Custom Component: Dreame Vacuum
You can use Dreamehome account but it is only available for the beta right now.
Is anybody else having trouble installing this integration?
You are probably using older version of HA than supported.
Iā€™m on the latest 2023.9.2 on my HA Yellow
Update: it installs now, but canā€™t get logged in
Does it only work when setup in the Mi Home app and not Dreamehomeā€™s app?
IMG_0666
You need to install the beta version for Dreamehome account.
Good news: I was able to update to the beta, login with Dreame account and it found my L10s Ultra vacuum
Bad news: It did not find my L20 Ultra (understandable since its new) and every time I view the L10s Ultra device page it crashes HA :sweat_smile:
L20 series will be added on the next beta release. If HA is crashing you probably need more ram on your setup or enable the low resolution map from the configuration settings.
iā€™m using the mi home app fore my l10s ultra, i have to delete the vacuum in home assistant install the dream app and connect that to home assistant? last time i tried that i couldnā€™t log in with the dream account.
do i need to be a beta user or is it only possible to use withe the MI home app?
thanks.
First you need to update your integration to beta using HACS, you can delete and add it again after that.
That worked! Thanks, bought you a :coffee:
Hi, i have some questions. I added Dreame x20 pro, all works, but canā€™t understand how to enable interactive maps (choose a room, cleaning zone, invisible walls, and others). I only have not interactive picture with a map.
A second question, can I use a robot camera in the home assistant like in the dream app??
ps I only yesterday started using HA))
How to use
Thanks tasshack for making an integration to include dreame bot vacumms.
One quick question is there a way to use cleaning shortcuts made on the app via HA?
Also out of 139 entities exposed of L10s Ultra about 50 or so entities are unavailable, is there something wrong on my end or is this still in beta and other entities will be added subsequently?
Shortcuts should appear as buttons with the integration.
Some entities are disabled by default, you have to enable them manually from entity settings.
Hi again, thx for the link, do this later (for now it is too hard for me). Now have another question to ask, is x20 Plus Pro fully supported with this integration? because I try to change the different robot settings, but it still does the same every time(I want to start sweeping only without mops and water clean). Also, I only have four rooms on the menu, how I can have one more?
You should really read all of the documentations before asking questions otherwise i cannot understand what you are trying to do because you donā€™t have the correct terminologies yet about Home Assistant and the integration.
is it now released with the dreame login?
Because I cannot login with the account information from the dreame app :frowning:
It is available on the beta, you need to turn on beta versions switch before installing the integration from HACS.
and it works like a charm :slight_smile: thx for your work!
Hi, thanks for your work, with this addon I have the ability to work with the ā€œlocked regionā€ through HA.
I have X20, it supports an ā€œextended mop armā€ (to wash close to walls) and leaving mops on base, to do sweeping only (the sweeping option also does not work, for now, or maybe I do something wrong), but this does not work, it always cleans in wet mode.
