREDAQLw8wDy8zEhAvMxEQMA8wMxE0EhAvNBEQMBAvEC8QAAHNMhEzETQRNBI0ERAwNBE1ERAwEC8QMA8vNBEQMDQREDAQLzQRNBIQMDQREDAQMBAvEAABzzMRMxE0ETURNRERLzURNRERMBAvEDAPMDQREDA0ERAwEDA0ETUSEDA0EhAwEDAQLxAAAdEyEjMRNRE1ETURETAJAAXcAAAAAAAAAAA=",
"stop": "sgCKAA4uDi8OLjESDi8xEw4wDi8xEjISDzAPLzISDzAOMA4AAcoxEjETMhIyEzITDzAyEzMSDzEOMQ4wDzAyEw4xMhMOMQ8wMhMzEg8xDzAzEg8xDzAPAAHOMRMyEjITMxMzEw8xMxIwFg8xDzEOMQ8wMxIQMDMTDzAPMTMSNBIPMRAwMxIPMg8wDwAF3AAAAAAAAAAAAAAAAAAA"
"version": 2,
"key": "broadlink_remote_b4430dfbd5d4_codes",
"data": {
"persiana_da_cozinha": {
"close": "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",
"open": "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",
"stop": "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"
"version": 3,
"data": {
"persiana_da_esquerda": {
"close": "sgg0ACIOCiUKJQolIQ8KJQoAAVwKJSEPCSUhDwolIQ8KJQolIQ4hDyIOIQ8hDyIPCiUKJSEPCiUAAAAA",
"open": "sjk0ACEPIg4KJQokIQ8KJSIPCiUiDgolCiUKJQoAAVsKJSEPCiQhDgolIQ4KJQolIQ4hDiEOIQ4AAAAA",
"stop": "sgo0AAolIQ8KJSIOCiUhDwolCiUhDiIOIQ8hDyIPIg4KJQolIQ8KJSEPCiUKJSIOCiUKJQoAAV0AAAAA"
"version": 4,
"data": {
"persiana_da_direita": {
"close": "sgo0AB4NHg0eDAohCSEJIR4NCiEJIQkhCSEeDQkhCSEJIR4MCSEJIR4NCSEJIQohHg0JIQkAATsAAAAA",
"open": "sgo0AAohCiEeDAohCSEJIQkhHg0JIQkhCiEeDAkhCSEeDAkhHw0JIQkhCiEJAAE7HgweDR4NCSEAAAAA",
"stop": "sgk0AAkhCiAKIR4MCiEJIQkhCSEeDQkhCSEJIR4NCSEJIR4NCiEJIR4NCSEJIQkAATseDB8NHg0AAAAA"
"version": 5,
"data": {
"persiana_do_quarto": {
"close": "sgCyAA0AAZ8pDyoPDSoNKSoPKg8rDyoPKhANKSsPKg8rDysPKg8OKgwqKw8rDw0pDikOKSsPDSoNAAGhKg4rDw0qDSoqECoPKw8rDysPDSorDisQKw4rDysQDSoNKisPKw8NKg0qDSorDw0qDQABoSoPKw8NKg4pKw8rDysPKw8rDw0qKw8rDysQKhArDw0qDSorDysPDioNKg0qKw8NKwwAAaIqDysPDioMKisPKw8rDxsABdwAAAAAAAA=",
"open": "sgD6ACoPKg4OKQ0qKg4rDisOKw8rDg4pKg8rDisPKw4rDw0pDiorDisODikrDw4pDikOKQ4AAaArDisODikOKSwOKw8qDysOLA4OKSsPKw4sDisPKw8OKQ4pKw8rDg4qKw4OKQ4qDSoNAAGhKw4sDg4qDSkrDysOLA4rDysPDikrDysOLA4sDiwODioNKisOLA4OKisPDSoOKQ4pDgABoSsPKw4OKQ4pLA4rDysPKw4sDg4qKw4sDysPKw8rDw4pDiksDiwODiorDg4qDSoOKQ4AAaIrDisPDikOKSsOLA4sDiwOLA8NKisPKw8rDywOLA4OKQ8pKw8sDg4ABdwAAAAAAAAAAAAAAAAAAA==",
"stop": "sgAmAQwAAaApDyoPDSoNKioPKg8rDyoPKw8NKisPKhAqDysPKw8NKg0qKw8rDw0qDSorDw0qDSoNAAGhKg8rDw0qDSsqDyoPKxArDysPDSorDysPKw8rDysQDSoNKisPKw8NKg4qKhANKg0qDQABoSsPKw8NKg0qKw8rECoQKw8rDw4qKw8rDysPLA8rDw4qDSorDysPDioNKisPDioNKg0AAaIqDysPDSoOKisPKw8rDywPKw8OKisPKw8sDysPLA8NKw0qKw8rEA0qDSsrDg4qDSoOAAGhKw8rDw4pDiorDysPKw8sDysQDSorDywPKw8sDywPDSoOKisPKw8OKg0qLA8NKg0qDgABoioPKw8OKg0qKw8sDiwPKw8sDw0qLA4sDywPLAAF3AAA"
"version": 6,
"data": {
