Custom Component: HACS
Unless there are reported any more issues with the beta it will probably be released tomorrow(UTC).
You know one of the great things about hacs (besides the obvious convenience) is that I discover new custom integrations and lovelace cards just by cruising by the UI every now and then and looking for the new tag. Great stuff.
Same. But as its so easy now its finding the time to implement them all.
HACS is a game changer for HA in making it easy for new users to implement stuff.
Again @ludeeus hats off for creating HACS
Version 0.13.0 has been released
https://github.com/custom-components/hacs/releases/0.13.0
I can’t get HACS to install.
My config file:
hacs:
  token: blahblahblah
error message in logs:
2019-08-11 17:27:19 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: hacs
Do I have to add anything to the custom components folder?
yes, you need to follow the installation instructions.
https://custom-components.github.io/hacs/installation/manual/
thanks. got it. silly me extracted it to a new custom component inside my existing custom component folder
Working now! :relaxed:
Followed the instructions and installed 0.13 via ssh
Then I get :
Log Details (ERROR)
Sun Aug 11 2019 20:39:27 GMT+0200 (CEST)
Setup failed for hacs: Integration not found.
  • hacs
Please check your config., notification_id=invalid_config>
2019-08-11 18:39:28 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-08-11 18:39:28 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-08-11 18:39:28 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=webhook>
2019-08-11 18:39:28 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-08-11 18:39:28 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-08-11 18:39:28 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=auth>
2019-08-11 18:39:30 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2019-08-11 18:39:30 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2019-08-11 18:39:30 INFO (MainThread) [homeassistant.setup] Setting up api
2019-08-11 18:39:30 INFO (SyncWorker_9) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-08-11 18:39:30 INFO (MainThread) [homeassistant.setup] Setting up history
2019-08-11 18:39:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event panels_updated[L]>
2019-08-11 18:39:30 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-08-11 18:39:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
2019-08-11 18:39:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.auth>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.entity_registry>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.group>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.auth_provider_homeassistant>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.automation>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.script>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.config_entries>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.core>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.customize>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.device_registry>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.area_registry>
2019-08-11 18:39:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
  • hacs
This means that you:
  1. Are missing expected files.
  2. Did not restart.
What is the meaning of the red colored entries? Actually I have Alexa media player and spotcast components in red and I have 0.96.5 release.
Pending restart
But I guess shh install as described in you tutorial should install all files ??
Using : Home Assistant 0.97.1
Restarted 3 * now…
yes, open issue @ github include the dir contents of the hacs dir. + startup logs.
Ok, thanks!
Thnx, solved… wrong folder name… custom-components should be --> custom_components
Apparently I added a repository that is not supported with HACS (which I didn’t know was even a thing), and now after updating HACS I get
500 Internal Server Error
Server got itself in trouble
What can I do to fix this? Is there a config where I can delete the custom_component that I installed, or is it enough to simply delete the faulty component from the custom_components folder?
i don’t think u can install an unsupported component
After the update have you restarted HA?
Haven’t restarted yet - is that mandatory?
after an update of HACS yes
and after adding a custom_component as well
