Custom Component: Dreame Vacuum
Beta version contains an configuration option called Square Map which is added to solve this issue, you should try it.
Hi @tasshack , is the D10s plus supported by the beta version?! I tried to configure my robot but i got this error:
“Configuration failed, I will try again”
Screenshot 2023-08-25 181954
thanks!
Yes but seems like there is a bug that causing this issue. Can you open an issue about this in github page and provide the HA logs?
Ok, i’ll do, thank you!
That look awesome! Will it be completely declouded with Valetudo + Valetudo map card + this integration? And willl there be any problems?
No, you cannot use this integration with a Valetudo installed device. Also map feature requires cloud connection in this integration.
Thanks for your work.
Regarding the Real-time camera streaming feature and the technical reasons, do we have any ETA or it will never be integrated ?
Thanks a lot
Hey,
do you have any plans to integrate the new L20 Ultra?
Thanks!
L20 Ultra will be added to the supported devices list on next beta release (v2.0.0b6).
I’m trying to call dreame_vacuum.vacuum_set_custom_cleaning, but keeping getting error Parameter count mismatch!. The vacuum model is Xiaomi X10+.
service: dreame_vacuum.vacuum_set_custom_cleaning
  segment_id:
    [6,2,1,5,3,7,4]
  suction_level:
    [3,3,3,3,3,3,3]
  water_volume:
    [1,1,1,1,1,1,1]
  repeats:
    [1,1,1,1,1,1,1]
  cleaning_mode:
    [1,1,1,1,1,1,1]
  entity_id: vacuum.x10
I think it is not working correctly on beta, I will fix this on the next release.
You can use segment select entities to modify the custom cleaning settings for now or if you want to use multiple cleaning settings for different automations, suggest you to use onboard Shortcuts feature of the app which is designed for that.
Thx for the response!
Trying to install the beta version. But get unknown error after a while and then HA just reboots
It can successfully connect to my dreame account and discover the L10S Ultra
Also not seeing anything in the logs
Nevermind. This → Wizard fails to configure the integration, HA restarts · Issue #122 · Tasshack/dreame-vacuum · GitHub
Had to select low res map in order for it to work - with low res map disabled it consumes the CPU/MEM 100%
I am guessing you are trying to use this integration on a < 2GB Ram 32bit ARM device. If that was the case, integration does not consumes too many resources but your system does not actually have any.
Even HA installation guide does not recommend you to use an RPI2/RPI3 with less than 2GB ram.
Actually no, this was all stupidity on my end. Running it on an old Lenovo M710q tiny (2.7Ghz, 8GB RAM, 256 SDD), inside a VM.
The same machine is running my Milestone Xprotect VMS and I had too little resources assigned to HA.
I figured I just need to up the 8GB → 16GB and all will be fine
Hi, i have this problem; when i try to pin-&-go or clean a zone, i get this error:
xiaomi_miio/vacuum_goto - connection lost
How can i solve?
Hi, why does the cleaning mode change automatically at night, from sweeping + mopping to only sweeping? Thank you
I need more information than this to answer that question.
It’s possible use with dreame official app or need xiaomi home? Thanks