"persiana_do_quarto_da_lara": {
"close": "sgc0AAojIA0KIwojCiMgDQojCgABUQojCiMKIx8NIA0gDQojCiMKIwojIA0KIwojIA0KIyANIA0AAAAA",
"open": "sgg0ACANCiMgDQojIA0KIwoiCiIKAAFRCiIKIgoiIA0gDSANCiMKIgoiCiIgDQoiCiMgDQoiIA0AAAAA",
"stop": "sgg0ACANCiMKIwojCiIgDQojCiMgDQojIA0gDQojIA0KIwojIA0KIwojCgABUgojCiMKIyANIA0AAAAA"
"version": 7,
"data": {
"persiana_do_quarto_de_brincar": {
"close": "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",
"open": "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",
"stop": "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"
Progress! For your cover.yaml you have a 4 character indent under devices, I think that should be just 2. When I had issues I had to cut it out of the cover.yaml, restart HA, delete the entity, restart, readd, then restart again for it to show up right. Iâm also not a fan of referencing the broadlink codes like you are. Put them in the actual script with b64 and bypass that file altogether.
Thank you for your help!!!
I now have all Cover present. The only problem itâs my file
If I only save like this, the Escritorio cover works just fine:
"version": 1,
"key": "broadlink_remote_XXXXXXXXXXXX_codes",
"data": {
but if I add the others like this, none of them works:
"version": 1,
"data": {
"version": 2,
"key": "broadlink_remote_XXXXXXXXXXX_codes",
"data": {
"version": 3,
"data": {
"version": 4,
"data": {
"version": 5,
"key": "broadlink_remote_XXXXXXXXXXXXX_codes",
"data": {
"version": 6,
"data": {
"version": 7,
"data": {
Damn!! I always get this error:
Logger: homeassistant.components.script.persiana_do_escritorio_stop
Source: helpers/script.py:1337
Integration: Script (documentation, issues)
First occurred: 29 de maio de 2021 23:09:47 (12 occurrences)
Last logged: 12:06:49
persiana_do_escritorio_stop: Error executing script. Error for call_service at pos 1: Extra data: line 12 column 1 (char 986)
The problem is your broadlink code file format. Abandon it or fix it to look like mine âŠ
"version": 1,
"key": "broadlink_remote_a043b031d196_codes",
"data": {
"kitchen-rollerblinds": {
"close": "scCwBJKeBgALCgwJDAkMCQwJDAkMCgsKCwoLCgsKCwoLCgwJDAoLCgsKCwoLCgsKCwoLCgsKCwsKCgwKCwoLCgsKCwoLCgsKCwoLCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoKCwsKCwsKCgsLCgsKCwsKCgsLCgsKCwoLCgsLCgsKCwoLCwoLCgsLCgoLCwoLCgsLCgoLCwoLCgsKCwoLCgsLCgsKCwsKCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsLCgoLCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCwoLCgsKCwoLCgsLCgsLCgsKCwoLCgsKCwoLCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCgsLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsLCgoLCwoLCwoLCgsKCwoLCwoLCwoLCgsKCwoLCgsKCwsKCwoLCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsLCgsVFRUVFhQWFRUVFRUVFRYUVVQWKhUVFRUVFRYUFhUVFSoqFhUVFSoVFioVFSoqKyoqKisVFSoqFRYqFRUVFRUVFhUVFSoqKyoVFRUVFhUqKhUVFhQWFRUVFRUWFRUVFRUVFVVUFioVFRUVFhUVFRUVFRUrKhUVFRUrFRUqFRUrKioqKyoqFRUqKxUVKhYVFRUVFRUVFhUqKisqFRUVFRUWKioVFRUWFRUVFRUVFhUVFQAAAAAAAA==",
"open": "scCwBLadBgALCQwJDAkMCQwJDAkMCQwKCwoLCgsKCwoMCQwJDAkMCgsKCwoLCgsKCwoLCgsKDAkLCgwKCwkMCgsKCwoLCgsKCwoLCgsKDAoKCwsKCwoLCgsKCwoLCgsKCwoLCwsKCgsLCgsKCwoLCgsKCwoLCgsLCwoLCgsKCwoLCgsKCwoLCgwJCwoMCgsKCwoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoLCgwJDAoLCgsKCwoLCgsKCwoLCgsLCwoLCgsKCwoLCgsKCwoMCQwKCwoLCgsKCwoLCgsKCwoMCgsKCwoLCgsKCwoLCgsKDAoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKDAkMCgsKCwoLCgsKCwoMCQwJDAoLCgsKCwoLCgsKCwoMCQsLCwoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoMCgsKCwoLCgsKCwoLCgsKDAoLCgsKCwoLCgsKCwoLCgsKDAoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKDAkMCgsKCwoLCgsKCwoLCgsKDAoLCgsKCwoLCgsKCwoMCQsLCwoLCgsKCwoLCgsKCwoMCQwJDAkMCgsKCwoLCgsKCwoLCgsKDAkMCgsKCwoLCgsKCwoLCgwJCwoLCwsKCwoLCgsKCwoLCgsKCwoMCQsKDAoLCgsKCwoLCgsKCwoMCQwJDAoLCgsKCwoLCgsKCwoMCQwKCwoLCgsKCwoLCgsKDAoLCQwKCwoLCgsKCwoLCgsKDAkLCwsKCwoLCgsKCwoLCgsKCwoMCgsKCwoLCgsKCwoLCgsKDAkMCgsKCwoLCgsKCwoLCgwJDAkMCgsKCwoLCgsKCwoLCgwJDAoLCgsKCwoMCQsKCwoLCgwJDAoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoLCgwJDAoLCgsKCwoLCgsKCwoLCgwJDAkMCgsKCwoLCgsKCwoLCgsKCwoMCgsJDAoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoLCgsKDAkMCgsKCwoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLCgsKCwoMCQsKDAoLCgsKCwoLCgsKCwoLCgsKCwoLCwsKCwoLCgsKCwoLCgsKCwoLCgsLCwoLCgsKCwoLCgsKCwoLCgsKCwoMCgsKCwoLCgsKCwoLCgsKCwoLCgwJDAoLCgsKCwoLCgsKCwoLCgsKCwoMCQwKCwoLCgsKCwoLCgsKCwoLCgwJDAkMCgsKCwoLCgsKCwoLCgwJCwsLCgsJDAoLCgsKCwoLCgsKCwoLCgwKCwoLCgsKCwoLChYUFhQWFRUVFhQWFBYUFhVVUxYqFhQWFBYUFhQWFRYUKykWFRYUKxQWKhYUKykrKispKxQWKispFhQWFRUVFRUWFBYUKxUVKhYUFhQWFBYUKyoWFBYUFhQWFRUVFhQWFBYUFhRWUxYpFhUWFBYUFhQWFRUVKykWFBYUKxUWKRYUKyorKSspKxUWKSspFhUWFBYUFhQWFRUVKxQWKRYVFhQWFBYUKyoVFRUVFhQWFAAAAAAAAA==",
"stop": "sMCwBGibBgAMCQwKCwkMCgsKCwoLCgsKDAkLCwsKCwkMCgsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwsKCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgoLCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCgsLCgoLCwoLCgsKCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsKCwsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsLCgsKCwoLCgsKCwoLCgsKCwoLCgsLCgoLCwoLCgsLCgsKCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwsKCgsLCgsKCwoLCgsKCwsKCgsLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCgsKCwsKCgsLCgsLCgsKCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwsKCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwoLCgsKCwsKCgsLCgsLCgsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCgsLCgoLCwoLCgsKCwoLCgsKCwsKCwoLCwoLCgsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwoLCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCwoKCwsKCwsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCgsLCgsLCgsKCwoLCgsKCwoLCgsKCwsKCwsKCwoLCgsKCwoLCgsKCwoLCgsLCgoLCwoLCwoLCgsKCwoLCgsKCwsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCgsLCgsKCwoLCgsKCwoLCgsKCwsKCgsLCgsLCgsKCwoLCgsKCwoLCgsKCwsKCwsKCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCwoKCwsKCwoLCgsKCwoLCgsKCwsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsLCgoLCwoLCgsKCwoLCgsKCwsKCwoLCwoVFRYVFRQWFRUVFRUVFRUVVVQWKhUVFRUWFBYUFhUVFSoqFhUVFSoVFSoWFSoqKiorKioVFioVFSoqFhUVFRUVFRUWFRUVFRUrKhUVFRUWFSoqFhQWFRUVFRUWFBYVFRUWFBUVVVUVKhUVFhQWFRUVFRUWFCsqFRUWFCsVFSsVFSoqKiorKioVFioVFSoqFhUVFRUVFhQWFBYVFRUrKhUVFRUWFSoqFhQWFRUVFRUWFQAAAAAAAA=="
"kitchenrollerblinds2": {
"open": "scCwBKaeBgAKCgsKDAkMCQwJDAkMCQwJDAkMCgsKCwoLCgsKCwoLCgsKCwoMCgsKCwoLCgsKCw4HChAFDAkLCgsLCgsKCwsKCwoLCgsKCwoLCgsKCwoLCwoLCwoKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCwoKCwsKCwoLCgsKCwsKCwoLCgsLCgoLCwoLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsLCgsKCwoLCgsKCwoLCwoKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwsKCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCgsKCwsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsLCgsKCwoLCgsKCwoLCgsLCgsKCwoLCgsKCwsKCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwsKCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsKCwsKCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwsKCgsLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCwoKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCwoLCwoLCgsKCwoLCgsLCgsKCwoLCgsLCgsKCwoLCgsKCwoLCwoLCgsKCwsKCwoLCgsKCwoLCgsLCgsKCxUVFRUVFRYUFhUVFRUVFRVUVRUqFRUVFRYUFhUVFRUVKioWFBYVKhUVKhYUKyoqKisqKhUVKiorFRUVFRUVFRUVFhUVKhUVKhYVFRUVFRUVKioWFRUVFRUVFRYUFhQWFRUVFRVVVBUqFRUWFBYVFRUVFRUVKisVFRUVKhUVKxUVKykqKyoqKhUWKioqFRUVFRYVFRUVFRUVKxUVKhUVFRUVFhUVKioVFRUVFhUVFQAAAAAAAA=="
"kitchen curtain": {
"close": "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",
