Dsl pour la rĂ©ponse tardiveâŠ
2021-03-26 17:47:42 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.compteur_electricite fails
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
socket.timeout: timed out
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 234, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/usr/local/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 200, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 174, in _new_conn
raise ConnectTimeoutError(
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x7fc763e7a550>, 'Connection to 192.168.1.138 timed out. (connect timeout=2)')
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 573, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.138', port=80): Max retries exceeded with url: /api/xdevices.json?cmd=10 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7fc763e7a550>, 'Connection to 192.168.1.138 timed out. (connect timeout=2)'))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 277, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 473, in async_device_update
raise exc
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/ecodevices/sensor.py", line 188, in update
self._state = self._controller.get(self._request)
File "/config/custom_components/ecodevices/ecodevicesapi/__init__.py", line 40, in get
return self._request({"cmd": 10}).get("T1_PAPP")
File "/config/custom_components/ecodevices/ecodevicesapi/__init__.py", line 17, in _request
r = requests.get(self._api_url, params=params, timeout=2)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.1.138', port=80): Max retries exceeded with url: /api/xdevices.json?cmd=10 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7fc763e7a550>, 'Connection to 192.168.1.138 timed out. (connect timeout=2)'))
2021-03-26 17:47:46 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:02
2021-03-26 17:47:46 WARNING (MainThread) [homeassistant.components.sensor] Updating ecodevices sensor took longer than the scheduled update interval 0:00:05
2021-03-26 17:47:50 WARNING (MainThread) [homeassistant.components.media_player] Updating russound_rnet media_player took longer than the scheduled update interval 0:00:10
2021-03-26 17:47:53 WARNING (MainThread) [homeassistant.components.sensor] Updating ecodevices sensor took longer than the scheduled update interval 0:00:05
2021-03-26 17:47:53 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:02
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["c0day"]}}")' for attribute '_state' in entity 'sensor.water_today'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["c1day"]}}")' for attribute '_state' in entity 'sensor.gaz_today'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["meter2"]}}")' for attribute '_state' in entity 'sensor.water_flow_now'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["meter3"]}}")' for attribute '_state' in entity 'sensor.gaz_usage_now'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["count0"] | multiply(0.001)}}")' for attribute '_state' in entity 'sensor.water_total'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_status.attributes["count1"] | multiply(0.001)}}")' for attribute '_state' in entity 'sensor.gaz_total'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_teleinfo1.attributes["T1_PTEC"] }}")' for attribute '_state' in entity 'sensor.electricity_tarfi'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_teleinfo1.attributes["T1_PPAP"] }}")' for attribute '_state' in entity 'sensor.power_usage_now'
2021-03-26 17:47:55 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'attributes'') while processing template 'Template("{{ states.sensor.eco_devices_teleinfo1.attributes["T1_BASE"] | multiply(0.001) | round(0.001)}}")' for attribute '_state' in entity 'sensor.electricity_total'
2021-03-26 17:48:04 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:02
2021-03-26 17:48:28 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:02
