Did you manage find any workaround? Thank you
install the beta and try it yourself.
yes i did unfortunately itās not supported but i saw dreame.vacuum.r2401 being supported. not sure what is the difference between these 2
Dude. Did you try logging in the beta and accessing your robot or not.
That will tell you if the robot is compatible
yeah i did on v2.0.0b16, my x40 master was able to access, my x40 ultra pro with codename r2401h is unable to access the robot
Another Ls10 Ultra with R2228B here. Is there something we can edit locally to get it working while we wait for update? Iāve tried current release and latest beta as of posting (Dec 4 2024 10 AM)
**On Beta using Dreamehome login
I canāt find such option so I assume that selected room cleaning is not available when using dreame login in beta version?
It is a very stupid thing to assume that without reading any documentation or post so you should delete it because donāt deserve to use this project.
In the Supported Devices isnt the D10s Plus listed, would the D10 Plus work too?
Yeah, I did read it, it is a WIP currently: š„ dreame-vacuum-card š§ Ā· Issue #466 Ā· Tasshack/dreame-vacuum Ā· GitHub
The base of the Dreame L10s Ultra has 3 buttons and with a double tap on the home button the robot leaves the station to be cleaned by hand. Newer models donāt have this button and I didnāt find any convenient way in the app. Has someone a idea how to let the robot leave the station, beside of moving it out by hand?
After upgrade to python 3.12.7 and HA 2024.12.1 I can not connect anymore and get the error:
Source: custom_components/dreame_vacuum/coordinator.py:443
integration: Dreame Vacuum ([documentation](https://github.com/Tasshack/dreame-vacuum), [issues](https://github.com/Tasshack/dreame-vacuum/issues))
First occurred: 2:20:54 PM (11 occurrences)
Last logged: 2:27:49 PM
Integration start failed: Traceback (most recent call last): File "/home/homeassistant/.homeassistant/custom_components/dreame_vacuum/coordinator.py", line 437, in _async_update_data await self.hass.async_add_executor_job(self._device.update) File "/usr/lib/python3.12/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/homeassistant/.homeassistant/custom_components/dreame_vacuum/dreame/device.py", line 2815, in update raise DeviceUpdateFailedException("Device cannot be reached") from None custom_components.dreame_vacuum.dreame.exceptions.DeviceUpdateFailedException: Device cannot be reached
Any idea what that could be caused from?
I see 2 options of which I donāt understand to which option in the app they map. I looked through the list of entities but could not find them. Could anyone help me with them?
For CleanGenius I can choose between āRoutine Cleaningā and āDeep Cleaningā, but I donāt see anything with those names in the app, thereās just CleanGenius or Custom. The names suggest they change the intensity of the cleaning routine, is there any more description of them?
And in the Configuration there is a toggle for āUltra Clean Modeā, but again I donāt see any setting with that name in the app. What does this do? It sounds kinda similar to the āDeep Cleaningā option above?
(see image in next post)
And for both of these, do they actually do anything if I change them, if I donāt see them in the app?
This is with an L10s Ultra Gen2 (r2469a), firmware 4.3.9_1103, Dreamehome app 2.1.4.16, integration v2.0.0b16.
Ultra Clean Mode = Ultra-Washing
Deep clean mop pads with increased water consumption and cleaning time.
Only support after Automatic Water Supply and Drainage Device installed and in Customize mode.
App probably renders it only if the Auto Water Check has been completed.
OK, thanks. I donāt have a water supply hooked up so that explains why the app isnāt showing it.
Maybe you could add a check for that, to only enable the toggle if the auto water supply is installed?
There is no easy way to check the water supply is installed so app stores a flag inside the phone that.
Hi Thomas,
Have you managed to login with the Dreamhome username? I have the same model R2228B but fail many times to login with my dreamhome username
First of all, thank you for the integration. Installation went smoothly.
I have recently owned the Dreame X40 and would now like to implement a few automations.
Example:
I ONLY want to vacuum my kitchen, and with the suction power āMaxā.
(see picture 1+2)
He does the following:
He uncouples the wipers, moves into the room and vacuums.
Unfortunately, it only vacuums with the lowest level, no matter what I set in the āvisual editorā or in the ācode editorā.
Where is my mistake? Anyone have an idea how I can solve this?
It is also noticeable that in the āvisual editorā only have 3 levels available for vacuuming and wiping, but in the Dreameapp I have more? My mistake?
Hope somebody can help meā¦
Regards Jürgen
Is there a way to retrieve existing schedules? Just want to be able to set up notifications on when upcoming schedules are happening. I have the Dreame X40 ultra. Thanks