"stop": "scBOAYieBgALCwwLDAsNCg0KDAsNqg0LDQsMFxkWDQsYCw0LDQsMFxkLDBcYFxkXDAsNCw0LGBcMCxgMDBgYFxgXDAsZDAsMDBcNCxgMCxgMDAwLDQsYDAsYFxgYDAsYDAwXDAwXGAwMDAwXGBcNCxcMDHcMCwwLDAwLDAwLDAsMCwyrDAwMDAwXGBcNCxgLDAwMDAwXGAwMFxgXGBgMDAwLDAwXGAwLGAwMGBcYFxgMCxgNCwwMFwwMGAsMFw0LDQsMDBcMDBgXFxkMCxgMCxgMDBcYDAwMCxgYFwwMFwwMdwwLDAsMCwwMCwwMCwwLDKsMDAwLDRYZFwwLGAwMDAwMDBcYDAsYFxgaFwwMDAsNCxgXDAwXDQsYGBcYFwwMGAwLDAwXDQsYDAsYDAwMCw0LGAwLGBcYGAwMFwwMGAsMFxgMDAwMFxgXDQsYDAsABdwAAAAAAAAAAA==",
"open": "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"
"living room curtains": {
"open": "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",
"stop": "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",
"close": "scCwBLqeBgANCg0KDQoNCg0LDAsMqw0LDAsNCw0WGRcMCw0LGAwMCwwYDAsNCxgXDQsYDAwLDAwMDAsMDAwMCwwMDAwMFxgMDAsMDAwMDAsMFxkLDAwMFxgXDQsYFw0LDAwMCxgYFwwMGAwLDQsMCwwMGAwMDAsYGBcMDAwLDGsMCwwLDAwLDAwLDAsMCwyrDQsMDAwMDBcYFwwLDQsYDAwMDBcMDAwLGBcNCxgMDAwLDAwMDAsMDAwMDAsMDAwXGAwMCwwMDAwMDAsYGAwLDAwXGBcNCxgYDAsMDAwLGBgXDQsYDAsNCwwLDAwYDAwMCxgYFwwMDAsMawwLDAwMCwwLDAsMCwwLDKsMDAwMDAsNFxgXDAsNCxgMDAwMFwwLDQsYFw0LGAwMDAsMDAwMCwwMCw0LDAwMDBcYDAwLDAwMDAwMCxgXDAwMDBcYFw0LGBcNCwwMDAsYGBcNCxgMCw0LDAsNCxgMDAwMFxgXDAwMCwxrDAsMDAsMDAsMCwwLDAsMrAwLDAwMDAwXGBcNCwwLGQsMDAwXDQsMCxgXDQsYDAwMDAwLDAwMCwwMDAwMCwwMGBcMDAwLDAwMDAwMFxgMDAsMFxgYDAsYGAwMDAsMCxgYGAwMFwwMDAsMDAwLGA0LDAwXGBcNCwwMC2wMCwwLDAsMCwwLDAwMCwyrDAwMCw0LDBcZFg0LDAwYDAwLDBcNCw0LGBcMDBgLDAwMDAwLDAwMCwwMDAwMDAsYGAsMDAwLDAwMDAwXGAwMCwwXGBgMDBcYDAwMCwwMFxgYDAwXDAwMCwwMDAsZCwwMDBcYFw0LDAsMawwMDAsMCwwLDAsMCwwLDKsNCwwMDAwMFxgXDAsNCxgMDAwMFwwMDAsYFw0LGAwMDAsMDAwLDAwMDAwLDAwMDBcYDAsMDAwMDAsMDBgXDAwMDBcYFw0LGBcNCwwMDAsYFxgMDBgMCwwMDAsMDBgMCw0LGBcYDAsNCwxrDAsMCwwLDAsMDAwLDAsMqwwMDAsNCwwXGRcMCw0LGAwMCwwYDAsNCxgXDAwYDAsMDAwMCwwMDAwLDAwMDAwLGBgMDAsMDAsNCwwMFxgMDAwLGBcYDQsYFwwMDAsNCxgXGAwMFwwMDAsNCwwLGQwLDAwXGBgMCwwMC2wMCwwLDAsMCwwLDAwLDAyrDAsNCwwMDBcYFw0LDAsZCwwMDBcNCwwLGBgMCxgMDAwMCwwMDAwLDAwMDAwLDAwXGAwMDAwLDAwMDAwXGAwMCwwXGBgMCxgYDAsNCwwMFxgYDAsYDAwMCwwMDAsZCwwMDBcYFw0LDAsMaw0LDAsMCwwLDAsMCwwMC6sNCw0LDAwMFxgXDQsMCxkMCwwMFw0LDAwXFw0LGAwMDAwMCwwMDAsMDAwMDAsMDBcYDAwMCwwMDAwMCxgYDAsMDBcYGAwLGBgMCw0LDAsYGBgMCxgMDAwLDAwMCxgMDAwMFxgXDAwMCwxrDAsNCwwLDAsMCwwLDAsMqw0LDAwMDAwXGBcNCwwLGQsMDAwXDAwMCxgXDQsYDAwMDQwMDAwLDAwLDQsMDAwMFxgMCwwMDAwMCw0LFxgMDAwLGBgXDQsYFw0LDAwMCxgXGAwMFwAAAAAAAA=="
"dining room curtains": {
"close": "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",
"open": "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",
"stop": "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"
Thank you @steelincable !!! Thank you! Thank you! Thank you!
