I can’t get the padding to work with the newest bar-card. How did you fix this?
Check out my card -
https://pastebin.com/aMeGq05x
I know it works on the latest 109 release
cards:
- cards:
- entities:
- entity: sensor.brother_mfc_j485dw
type: glance
type: entity
type: horizontal-stack
- cards:
- cards:
- columns: 4
direction: up
entities:
- color: MediumTurquoise
entity: sensor.brother_mfc_j485dw_c
- color: MediumOrchid
entity: sensor.brother_mfc_j485dw_m
- color: Gold
entity: sensor.brother_mfc_j485dw_y
- color: Black
entity: sensor.brother_mfc_j485dw_bk
height: 200px
max: 100
min: 0
padding: 2px
type: 'custom:bar-card'
unit_of_measurement: '%'
width: 100%
title: Brother Printer Ink Levels
type: 'custom:vertical-stack-in-card'
- entities:
- entity: sensor.mfc_j485dw_page_counter
- entity: sensor.mfc_j485dw_b_w_counter
- entity: sensor.mfc_j485dw_color_counter
type: glance
type: vertical-stack
Hi, Can you help me and explain how to setup MQTT?
I have also Canon printer so if you can share your setup I will be grateful.
Sorry no, I’m not using MQTT. I’m using SNMP to get my printer levels.
Sorry for not getting back to you before. I am not using MQTT. I am using Brother Printers HA integration
Has no one else tried the IPP integration? Seems to work well for my Cannon.
Appreciate you all sharing your code. Did a copy paste and enhanced it with a conditional card, so the ink-card is not displayed when the printer is shut off.
cards:
- type: glance
entities:
- entity: sensor.canon_printer_mf643cdw
- type: conditional
conditions:
state: idle
card:
title: Toner cartridge levels
height: 200px
max: 100
min: 0
padding: 2px
title_position: bottom
icon_position: inside
width: 100%
direction: up
columns: 4
entities:
- color: black
entity: sensor.canon_printer_mf643cdw_cartridge_054_black_toner
positions:
icon: inside
indicator: inside
entity: sensor.canon_printer_mf643cdw_cartridge_054_cyan_toner
positions:
icon: inside
indicator: inside
entity: sensor.canon_printer_mf643cdw_cartridge_054_magenta_to
positions:
icon: inside
indicator: inside
- color: Gold
entity: sensor.canon_printer_mf643cdw_cartridge_054_yellow_ton
positions:
icon: inside
indicator: inside
Hello Tomahawk, I do have Canon MF724cdw, tried to use IPP integration and failed connecting to the printer using IP address - what integration do you use?
thanks in advance for help
I used the IPP integration.
The printer is connected with a LAN cable. And the printers IP address is reserver at the router so it have a “fixed” ip-address. Hope it helps.
Thanks, this explains and helps in confirming that it does work for you.
When I tried, IPP integration did not want to connect to my printer (using IP address). Few factors are on the way (self-signed cert used, maybe also the subnet mask) I may want to diagnose, but with your comment I know I should not give-up too easy. In my case printer uses WiFi, what might be an additional factor, but I don’t have any issues with printing the materials from my phone (also over wifi). Magement interface is available but I don’t like page-scrapping techniques having IPP or SNMP.
I will go your route digging harder
You might try the ink2mqtt-addon from this repository: https://github.com/james-fry/hassio-addons. That one should work for Canon-printers.
This one requires the Mosquitto Broker addon to present.
Thank you, issue here is to force the printer “talking” any way, so far it responds only to https management portal. Obviously to printing requests too
I will give it a try.
Hello, I used your code and it works perfectly fine. Visually I would like to customize the boxes because the box “Canon Printer idle” looks a little lost. How and where can I do that? Which template do I need to edit?
- type: glance # Card no 1 - you an change this card or use another card which you can customize more...
entities:
- type: conditional # Card no 2 - This only displays when sensor.canon_printer_mf643cdw is idle
conditions:
state: idle
card:
Hi, could I use this for printer connected via usb?
Or is this only for networked printers
