Don’t show beta for it.
Awesome, thanks I didnt even know that was already an option
I have remove the old version of HACS, copy the new one to the custom_components folder.
I remove the HACS option in configuration.yaml (as the description at the github)
How to test.
- Delete your custom_components/hacs directory.
- Download the zip file from this release page.
- Extract the zip file.
- Copy the custom_components/hacs directory from the extracted zip file to where you had the directory you removed in step 1.
- If you want to start using config_flow for HACS, remove the configuration for HACS in your configuration.yaml file.
- Restart Home Assistant.
After restart he shows in the integration page, so i put there my githib token.
But he don’t show up in my side-bar.
Same here, im trying to figure it out now…
@Cinamon && @Corey_Maxim Check the logs, and use the dedicated issue on github for issues with that beta.
I needed one HA restart more to show up.
My fault, i was on HA 0.96 instead of 0.97 beta, after upgrade to 0.97 beta it works!
next version (now in beta) you can reset it from the store. It also looks like they renamed the file in v13 as well.
You can just delete those.
I’m having problems installing HACS.
What I have done (I’m on 95.6):
- Followed instructions by the letter (I also have several customer components already)
- Removed any old ‘customer updater’ stuff from file system & configuration.yaml (left the stuff in Lovelace).
- Used ‘latest’ link (0.12.1) for HACS files
- I have created Github API key succesfully and have tried restarting several times with and without the entry below
hacs:
token: xxxxxxxxxxxxxxxxxxxxxxxxx
- HASS starts but I get notification that HACS could not be set up with below in logs
2019-08-07 23:13:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component hacs
File "/usr/src/homeassistant/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/config/custom_components/hacs/__init__.py", line 61, in async_setup
from .aiogithub.exceptions import AIOGitHubAuthentication, AIOGitHubException, AIOGitHubRatelimit
ModuleNotFoundError: No module named 'custom_components.hacs.aiogithub.exceptions'
Best log an issue on github has described in first post
Issues
If When you experience issues/bugs with this the best way to report them is to open an issue in the repository https://github.com/custom-components/hacs/issues , GitHub is AWESOME for tracking/searching issues.
So again, since this is kinda important, If when you experience issues/bugs with this, post them to GitHub, not here.
Issues posted in a forum thread is really, really, really hard to track/follow
The same goes for feature requests.
I think so, I may remove the old Alexa media player component fist then install the latest one after with HACS
Am I correct that HACS 0.12.1 is not running on HA 17.0 ?? I Did a fresh git install
Keep getting :
Sat Aug 10 2019 11:18:23 GMT+0200 (CEST)
Setup failed for hacs: Integration not found.
all is done according to instructions …
Yes, HACS 0.12.x require HA 0.93+
HACS 0.13.0 will require HA 0.97+
OK did an update to 0.13.0b1 But still the same error
Sat Aug 10 2019 12:34:02 GMT+0200 (CEST)
No more info found in logs
You are missing files. (or not restarting)
did a new git install from : https://github.com/custom-components/hacs/tree/0.13.0b3
added key to hacs:
token: ****
and restarted
Any way to get an attribute of what needs updated and a way to force an update without open the hacs plugin?
If there is another some other way let me know.