After about a month I finally have this working!! Youâre the man!!!
I will do tha for sure! Thank you!
I need some help with the original cover_time_based component.
I use sonoff 2ch switches to control my blinds. I have installed the original cover_time_based component (its located in /config/custom_components/cover_time_based/). I have used the following configuration for the past months without an issue.
cover:
- platform: cover_time_based
devices:
roleta_sypialnia:
name: Roleta Sypialnia
travelling_time_down: 24
travelling_time_up: 26
open_switch_entity_id: switch.sonoff_1000d2d590_2
close_switch_entity_id: switch.sonoff_1000d2d590_1
aliases:
- roleta_sypialnia
roleta_zoja:
open_switch_entity_id: switch.sonoff_1000d2cdca_2
close_switch_entity_id: switch.sonoff_1000d2cdca_1
aliases:
- roleta_zoja
roleta_salon:
travelling_time_down: 32
travelling_time_up: 39
open_switch_entity_id: switch.sonoff_1000d2d58e_2
close_switch_entity_id: switch.sonoff_1000d2d58e_1
aliases:
- roleta_salon
However, after last updates of Home Assistant I get the following error:
Platform error cover.cover_time_based - Integration âcover_time_basedâ not found.
Any idea how to fix this? I do not wish to move to the ârfâ version as it requires scrpits instead of entities IDs and I am unsure how to solve this when I do not have a âstyopâ switch.
Try adding a version key to manifest.json, as the rf version has it.
HA team warned that if the version key will be missing, will block the components.
I disagree here, when calling scripts you can pass any variables you want so no matter variables people need, all is needed is transfer the data section.
When using this custom component is still possible to also use the RF remote control?
Yes, but then you might get out of sync unless you let the component know that a remote control was used if that is at all possible with your RF environment. The component provides a service called cover_rf_time_based.set_known_action to let it know if the cover was moved manually.
Hello @starob,
Thanks for you quickly reply.
I did not completely understand when you say ââŠyour RF environment.â
Assuming that I will be using a Sonoff RF Bridge could I use so the component and the remote?
Thanks again.
Sorry I donât have any experience with this device. Maybe somebody else can help.
The key is that whatever you use as an RF bridge is able to receive and understand the signals from your RF remote and is able to communicate with HA (eg using MQTT) so that HA gets updated with what you do manually.
Hi all,
I open/close the cover with the relays: switch.open_1/switch.close_1, this is the code:
devices:
room1_rolling_shutter:
name: Room1 Rolling Shutter
travelling_time_down: 5
travelling_time_up: 5
open_switch_entity_id: switch.open_1
close_switch_entity_id: switch.close_1
aliases:
- room1_rolling_shutter
In HA everything is okâŠ
The problem is with the wall buttons that are directly connected to the cover motor, so when I use the wall buttons the position of the cover isnât updated on HAâŠ
Is possibile to monitor the state of the switch.open_1/switch.close_1 and maintain the position updated?
If your control device cannot communicate with HA then there is no solution. How should HA know what you do manually if can cannot communicate with your switches?
If your device has an ESP8266 you could potentially install ESP Home or Tasmota which would solve your problem.
